Question about Roland Music
Roland ac 40 amp
Will not turn on power light does not come on do they have a fuse made a popping noise before it lost power only 4 days old
2 Suggested Answers
  • 5603 Answers
SOURCE: Roland EP3 Piano. Power supply
The damage will probably not go beyond the power input and regulaltor area. Should be fixable.
Posted on Apr 20, 2011
Roland ac 60 sudden loss of power. Is it the fuse?
If you mean it's completely dead, no lights or anything, then probably the fuse is blown. The question then becomes"what caused the fuse tio blow?".
If however, by loss of power you mean it's quiter but still producing sound, then the fuse is not blown.
Sep 08, 2013 | Roland Ac60 Acoustic Chorus Guitar...
Roland r8 has flashing green light
Are you using the correct AC adapter? An aftermarket unit will do this if the power is insufficient, or the polarity is wrong (- / +). If you're using an aftermarket unit, it may not be providing the right amount of Amps and Voltage to the unit; causing the display to blink. You can try this cord to help: http://www.powerpayless.com/ac-power-adapter-for-roland-r-8-r8-drum-machine.html
Jan 13, 2013 | Music
Roland Micro Cube Amp fuse blew out. How do you fix it?
have a look here:
http://www.ehow.com/how_8698510_fix-roland-cube.html
although it doesn't mention the fuse you will probably find it. Sometimes there is a fuse access on the outer case.
Jan 11, 2012 | Roland Micro Cube Battery Powered Amp...
I need the schematics for the Roland CK-60 amp or the wire diagram.
This MIGHT be close to your unit... it is for the KC-100... they often use the same circuitry.
http://elektrotanya.com/roland_kc-100.pdf/download.html
Scroll down to the "Get Manual" and click on it to download. There may be slight variations but these amps are simple enough to troubleshoot. USE the old trick of putting an incandescent lamp of say 100 watts in series with the power input to act as resetable fuse and save fuses when powering up after a repair.
Apr 29, 2011 | Roland KC60 (40W 10 3Ch Keyboard Amp)
My amp stopped working after 2 days from the day bought it. It stayed on standby for a while, about ten to fifteen minutes, but once I switched it on it started humming and making crack and pop noises.I...
Take it back for warranty replacement or repair since you only had it for 2 days. Since there is burnt smell this could be very serious problem. Probably a fuse blew due to any of several problems.
The pilot light runs off a rectified output of the power transformer but it is fused. There are three sopplies from the transformer and any of those could have a short and blow the main fuse or their individual fuses.
Take it in as I stated as this is NOT DIY repair. There are high voltages in this unit and if one is not adept at electronics you probably would not be able to repair it anyway.
Nov 29, 2010 | Peavey ValveKing VK112 50W Combo Amplifier
HI My Rowland Kc60 suddenly has no power. I presume it is shorted out...can I replace the fuse myself, and if so - where and what fuse do I buy and how do I access it on the amp?
Here is a link to the manual:http://lib.roland.co.jp/support/en/manuals/res/1811247/KC-60_e2.pdf Page 9 states that there is a protection circuit built into the power supply. Follow the directions for turning the power on in the manual. If the amp doesn't power up you will have to have it serviced by a qualified Roland tech as there is likely to be some damaged circuitry that won't be repairable without the schematic, parts and safe repair procedures.
Oct 18, 2010 | Roland Kc60
I have no cable for my Roland E-86. Witch one sould i buy??? tank you.
If you mean power adapter, it is a 12 volt 2 amp one and I don't know which polarity.
Here is an Ebay seller that has them for the E86:
http://cgi.ebay.com/AC-power-adapter-4-Roland-E-86-E86-Keyboard-Synthesizer-/110432738764?cmd=ViewItem&pt=LH_DefaultDomain_0&hash=item19b64dddcc
If it is the audio cable you are after, just get a standard INSTRUMENT cable (not speaker cable) with 1/4 inch plugs.
May 30, 2010 | Music
I need a power transformer for roland sde -3000
I need a transformer part 32 no:11-32-000 class 2 ac power transformer mod:mw48-090200a Input:120 ac 60hz output:9vac 2000ma.
(UL) US Ite powuer supply made in japan
Dec 11, 2008 | Music
Guitar amp signal interference.
Mine did that. Found out it was the input jacks
Apr 29, 2017 | Roland Music
Music Logo
19 people viewed this question
Top Roland Music Experts
Michial Gueffroy
Alex McGaughan
Alex McGaughan
Level 1 Expert
Are you a Roland Music Expert? Answer questions, earn points and help others
