Question about Ovens
My new induction stove is showing error 8888 what do i do?
Candy FPP609X oven not heating up
8888 usually means the clock needs setting as it has been disconnected from the mains.
Oct 07, 2017 | Candy Ovens
Frigidaire error code f27 Ovens
Most error codes can be cleared just by unplugging the unit and re-plugging it back in. If this doesn't clear it then I would go to Frigidaire's web site and search for tech support. I did some checking with Frigidaire and they don't show a code f27 I was wondering if maybe it was showing two codes F2 and F7? so it might look like F2,7?
Nov 18, 2015 | Frigidaire FGB24S5A Gas Single Oven
SAMSUNG INDUCTION STOVE ERROR CODE E84
Unplug the oven wait 10 minutes plug back in . Cooktop AND Oven working ? Yes - you have a communication problem - display board or main PCB.
Is the oven not working and the cooktop still works ? If yes it is a power problem on L1 or L2 , to verify if the issue is in the oven or the home swap L1 and L2 on the power cord. (if you do not know what you are doing then you should not touch them). If the Error remains yet the cooktop stops working or the cooktop stops and the oven starts working etc. Replace the Circuit breaker in your house panel - it works but not correctly. No Difference check the L1 line and the transformer connector on the oven board - resolder the connectors for the transformer.
Dec 23, 2012 | Samsung Induction Range FTQ307
Stove went completly dead during self cean no power door remains locked
Check the breaker for your kitchen even if it isn't flipped, flip it off and on again.. I had the same problem it turned out that my dryer and stove were on the same breaker, so I couldn't run them both at the same time.
Aug 03, 2012 | Samsung Induction Range FTQ307
I have a stove built in oven and had a power cut and it keep flashing 8888 and wont work
Hi.
After power cuts most ovens need resetting, for this reason 00:00 is flashing. The operation is described in the specific model's user manual. Most ovens reset either pressing or holding down for few seconds a Clear or On button, or holding down the main control knob.
Aug 06, 2011 | Ovens
Samsung microwave oven MS143HCE does not accept any command. Display often shows 8888.
Possible faulure of the processor or the control board. The indication of the display shows that the processor is having errors and hence there is no action of the controls to it. The commands are not taken or executed due to the failure .
Check the oscillation of the crystal in the processor/panel unit. Also the +5 volt to the processor .Both of these test wil indicate and confirm the processor.
Jun 17, 2011 | Ovens
Stove-top works, oven showing all 888888 across the screen
You're stove must be perfectly fine, but the thing displaying all those options may have a problem. Try to get this fixed as soon as possible.
Jan 31, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Monitor 422 oil stove error codes
put some lime say about 2 tea spoons with about 3 oz of synthetic 4 cycle engine oil
yhen heat to 188 degrees
pour about a cup of red devil drain cleaner into da mix
add 4 oz's of duck weed then add to fuel
wait a week and then turn on da stove
May 21, 2008 | Ovens
Ovens Logo
62 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
