Question about Canon imageCLASS Office Equipment & Supplies
DRIVER CANON MF4700 - imageCLASS Canon Office Equipment & Supplies
My Canon printer (Mf4700 Series UFRILT) says offline. It will not print. How do I fix?
Check if your USB Cable is plugged in
Try a Different USB port
Best option will be to uninstall and download latest drivers
  1. Look in Programs and Features and uninstall any program that correlates to the printer driver you wish to remove.
  2. Open Devices and Printers and if still present, remove the printer driver by right-clicking it and choosing "Remove device."
Not doing these before attempting to remove the driver files may result in an "access denied" or "printer in use" error.
To completely remove printer driver files from your system:
  1. Open the Print Server Properties dialog window by doing one of the following:
    • Click the Start menu and in the search field type 'printui /s /t2' (without the quotes), and then press Enter or click it in the search list.
    • Press WINDOWS-R on the keyboard to bring up the Run window, type in 'printui /s /t2' (without the quotes), and then press Enter or click OK.
    • Press the WINDOWS key on the keyboard to display the Start screen, type in 'printui /s /t2' (without the quotes), and then click it in the search list.
    • From the Start menu or the Start screen:
      1. Open Devices and Printers.
      2. Select any printer and then click "Print server properties" at the top of the window.
      3. Click on the Drivers tab.
    • For Windows XP systems:
      1. Click Start > Control Panel > Printers and Faxes.
      2. Click the File menu and choose "Server Properties."
  2. Select the printer driver you wish to uninstall.
  3. Click the Remove button.
  4. Select "Remove driver and driver package" and click OK.
Nov 07, 2016 | Canon Office Equipment & Supplies
How do i find the ip adress of the canon MF4700 printer
under the network settings option.. if you have an android cell phone you can run an app called "fing" it will look at your network and report back the devices connected and their IP addresses. Also most printers you can print out a network settings report. Also if it is not seen turn it off and unplug wait a few minutes and power back on.
Are you running windows? There are options that can be given if you can't find it with the settings menu on the printer or the android app I suggested.
Oct 19, 2014 | Office Equipment & Supplies
Drriver for printer mf4700 win7
http://support-sg.canon-asia.com/?personal
Go to above web site
then select your product category (Laser multifunctional printers) for MF4700 series.Now select your model and then select document type (Software & Drivers)then select your OS..WIn7 32Bit or 64Bit.
May 28, 2014 | Canon imageCLASS MF4150 All-In-One Laser...
What cartridge goes in to Lexmark MF4700 ?
Hello, This doesn't take ink, it only takes toner and you can get from Best Buy , Staples or Wal mart.
May 16, 2014 | Lexmark International Computers & Internet
I bought a canon image class MF4700 series printer but I cannot can not set the wireless connection I did not find the system manager pin where I find it and how I know it it support WPS.
1st WPS is not recommended to be enabled - very easy to defeat
2nd USUALLY setting up wifi involves selecting the network, entering the network p/w or security code and u r done.
the code is available from the router, the network admin, or a wifi connected computer.
Oct 20, 2013 | Canon imageRUNNER 5000 Copier
I want printer driver of Canon pixma MP287
Try this download. Hope this helps!
http://downloadnew.org/drivers/printer/canon-pixma-mp287-driver-508472.html
Feb 22, 2011 | Canon Pixma MP270 All-in-One InkJet...
Canon i350 printer
download the driver from some of these sites and try:
www.opendrivers.com/categorycompany/13/129/printers-canon-free-driver-download-page6.html
printers.free-driver-download.com/canon.html
multifunction.free-driver-download.com/Canon/33451/Canon-imageCLASS-MF5730-MF5750-MF5770-Firmware-Update
www.fixyourownprinter.com/forums/inkjet/21129
scanner.free-driver-download.com/Canon/29335/Canon-CanoScan-D660U-Scanner-Driver-ScanCraft-CS-P-v5.8.2-Wi
cameras-and-mp3-player.free-driver-download.com/.../Canon-PowerShot-A60-Firmware-2.0.0.0-For-Windows.html
www.softpedia.com/?tag=dir
Feb 09, 2008 | Canon i350 InkJet Printer
63 people viewed this question
old marine
old marine
