Question about Air Tools & Compressors
VALUE DOES NOT DISPLAY ON SCREEN
DP AIR FILTER VALUE COMES ************ ON SCREEN AND NO VALUES
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,727 Answers
Oh ok thanks
Posted on Dec 30, 2013
Vlookup for duplicate cell values to display both names in separate cells
Check your formulae for a small error. Use F1 to guide you.
Jul 14, 2017 | The Computers & Internet
Determine the domain and the range of the
Domain and range are concepts that many students have trouble with, so you are not alone!
Domain is the x values of the relation.
Range is the y values of the relation.
If you have trouble remembering which one is which , like I do, D comes before R, just like x comes before y;)
To determine if a relation is a function, there are several tests that you can use. For every x value, there can be one and only one y value. If there is more than one y value for any x value, it is not a function.
Another test is the vertical line test. If a vertical line only goes through one point on the line, it is a function. If it goes through two points on the line, it is not a function.
As an example, let's look at y = (x-3)^2 + 6.
This parabola is in the form, y=a(x-h)^2 + k, where a indicates a stretch or compression, and whether the parabola opens up or down. If a is positive, it opens up, and the y value of the vertex represents a minimum. If a is negative, it opens down, and the y value of the vertex is a maximum. The values h and k are the x and y values of the vertex.
In this case, a is one, so the parabola opens up, with a minimum value of 6.''
Now back to the domain and range.
Since we can use any value for x in the equation, for the domain, x is an element of real numbers, sometimes written (xER).
For the range, y can only be greater than or equal to the minimum. So the range is y is an element of all real numbers, such that y is greater or equal to 6, sometimes written (yER'y>=6). Sorry I couldn't find the greater than or equal to character;)
Good luck.
Paul
Oct 03, 2014 | Office Equipment & Supplies
Why does ac go to 80 degrees when set at 76
Sounds like you need another opinion from another AC man. If you are in an apartment complex, it has been my experience most apartment techs have limited knowledge of what to check. Try this
1. With the unit on, go to you air filter and check for proper air flow. If you are using pleated filters, stop. Use what is called 30 day throwaway filters. Pleated filters block 35 % of the air flow and can cause evaporators to freeze over. Ace hardware still stocks the ones with the blue mesh with cardboard edges. I have used the same filters for over 2 years. All I do is use my vacuum cleaner and clean the dust bunnies collected every 30 days.
2. Perform an sight inspection of your duct system. I have had several customers whose duct have fallen off and they were air conditioning the attic space and/or crawl space.
3. Have your AC man determine your superheat and subcooling value for your airconditioning unit. If your AC man does not know what these are then he really isn't an AC man. A typical value for most superheat (SH) and subcool (SC) is 12 to 15 degrees. These values are typically normal values but can change due to design criteria established among manufactures. If your AC man does not know what these are or can not measure these you need to get someone that know how to obtain them. These values are typical value for a normally charged equipment and does not vary from refrigerant to refrigerant.
Hope this helps.
Jun 26, 2014 | Goodman Heating & Cooling
Post winxp install no dvd/cd found
Start Registry Editor (Regedt32.exe). Start > Run and type: REGEDIT and press enter
We need to locate the upper filter and lower filter in the Registry. Open the folder and its sub route through the heives... as below
To Locate the Upper filter we need to travel through the below given Heives.
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
Click on this Value and select Edit from menu and Press Delete to delete the values inside.
Delete also the Lower Filter in the same folder of the Registry... follow the steps to delete the value.
Quit Registry Editor.NOTE: After you remove the Upperfilters value and the Lowerfilters value,
Restart your laptop \ computer.
If you find that your system is malfunctioning at any cost you may need to do a re-installation of the CD\Drive Drivers.
If the CD\DVD is missing from the Device Manager and if you are not able to see the Status of this device, you may restart the PnP (Plug and Play) Services and you will have the drive details in the Device Manager.
Hope this resolves your issue. Good Luck
Mar 14, 2010 | Sony VAIO PCG-V505EX Notebook
My phone is deleting my text messsages and my calls I have made. When I go to check if my message sent, it says there is nothing in my inbox or outbox. How does my phone delete my stuff without me doing...
Cause 1 A number of large applications are installed on the BlackBerry smartphone. Resolution To resolve this issue, complete the following steps: Make sure that the BlackBerry® Device Software is installed on the computer to display the correct total application space. Determine the application space that is available on the BlackBerry smartphone by completing the following steps: Connect the BlackBerry smartphone to the computer. Open the BlackBerry® Desktop Manager. Double-click Application Loader. At the Device Application Selection screen, under the application selection window, note the total application space. Note: Select the List additional applications that are installed on the connected device check box to include the applications that are installed outside of the BlackBerry Device Software applications and the file sizes. Remove applications that are not required. For example, remove additional language packs and themes. Cause 2 A large amount of BlackBerry smartphone user data is present on the BlackBerry smartphone that cannot be removed by the Low Memory Manager. Resolution To resolve this issue, complete the following steps: On the BlackBerry smartphone, click Options > Status. Display the menu, and select Database Sizes. Reduce the number of items that are increasing the size of the database. For example, if the Address Book database is large, remove out-of-date contacts. If the Content Store database is large, move media files from the BlackBerry smartphone memory to a media card. Cause 3 Media settings may contribute to low memory capacity. Resolution Modify the Device Memory Limit settings by completing the following steps: On the BlackBerry smartphone, click Media. Select a media application. Display the menu, and click Options. Set the Device Memory Limit to the lowest setting field. Display the menu, and click Save. Note: Some BlackBerry smartphones have integrated cameras without a media card. As a result, some features have been added to handle picture storage on the BlackBerry smartphone, including the following: · Reserved Pictures Memory: In BlackBerry Device Software 4.2.0, the default value setting is 10 MB. In BlackBerry Device Software 4.2.1 - 4.7, the default value setting has been reduced to 2 MB. This setting reserves memory for pictures that the BlackBerry smartphone might take, and reduce the File Free amount that is displayed in the BlackBerry smartphone. This makes sure that the BlackBerry smartphone has memory available for pictures that are taken when a media card is not inserted in the BlackBerry smartphone. · Device Memory Limit: The default value setting is 20 MB. This prevents the BlackBerry smartphone from storing more than the specified amount of memory use. Cause 4 An application has expanded beyond intended memory boundaries. Resolution Note: In the Java® operating environment, applications increase and reduce memory usage when the applications launch, run required processes, and close processes. An application may use more memory than it is intended to use. Please make note of the values outlined in the following steps: On the Home screen of the BlackBerry smartphone, click Options. Click Status and note the values listed for File Free and File Total. Divide each of these two values by 1024, so that they are measured in kilobytes (KB). Record the new values, and name them as Displayed File Free and Displayed File Total. Display the menu, and click Database Sizes. Record the value shown in the Total Size field at the top of the screen. Open BlackBerry Desktop Manager, then open the application loader tool. Click Next on the Welcome screen. Connect the BlackBerry smartphone to the computer and allow the application loader tool to detect it. You might be prompted to type a password. Click Next on the Device Application Selection screen. Verify that the List additional applications that are installed on the connected device check box is selected. Record the value for the Total application space, located at the bottom of the window. Calculate the Reserved Pictures Memory for BlackBerry smartphones that have integrated cameras. If a camera is not integrated, proceed to step 12. On the BlackBerry smartphone, open the Media application. Display the menu, and click Options. Note the Reserved Pictures Memory value and multiply that value by 1024. Record the value. For example, 2 MB * 1024 = 2048. To calculate the Total Amount of Memory In Usage, add the values for Total Application Space, Total Size, and Reserved Pictures Memory (if applicable). To get the Calculated File Free value, subtract the value for Total Amount of Memory In Usage from the Total Flash Memory supported by the BlackBerry smartphone.
Oct 29, 2009 | AT&T Blackberry Curve 8300 Smartphone
How do you fix the clock display
No or dim display? You can replace the clock at about $160.00, or Check for a burned capacitor on the clock board, The likely culprit is labeled C3 on the board, its a 35 Volt 68 mF capacitor that needs to be replaced with a high temp (105 degree C) capacitor . Any capacitor that shows signs of discoloration and or leakage should be replaced with the same value but high temp. component. You can use regular capacitors of near equal values in a pinch but find the good ones of the correct values for a long term fix.
Aug 16, 2009 | Jenn-Air JJW8530C Expressions Collection...
Display says protect
check your low voltage fuses, the protect light up when a overload comes....
Jan 28, 2009 | Audio Players & Recorders
T30 always comes up with record-ready display screen
T30 defaults to an opening display screen based on where you were when you last used the device. When leaving from the record folder and record mode, you will always open with the record-ready screen. If you left your T30 while in the music folder playing a music file, you will be returned to that.
This record-ready display screen has a numeric and bar time line. The numeric values of the line are in hrs:min:seconds. This line is also split: the right half of the line indicates the total amount of available recording time, while the left half indicates your time as you record. If you compare the values of the right and left sides of the numeric bar while you are recording, you will see that the right side is diminishing as the left side increases in numeric value. When you complete your recording and save your track, the right side will now indicate the new total time (the amount your screen first displayed LESS the time value of the track just recorded).
When you are playing a music file, if you watch the time display, you will see the numeric information changing in the same way. The left side indicates how may hrs:min:seconds your track has played while the right side indicates the total time value for that file and will be correspondingly decreasing while you play your music file.
So in the short, you don't need to worry much about your display screen unless you open in the wrong folder or you need more recording time than is available. Then it has a message for you.
Nov 06, 2008 | iRiver T30 MP3 Player
Calculate Menu Problems
If you have more than one function graphed, use Up/Down to select the one you want. Press Left/Right to select the point at which you want the derivative, then press ENTER to see the value of dy/dx.
Oct 06, 2008 | Texas Instruments TI-83 Plus Calculator
Store & Recall Buttons
STO 1 puts the displayed value into memory location 1.
RCL 1 brings the stored value back.
Same for memory locations 2 and 3.
If there's something in memory, M1, M2 M3 will show in the display, clear the memory by storing the value zero.
Note that anything stored into memory location 1, 2 or 3 over writes what was there. Memory values are retained through power off/on.
To add the displayed number to a memory location (instead of replacing the value stored), use 2nd, STO, n
To exchange displayed and stored values, use 2nd, EXC, n
n is 1, 2 or 3
Get the instruction booklet from TI's website (pdf download) if you don't have one
Sep 26, 2008 | Texas Instruments TI-30XA Calculator
Air Tools & Compressors Logo
16 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
