Question about Adobe PageMaker 7.0
Plug-in can not be completed some system operation failed
Error code 7212 4336
My laptop operating system failed to start it has an error code: 0xc0000001
It is probably a hard drive failure and will either require the operating system to be repaired, rebuild or at worst case the hard drive to be replaced and then the operating system to be reinstalled.
It is impossible to go further without expert examination so I advise you to find a reputable repair man.
Aug 21, 2014 | HP Computers & Internet
Microboard error code 306
The 306 Error Code is generated when any corresponding process or operation could not be completed successfully by the application.
error 306 may prevent the user from performing the required action or may the application will close unconditionally.
Technical (Deep) Description of Error Code 306:
This is a full Description of ERROR 306:
ERROR 306: MCIERR_DEVICE_NOT_INSTALLED.This error is due to .The default facility code
ERROR 306: EVENT_APPMGMT_UPGRADE_COMPLETE.This error is due to Application %1 from policy %2 successfully upgraded application %3 from policy %4..The default facility code
ERROR 306: SQL_306_severity_16.This error is due to The text ntext and image data types cannot be compared or sorted except when using IS NULL or LIKE operator..The default facility code
ERROR 306: ERROR_SECURITY_STREAM_IS_INCONSISTENT.This error is due to The security stream for the given volume is in an inconsistent state. Please run CHKDSK on the volume..The default facility code
ERROR 306: CO_E_LOOKUPACCNAMEFAILED.This error is due to The system function LookupAccountName failed .The source of the error code is an RPC subsystem.
ERROR 306: STATUS_LOGON_SERVER_CONFLICT.This error is due to The Netlogon service cannot start because another Netlogon service running in the domain conflicts with the specified role. .The default facility code
Fixing Error 306 manually is a difficult process and it is not recommend unless you are an expert in this field.
click start control panel administrative tools computer management then select event viewer this may vary depending on what operating system you have
extend the events there you will see errors in red you will no what exactly what the error was and at what time it occured
you might be able work your way through the problem
if you need more help with this post a reply with the error message details
hope it helps
Jul 13, 2012 | MicroBoards CFD-USB-15 1 Read,15-Port USB...
Maxdata tower computer : - when switched on bleeps 2/3 times and doesn't engage the mouse or the keyboard and the monitor shows " no video input ".Just no response and doesn't turn itself on...
BIOS Beep Codes
Whenever a recoverable error occurs during POST, the BIOS displays an error message describing the problem. The BIOS also issues a beep code (one long tone followed by two short tones) during POST if the video configuration fails (a faulty video card or no card installed) or if an external ROM module does not properly checksum to zero.
An external ROM module (for example, a video BIOS) can also issue audible errors, usually consisting of one long tone followed by a series of short tones. For more information on the beep codes issued, check the documentation for that external device.
There are several POST routines that issue a POST terminal error and shut down the system if they fail. Before shutting down the system, the terminal-error handler issues a beep code signifying the test point error, writes the error to I/O port 80h, attempts to initialize the video and writes the error in the upper left corner of the screen (using both monochrome and color adapters).
If POST completes normally, the BIOS issues one short beep before passing control to the operating system.
I hope this helps.
Mar 14, 2011 | Computers & Internet
Plug-in error (7212) (6176)
I am getting the following error when i try to open Pagemaker 7:
Plug-in error plug-in cannot be completed. some system operation failed [7212] [16]
Nov 05, 2010 | Adobe PageMaker 7.0
Plugged it in and the computer states there was a problem and will not recognize it have XP operating system Firelite 250 gb 5400 rpm
If the hard drive that you're installing has an operating system on it already, like Windows XP, you can't just move the hard drive from machine to machine if the computers are different. When you install Windows (or most other operating systems), the operating system customizes itself to the hardware in the computer. If you pull that hard drive out and install it on a completely different computer, Windows will most likely fail to boot and give errors and blue screens. This is normal. You will need to reinstall or repair the operating system if you want to keep the new hard drive in the machine.
Mar 07, 2010 | Computers & Internet
I got the below error ... is it possible tot ake my backup from the HDD?
A 0146 error means that the hard drive has a failing sector, and the drive will need replaced. If it's operable, then back everything wanted or needed up, because it will fail completely if it hasn't already.
Aug 26, 2008 | Dell Inspiron 6000 Notebook
Windows crash
These are operating system errors. Start by doing a check disc from the bios or set up. The check disc is a hard drive test, if anything fails then you have a hard drive crash and you will need to replace the hard drive. If it passes, then you will need to run a repair on the operating system using your recovery or operating system disc. If you have any hang ups or issues during or after the repair then you will need to completely reload a fresh copy of the operating system.
Jul 17, 2008 | Dell Inspiron 8600 Notebook
Destop cd driver
is this an external USB CD Drive ?
Windows error code 10 indicates a hardware error or failed driver installation. This error may appear if a device has insufficient power to operate correctly (if it,s plugged into a bus powered hub with other devices), or may indicate a more serious hardware problem. Also, it may be indicative of USB root hub drivers being incorrectly installed.
This could be a faulty or dirty USB Lead problem.
Hope this helps.
Mike @ Compurepair.
Feb 22, 2008 | Microsoft Windows Vista Ultimate Edition
Adobe PageMaker 7.0   Logo
136 people viewed this question
Top Adobe Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you an Adobe Computer and Internet Expert? Answer questions, earn points and help others
