Question about GPS
Calibrate screen navman
When you touch the screen on my navman Ezy 15 and selects the wrong letter or numeral and some you can't even press although you are pressing in the correct place
SOURCE: Touchscreen problem
I corrected my problem. It was a pain, but I pulled the thing apart and cleaned the screen around the edge of the frame. It had alot of dust and particles there. Put it back together and with one calibration it works fine.
Posted on Dec 17, 2007
SOURCE: Garmin 2610
Back up the unit then do a master reset.
Switch OFF, Press Page + Menu and turn on, holding the buttons for 5 seconds.
Then recalibrate. I did the recalibrate a few times before it was OK. If you use a stylus when the cross appears and hold it on the screen and move it to the corners you can see the error. Make a mental note and go halfway between the two if it does not calibrate at first go. Then when it calibrates, do it again. I recalibrate every now and again. I think it could be a firmware problem. I will try going from 4.8 to an old version
Posted on May 06, 2008
SOURCE: Re-calibrate Screen on Tom Tom One Regional
I tried this to fix my tomtom one, but it didn't work.
It may be worth a try on other models, though....
http://www.yournav.com/forum/index.php?showtopic=12622
Posted on Aug 07, 2009
sharcnet
  • 2130 Answers
SOURCE: Cant calibrate my Garmin Nuvi 255 GPS
You have the wrong procedure. Please see this link:
http://www.sharc.net/discus/messages/6/77.html?1236709210
- Jim
Posted on Dec 20, 2009
FixinFax
  • 3085 Answers
SOURCE: Garmin nuvi 205w. The keyboard touchscreen selects
Look in the settings menu for CALIBRATE SCREEN
Posted on May 22, 2010
Testimonial: "Thanks, recalibrating the screen fixed the problem. Turn satnav on whilst pinching top left corner of the screen , then follow instructions."
Navman problem
WHY is it suddenly, overnight, my Navman EZY 45 has gone from working perfectly to the touch screen hardly working at all? All the buttons have moved ie: You CAN'T touch on the button you want, you need to touch either the one above or below it. As for the Accept and address buttons, well that's just not happening, back = Q and so on.
I have formatted, reloaded maps, done everything Navman has suggested. Is this a Hardware issue? If so, a rarely used 15 month old unit will be going in the bin and I will compare other brands.
Any help appreciated as I love this small but great unit.
Cheers
Jan 02, 2014 | GPS
How to enter maintenance mode KM 3050
Press the STATUS KEY
With the numeric key pad key in 10871087 (if done correctly the display will change and say ENTER MAINTENANCE ITEM)
Enter 201 with the numeric key pad (follow the steps below):
1. Press the start key. 2. Select the [INITIALIZE].
3. Press the start key.
4. Press the center of the + keys. Be sure to press three + keys displayed in order. The touch panel is adjusted automatically.
5. Press the indicated three + keys, and then check the display.
6. Press the stop key. The screen for selecting a maintenance item No. is displayed.
Completion Press the stop key. The screen for selecting a maintenance item No. is displayed.
Now to exit maintenance mode key in 001 with the numeric key pad
Press the Start Key ( you should be back to the status screen, press copy key to go back to the copy mode)
Remember do not go to any other maintenance mode or make any other changes.
Dec 03, 2013 | Kyocera Mita KM-3035 All-In-One Laser...
Hi, Have a Kyocera KM4050 copier/scanner/printer with a touch screen. The touch screen is out of alignment (i.e. where you point does not align with what is sensed by the touch screen) and needs...
First you have to get into the maintenance mode. It is important once in there you don't make any changes other than the one I tell you or you could damage the machine.
To get into maintenance mode do the following:
Completion
Feb 09, 2011 | Kyocera CS-2050 Black and White Copier
Malfunctioning keyboard. If touch a letter A a different letter will come up. same thing trying to use the calculater.
the screen needs calibration. below are the instruction on how to calibrate the screen. The Digitizer Preferences screen opens the digitizer calibration screen. This is the same screen that appears when you start your handheld for the first time. You can recalibrate your screen after a hard reset or if your digitizer drifts. You may need to repeat this process a few times until the calibration registers. To calibrate your handheld screen: 1. From the General Preferences list, select Digitizer. 2. Tap the targets as indicated on the screen as precisely as possible.
TIP You can also press Left, Right, Up, and Down on the navigator to highlight a Preferences screen name and then press Select on the navigator to open that Preferences screen.
Aug 04, 2010 | Palm Zire 71 Handheld
Calibration is not right on my garmin 330
If you think the touch screen is not responding properly, press and hold the Power button until the
Calibration screen appears. Follow the on-screen instructions.
Aug 15, 2009 | Garmin StreetPilot C330 GPS Receiver
When i try to type in address the wrong letters keeps coming up
Do a screen calibration. There are different ways to get to it depending on which GPS you have but that usually fixes problems like that.
Jan 21, 2009 | Garmin Touch Screen GPS Receiver
Touch screen
I havn't tried this yet but I will tomorrow.
Per the Manual,
To calibrate the touchscreen:
  1. Press the remote or unit MENU key.
  2. Select Display
  3. Press the remote or unit FIND key to begin calibration.
  4. Follow the on-screen instructions
Hope this helps!
Aug 04, 2008 | Garmin StreetPilot 2620 GPS Receiver
Tech Help
You need to calibrate the touch screen. With the unit off press and hold the power button until the calibration screen appears (approx 35 seconds). The follow the instruction on touching the dot on the screen. Once this is done your screen should be OK.
Dec 28, 2007 | Garmin StreetPilot c340 GPS Receiver
Screen letters out of alignment.
It sound like low battery or a software "glitch" Either removing the batteries and waiting a minute before reinstalling them will reboot the software. If not, replacing the batteries should work.
Jul 01, 2007 | Navman iCN 520 GPS Receiver
GPS Logo
1,224 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
