Question about Panasonic Lumix DMC-ZS3 Digital Camera
WHAT IT MEANS BY NO POWER REMAINS BY LX5
I WAS ABLE TO USE IT AND FULLY CHARGED. NEXT THING I KNEW IT SAYS NO POWER REMAINS :(
    Top Expert:
  • Panasonic Master
  • 6,702 Answers
I can't find this message in the manual. Power failures are the most common errors with portable gear. You have to rely on the quality of the batteries. Each and every battery can become faulty, with no obvious reason you can think off. Using lots of rechargeable batteries myself, I think I know where I'm talking off.Please to be sure, take another set of batteries, charge them and put them in the camera. Try to avoid alkaline batteries, because they only are capable of doing half the job of an rechargeable NiMH, pro charge. Also never use NiCD rechargeable batteries, because they won't have the correct voltage. (perhaps one or two shots, but the voltage drops very quick to 1,2 volt, its working voltage).
You also can check the camera and the batteries, if they don't have dirty or oxidised contacts. Only clean contacts with a dry cloth. Or when really dirty, with just a little contact oil on a cloth to wipe the contacts. Be sure you dry the contacts after the cleaning. Never use sharp tools to clean electronic contacts.
Posted on Nov 25, 2013
I have a syma x5c. No power. Bought new batteries for quadcopter fully charged still no power. What should I do next to make Work?
I'd be checking the battery-contacts in the battery-bay & also making sure there are no broken wires or connectors in the bay.
The next thing I'd do would be a function check of the main on/off switch on the 'copter & again check for broken wires or connectors.
Best of luck.
Mar 09, 2018 | Toys
Just bought a Ruobi drill with 18V Lithium Batteries. Been chatging for over an hour. Still not charged. Just the bottom Green light stays on. Is this normal? How long does it take?
The Ryobi charger will flash green as it charges and then remain steady or slowly flashing green when fully charged. Flashing red means testing and if it remains steady or slowly flashing red it is defective.
Apr 11, 2013 | Ryobi Two 18V Lithium-Ion Batteries +...
I can't start the engine. The battery is almost fully charged. I need to turn the key for about 3 or more times to start the engine.
If you turn key to START position, what is the sound, is it;
1. no sound at all means maybe starter problem.
2. only heard Tik sound means starter problem (you can add relay but it will still happen in future)
3. crank sound but not start means battery weak.
You can also try to move gearshift to N instead of at P position before turn key to START. if it work mean your car safety switch at gearbox not know which gear you're on.
Jun 16, 2017 | 2009 Kia Picanto 1.1
When the battery is on the charger there is 2 lghts one is power the otther is charge when the light is on for charge do it mean it is fully charged or charging
Yes, when both lights are on.. it means the battery is charging. The "charging" light should turn off once the battery is fully charged.
If the "charging" light remains on 12 or more hours later, your battery might need to be replaced.
May 15, 2011 | RCA CC285 Camcorder
My kindle reader will not power on
Make sure that the kindle is fully charged. When plugged into the wall the yellow led will light up as it is charging. When it turns green, it means the kindle is fully charged.
Feb 16, 2011 | Amazon Kindle Wireless Reading Device
Phone is completely dead. Battery is fully charged and I have taken the battery out and put it back in but still phone is dead.
Hi, how would you know battery is fully charged, and phone is still dead?.
You will need to confirm by using another battery to know if it is not a battery problem before you proceed to the next option.
After checking,if no response yet, that means you will now know that the phone is experiencing power problem.
To solve power problem,you will need to service the phone and flash the phone.
You can use this link to flash the phone for it to power up again.
(unlocktotalk.com/UnlockCodeInstructions.htm)).
And for the servicing of the phone, contact a technician.
Note: service before flashing.
Take care.
Jun 16, 2010 | Nokia 5230 Cell Phone
Sony DSC-W5 camera and the LCD screen is blank (white)
Remove the Battery pack from the Camera then press and hold the power button for 30 seconds.
Next, reinsert the Battery pack in the Camera and try to turn it ON. Make sure that the Battery pack is fully charged. If the LCD remains white then the LCD screen needs to be serviced or replaced.
Nov 25, 2009 | Sony Cyber-Shot DSC-W5 Digital Camera
Hi my LX5 stopped working on some of the surfaces. It was fine the other day and all of the sudden it only works fine on paper. On desk or mouspad i've been using for years the pointer barely moves. I...
Don't know about the different surfaces problem, but the batteries...I had similar problem with duracell charger/rechargeables and my digital camera. I bought new batteries, charged them up and they didn't last long at all. I finally bought a brand new charger and batteries and they work great as they should. Maybe the charger is bad or try cleaning the charger battery contacts with pencil eraser to see if that helps. Also, some devices work best with "normal" batteries.
Sep 12, 2009 | Logitech LX5 Cordless Optical Mouse
Delll axim x30 screen remains dimmed even though fully charged
ok , you have checked the brightness settings, check battery power settings as well. you may have to do a hard reset so back up your info. If doing a hard reset, pull the battery and charge it on its own if you have a cradle. Hope this works for you
Feb 28, 2009 | Dell Axim X30 Pocket PC
Panasonic Lumix DMC-ZS3 Digital Camera Logo
108 people viewed this question
Top Panasonic Cameras Experts
Computer Links
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
