I have a TLA-01901C Polaroid LCD I replaced - Televison & Video
I have a TLA-01901C Polaroid LCD I replaced capacitors on power supply and now my tv has white screen why does it not go back to green screen only white with no channels
  • 68 Answers
Mast look do you replace with same and do you look the + and - or same cable is not in place
Posted on Nov 25, 2013
  • Ron soto Nov 26, 2013
    I found the problem I had crossed the wires that connect to the power supply from the panel
SOURCE: Polaroid TLA-04011C LCD TV remote codes
I have the TLA-04011c and have yet to find a code. Out of curiosity, have yall? thanks
Posted on Jun 22, 2008
  • 5 Answers
SOURCE: how to disassemble polaroid TLA-01911C lcd tv
1) Take the foot off the stand and with a long philips screwdriver remove the single screw that is at the top of the leg (inside leg). Then with the tv facing down lift straight up on the leg.
2) remove the two screws comming from the back of the tv along the bottom edge.
3) With the tv face down on a soft surface ( towel, bedspread, ect).
4) Be carefull with this step it this tv gave me some difficulty and I am experianced with this proceedure. Too much pressure or forcing it too hard will break your case. The back of the tv has a lip which inserts into the face.The face has tabs that lock into slots in the lip of the back. Carefully pry between the face and back pannel (I used my thumbnail and a 1" plastic putty knife.) and slide along the seam until the locking tabs pop loose. Continue sliding your instrument along the seam until all tabs are loose.
5) The back of the tv lifts off of the face leaving all electronics in the face of the tv.
That gets you into the tv. what you do from there is up to you, Good luck;)
Posted on Mar 19, 2009
  • 718 Answers
SOURCE: OK,I've replaced the Power Control Board and the
Polaroid TLA-04011C
You can get a service manual from;
http://www.polaroidsupport.com/polaroid/docs/TLA-04011C_TLXB-4011_TLXB-4241_ServiceManual_20070613.pdf
This will give more diagnostic flowcharts etc. Could be useful in the future also.
Posted on May 07, 2009
  • 19 Answers
SOURCE: Polaroid 19" TV TLA-01911C has no picture. Powers up, see logo
To add to this solution above - I had the capacitor replacement and there was still an issue. Turns out the solder connection to the lamps themselves was very very poor causing an electrical arc (the scratching noises people are hearing) - then the inverter shuts the lamps down as it should. Fix lights!
Posted on Dec 10, 2009
SOURCE: hi polaroid tla-01911c white screen
polaroid LCD has white screen and no sound
Posted on Jan 11, 2011
Element tv dark no picture
This is a very common issue with that model. There are filter capacitors on the power supply board that fail and keep the back light power section from starting up correctly so you get no picture on the screen. The FLX-1910 uses the same power supply board of the Polaroid TLA-01911, below is a link to information showing how to repair this power supply board.
http://www.ccl-la.com/blog/index.php/repairing-a-polaroid-tla-01911c-with-a-bad-power-supply/
Nov 08, 2012 | Element Electronics FLX-1910 19 in. LCD...
When I turn on my tv the screen is white and nothing else happens.
This is a common symptom of a power supply failure on the TLA-01911c. The board has parts called capacitors that filter the output power and when they go bad the power supply does not power up right. The unit can either have no power, just a flashing power light, just a white screen or it could take a long time to show a picture. Here is a link to a repair guide that shows what to replace on the power supply board to repair the unit.
http://www.ccl-la.com/blog/index.php/repairing-a-polaroid-fla-01911c-with-a-bad-power-supply/
I hope this helps you get your TV bad up and running,
BuddyMc
Jul 13, 2012 | Polaroid TLA-01911C TV
My TV has a white/gray screen when I turn it on. I get nothing else, no sound either.
A white or gray screen usually means the power supply board is not functioning correctly. Below is a repair guide showing what to look for on your power supply board. Open the back of your TV and look at the power supply board as shown in the repair guide. If the capacitors are bulging on the top then they have failed and replacing them should get the board and TV back up and running. This is a very easy repair if you can do a little soldering.
I hope this helps,
BuddyMc
Sep 12, 2011 | Polaroid TLA-01911C TV
I have on element flx 2210 22inch lcd tv and when i power the tv to on the little blue light lites up for say 5 to 10 seconds then goes out and changes to amber without coming on and when looking down...
As others have stated your problem is most likely caused by bad capacitors on the power supply board. This power supply board is the 200-000-xxxxtltx and is the same board used in the Polaroid TLA-01911 TVs. Here is a repair guide that shows what capacitors to look for and replace on this board to rebuild it. This is much less than buying a new board even if you could find one for sale.
I hope this helps,
BuddyMc
Apr 22, 2011 | Element Electronics FLX-2210 22 in. LCD...
My screeen has gone white on my tv how do i fix it on my element flx-2210 tv
White screen only / no picture is a sure sign of a failure in the power supply board. Your TV is getting power to the back lights but the control board voltages are not getting through so it is not displaying the picture right. This is an easy repair to do, you will just need to replace the filter capacitors on the power supply board. This Element model is actually made by Funai and is the same as the Polaroid FLX-01911c TV. Here is a repair guide for that model that will show you what needs to be replaced to get your TV back up and running again.
I hope this helps you out.
BuddyMc
Jan 30, 2011 | Element Electronics FLX-2210 22 in. LCD...
My Polaroid Flat Screen Model TLA-01901C 19in will not turn on. It is not getting any power to it. I have tried un-plugging and using different power outlets but with no luck.
This sounds silly but is your cable securely plugged into the back of the TV? This sometimes comes loose, I know mine does! make sure that it is seated properly and try again! Post back if this does not solve your problem!
Sep 11, 2010 | Polaroid TLA-01901C 19 in. LCD TV
I have a Poleroid 19 inch flat screen. I turn it on and the picture is great but after 15 seconds there's a little pop sound and the screen turns black but you can still hear the sound perfectly. If I...
The tv have 1 or 2 long boards call the LCD inverter boards.These 1 or 2 long inverter boards are dead.That why the LCD screen not getting a backlight to produced a picture.Replaced those 1 or 2 long LCD inverter boards,will get a baklight back and have picture.Tries websites like Shopjimmy.com,Ebay.com buy those refurbishes 1 or 2 long LCD inverter boards for the replacement.
Aug 18, 2010 | Polaroid TLA-01901C 19 in. LCD TV
PROB LEM WITH POLAROID TLA-01911C
The white screen and nothing else usually indicates a failure of the filter capacitors in the power supply board. When these capacitors go out the voltages are not correct so the TV can not power up right. You can rebuild the power board by replacing the bad capacitors and this should bring the TV back to life. Here is a link to a repair guide for this power supply board.
I hope this helps,
BuddyMc
Dec 28, 2009 | Polaroid TLA-01911C TV
Televison & Video Logo
88 people viewed this question
Top Televison & Video Experts
Electro Med Services...
