Question about Microwave Ovens
Showing e83 error after heating
E83 error
E83 error code on display
circuit or door switches problem
Jul 24, 2015 | Microwave Ovens
We have a Samsung over the range microwave model ME21f7u7ljt, lights up but will not do anything else , shows eror code e83??
Sounds like you have a defective magnatron. Call around to get an approximate cost of repair including service call. Probably is not too much more to just replace it.
May 02, 2015 | Samsung Microwave Ovens
Oven shows -se- error,and now doesnt heat
Sorry but the -se- error code from the manual means:
An error of the oven may cause
low performance and problems
in safety. Stop using the oven
immediately.
Call local SAMSUNG service
centre.
Look for the 1-800 number on the back and give them a call.
Jun 10, 2014 | Samsung Microwave Ovens
Micro everything works but, it doesn't heat anything
go to appliancerepair.com and they have a video on how to repair this problem. I had to replace a diode in mine and that fixed it.
Jun 04, 2014 | Whirlpool MMV5208WS Microwave Oven
The induction cooker when put on it shows E6 after about a minute or so and no heating takes place.
There is a error message there, it indicate a problem with your induction cooker. It cause a defective winding wire or circuit controllers your know induction cooker works similar to the principle of electro magnet induction, it give heat to metal cooking pot. I hope I give you a idea regarding what happen to your unit.
Mar 23, 2011 | Microwave Ovens
Hi, The microwavw heats up and F3 shows on the LCD and wont work until after a while. Thanks
Make and odel please.
Error code F3 on many models of microwave oven means a problem with the touch panel, (tact switches).
Replace the switch panel to fix the fault.
Hope this helps.
Jan 18, 2011 | Microwave Ovens
I have GE model DE68 microwave. It does not show any errors. but it does not generate heat at all. What should i do
From your the description everything works but it won't heat. The problem is most likely the magnetron that heats the food is defective, or the least likely the high voltage transformer that drives the magnetron, either way the cost of repair will exceed a new microwave oven.
Jan 18, 2011 | GE Microwave Ovens
Microwave comes on but will not heat and shows error message on screen.
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
sgsgh
Jun 21, 2010 | KitchenAid KCMS185J Microwave Oven
Kenmore elite mircowave model 721,62369201...has a F9 error. ?? The unit runs, but does not heat up.
HI. in most cases, this will lead to a failed Heating device(magnetron tube).It would be wise to check the Magnetron cutoff fuse to be sure of its integrity. if the fuse is blown, simply replace it. if the fuse continues to show continuity, replace the magnetron.
(((The fuse is located inside the unit along side the magnetron)))
Aug 19, 2009 | Kenmore 63792 Microwave Oven
My GE microwave, model #WES1450DM1BB; serial #SM908139U, shows
When I try and heat some food, the microwave runs but doesn't heat anything, its a model wes1450dm1bb
Mar 15, 2009 | GE XL1800 1100 Watts Microwave Oven
Microwave Ovens Logo
74 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
