Honeywell cm921 display is corrupt. lots of missing segments on the display. Can the led panel be reset or will a replacement thermostat be required
  • 407 Answers
Unfortunately, you will have to replace the thermostat. You can try removing it from the base plate (if available) for at least 10 seconds after removing the batteries, but I have never seen a display reset and correct the problem you are having.
Posted on Dec 08, 2013
My Honeywell CM921 wireless thermostat is showing 41c on display and not communicating with the Relay Box. I have tried resetting it using the Binding / Rebinding procedure but still nothing.
Take the cover off and see if there is a reset button (usually recessed so you need a pencil or wire to push it. If that doesn't work check on the circuit board for a blown fuse. It might be like a car fuse 3-5 amps.
Sep 20, 2014 | Heating & Cooling
Honeywell CM927 display problems
here is no repairing these, if it is not under warranty you must live with it or replace it.
www.honeywell.com
Dec 14, 2013 | Heating & Cooling
Honeywell cm921 has only half the numbers displayed.
a new thermostat is needed. Someone probably banged it. replacing it will be easier and cheaper for you
Oct 22, 2013 | Heating & Cooling
Honeywell cm921
Replace the thermostat.
CM921 LCD figures breaking up
Hi There - I have a similar problem to the one described by yourself . Did anyone offer any help or assistance on this at all ?
Many thanks
M Hudson
Jul 15, 2013 | Honeywell Programmable Thermostat Heater
I have a cm921 thermostat with the correct batteries showing full charge. Yet the battery light is flashing and says battery low. Also displayed room temperature is a lot higher than the actual room...
HONEYWELL WEBSITE:
Go to honeywell.com
Under red welcome sign
Bottom red highlighted box literature/image search
Type in thermostat model number
Click on arrow to right
Then click on the PDF files owners manual / installation instructions
If you can’t find what you want, the bottom left and bottom of web
Page, they have homeowners assistance and Home products to get the help you need.
Feb 28, 2010 | Honeywell Programmable Thermostat Heater
Honeywell CM921 Showing room temp at -24 degrees, How do I reset?
Heya this is a manufacturing fault from honeywell them selves when it comes up -24 basically it needs to be replaced there is no way around in if you get in touch with honeywell they are generally good about it also if you provide them with the date code and model code they will be greatfull as it seems they have sent out a "bad batch". you locate this by:
A) Move the slide in to the off position
B) Press and hold i for 5 seconds
C) Unit will enter settings mode
D) Press and hold the i button and the + and ¿ button together
E) The unit will hold the relay on for 5 minutes and you can view by pressing the down arrow twice for model id/date code (ww/yy)
I hope this helps
Nov 11, 2008 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
278 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
