Question about Dishwashers
Blinking lights, unresponsive
Several lights are blinking on the control panel of my Maytag dishwasher, Model MDB5130AWB. The arrow by "Clean" The arrow by 6HR and the light above "Rinse Only" . They won't stop blinking. And the other buttons on the panel do not respond. I tried unplugging the unit, hoping it would reset, but it didn't.
  • Anonymous May 08, 2009
    all lights blinking, can't get it to start
I went to the Maytag site looking for a manual. None existed for my model, but I looked up won't start under the FAQs. The advice said to push the cancel button twice. My model doesn't have one, so I just started at the left side of the control panel and pushed each button twice. pushing the dry button twice made the lights stop blinking. i pushed the wash button and the unit started.
Posted on May 08, 2009
  • 1 more comment
  • Mark Oct 11, 2012
    I'm afraid pushing all buttons twice in succession had no effect. Still blinking, even after shutting off power at the fuse panel.
  • Lynda Klingsmith
    Lynda Klingsmith Nov 11, 2012
    My cleaning light blinks 7 times did the circuit breaker and the pushing buttons twice still cleaning button still blinking
  • Lynda Klingsmith
    I fixed it
I was told to push high temp wash then heated dry then high temp wash then heated dry the dishwasher ran a check took a feew secs then it worked
Posted on Nov 11, 2012
Called Maytag repair, they looked at unit, tried to reset it and said it was very likely the entire control panel unit had corroded and would need to be replaced.. Cost, approx $300 parts + labor. The current model of the same featured dishwasher was on sale for $499 ... I bought a new unit, and actually upgraded to the top of the line model in stainless steel for $759 plus $60 installation. Happy with new unit, very quiet,
MODEL DWF31 START PROGRAMME DISPLAY SHOWS 2H AND STAYS ON 2H ANY IDEAS
Hello. First, try to reset the control board. There are 2 buttons with arrows underneath. Press and hold them both for several seconds, maybe a little longer--this will perform a reset on the control board. See if that clears up the problem. Also, are there any lights blinking? Dishwashers will flash error codes(in binary format) by blinking certain lights in a pattern(i.e. The "sensing" light will blink 2 or 3 times, then the "cycle complete" light will blink 2-3-4 times--something like that) It could be any combination of lights depending on the component that has failed or has a problem. Components can be the drain pump, main wash motor, float switch(if present), heater circuit, inlet water valve, flood switch(if present), etc...
Sep 26, 2015 | Hotpoint Dishwashers
Jenn-air dishwasher will not start
it is usually the panel that fails
Apr 12, 2015 | Jenn-Air Dishwashers
Dishwasher control panel unresponsive
OK I am not an expert but I have spent the last two weeks learning about and fixing my dishwasher! Hopefully I can save you a headache. Try the following:
* Flip the switch off and on in your breaker/circuit box for 10-15 minutes. May reset your washer.
* If that doesn't work, try running diagnostic/reset cycles by pressing heated dry -normal- heated dry or heated dry-sanitize-heated dry in sequence. If the cycles run fine, you will rule out a power, latch, motor/drying issue. It also may (hopefully) reset your system.
* If normal function still does not resume after that, make sure your power (from the breaker box) is turned off and unscrew (with a star-shaped screwdriver bit - check your car emergency kit or toolbox, you may find you have it) and open the front button control panel and check all connections. Try carefully unplugging and replugging wires and look for any corrosion/moisture on the circuit board.
* If everything looks good but that does not work, test the circuit board by unplugging the green ribbon cable from the control panel, reassembling with the ribbon cable unplugged, flipping your circuit back on and then closing the dishwasher door. If the drain motor runs, it will show you that there is still some function with the circuit board. Although it doesn't rule out the circuit board completely, it will point to a most likely control (button) panel issue and try replacing that. If the drain test does NOT run, it may be the circuit board that needs to be replaced.
There may be some additional instructions specific to your model hidden in an envelope behind the kickplate of your washer.
Hopefully some of that helps!
Apr 18, 2012 | Maytag MDB7609AWS Builtin Dishwasher
Maytag mdb/c-2 some lights are blinking and won´t stop. I can´t start the cycle of cleaning, well really i can´t start anything. Please any sugestion ?
press the "off" button and hold it down for several seconds. this worked for me when i encountered the same problem on my maytag jetclean this weekend. it reset my control panel and now it's working great!
Sep 11, 2010 | Maytag 24 in. MDB5600A Jetclean II...
Control panel lights blinking
I have the same dishwasher with the same problem, try pushing the delay/resume button, then the drain/off button. When the lights go off start your wash cycle.
Sep 17, 2009 | Maytag 24 in. MDB5600A Jetclean II...
Maytag quiet series model #:MDBH950AWB
The dishwasher lights are all blinking, it starts randomly, like one in every 50 times you press the buttons. I have unplugged it to reset several times. Nothing is working. I'm looking for a solution to blinking lights and it not starting. is there any other way to reset the controls????
Jan 13, 2008 | Maytag 24 in. MDBH950AWS Built-in...
Dishwashers Logo
948 people viewed this question
Top Dishwashers Experts
