Question about Baby Gear
Pram Repair torn seat
Bonito bebe
Hi Hollie
Maxi-Cosi do not produce adaptors for the carseats to fit to this manufacturers chassis. We would advise contacting the manufacturer of the chassis to discuss availability of adaptors and how to purchase.
Prams Pushchairs Car Seats Baby Goods Superstore Pram Centre
Apr 04, 2014 | Baby Gear
How do you put quinny zap adapters into the frame?
if you are wanting to put the adaptors on the pram to use the mai cosi car seat then you put the adaptors in where the pram goes in the holes if the pramseat is in already you see the silver bits at either side of the pram hold them in and lift the seat then put your adaptors in and clip the car seat to the adaptors once on its stable hope this help s
Jul 28, 2012 | Quinny Buzz Three Wheel Stroller
How do u attach the pram rather than the car seat??
Hi Anny
On both sides of the car-seat, where the carry-handle is attached, you can see a small button.(mostly grey)Push those at the same time and pull the car-seat off.
Then you can put the pram on to the same adapters on your stroller.To take the pram off works exactly the same as the car-seat, that's a nice thing about Maxi-Cosi.
Hope this helps!
Apr 22, 2011 | Maxi-Cosi Foray Trail Stroller
Removinf a car seat from a Pliko pram
With one hand on each side of the seat, press down on the buttons with your thumbs and pull both handles up until the seat releases.
Aug 19, 2009 | Peg Perego Pliko p3 Standard Stroller
Does toddler seat for emmaljunga fit all pushchairs of emmaljunga make - bought pram 2002.
No, the older toddler seats will not fit the newer model strollers. You will need to check the toddler seat and see how it attaches to the pram, there are two different styles.
Apr 01, 2009 | Emmaljunga Baby Gear
Emmaljunga toddler seat
You can not get a manual any more as they are not made. They are releasing a new seat in Feb 2010. This works in an identical way so I have been told. I have the old seat. It is easy to understand how it is fixed, but I would have a strong man to help, it can be tough.
Step 1 : locate bumper bar and with an alan key undo the two black clips either side that hold it together. Remove bumper bar from pram, Keep the two clips on the pram with the opening facing up.
Step 2 : With your toddler seat you should have another two of these black clips, place these two on the pram in the same way, but as far forward as they will go.
Step 3 : On your seat either side of the black knob that reclines the seat you will find two holes, simply place the seat lined up with the clips, put the screws with the clips threw the clips and the holes in the seat place, put the other side of the screw on and tighten. Thats it seat on.
Aug 02, 2008 | Baby Gear
Toddler Seat Accessory
I went to the Valco site and wrote and email to the Support Team and they emailed me the instructions to collapse the Toddler seat with the pram. The pram now 'squashes' nicely!
Jun 26, 2008 | Valco Runabout Deluxe Jogger
Baby Gear Logo
63 people viewed this question
Top Baby Gear Experts
Dorel UK
Dorel UK
Jennifer Rock
Jennifer Rock
Are you a Baby Gear Expert? Answer questions, earn points and help others
