Question about Philips 42PF7220A 42 in. Plasma Television
Tv not work
Hi, everyone
I have a situation with this model, 42pf7320A/37b that I purchased last year 5/08 and last Friday the TV was on and working fine when suddenly, the screen turned dark with not complete black, in fact there were some marks like the volume bar, but too dim, the audio was fine, then after some time it just turn off, with the red LED blinking like seven times and repeat all over.
    President:
  • 1,077 Answers
Well, don't feel alone.
Everyone is having the same problems with many brands of TVs.
Somehow built to fail after warranty. I'm sure it's a power supply related problem. From this link here, there is a Service Manual for the 42PF7320.
http://www.scribd.com/doc/6528782/Philips-42pf7320
Page 27 says error code 7 means 8V6 supply.
I'm thinking it's the power supply for the screen. I can't 100% certain.
Posted on May 08, 2009
    Scholar:
  • 44 Answers
I had the Same issue. on a 50PF9431D/37 set. Many Plasma Set's use a LJ44-00118A PS-505-PH Power supply from Samsung. Known to have this common problem. If you can, or have a friend that can Solder components?. Unplug your set remove the back panel & locate your power supply. It will be the PCB in the center of the set just above the Video/Audio connections. http://www.shopjimmy.com/power-supply-unit-lj44-00118a-from-philips-50mf231d-40.htm. Link to a photo of the PCB. Make a note of the location of all cable connections then unplug them all. Un-install PCB, Check a Fuse first. I believe their is 5 or 6 of them on the PCB. Then replace the two 3300uf 10v 105C Radial capacitors at C8060 & C8059. The location of the caps are in the Lower bottom edge of the PCB. A local shop may Carrie them if not, digi-key has them. Part # http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=493-1754-ND. Total cost was $7 with S/H.
Posted on Jun 26, 2009
Phillips tv wont turn
Go to Philips web site, (enter Model number....) then download updated software & drive to update your TV software. It will fix that problem. I just did for my TV (42PF7320A/37).
Here is the link:
Download and save in USB. Stick USB on the TV' USB then updated from there.
Hope, It will work. Good look!
Nov 07, 2013 | Televison & Video
I awoke this morning to find the sound on my Apex Digital LD4088 LCD tv is dead. The picture is fine, but sound is dead, how do I solve this?
Download the user manual to your TV. Clik here to download it. See whether audio options to it are set right. If all are right, check its speaker. If speaker is OK, the audio output circuit section should be troubleshooted.
If you feel any difficulty in downloading the manual, send your email address to me. I'll send a copy of it to you by return mail.
May 16, 2012 | Apex Digital LD4088 LCD TV
I purchased a phillips magnavox tv in 2006
Just google the model # and you should come up with it.
Nov 17, 2009 | Philips 42PF7320A 42 in. Plasma HDTV
When I turn the tv on it takes about two minutes to get a picture basically like it is slowly coming on. The TV was purchased new on March 6, 2009 so only a few months old.
Might be its time to replace Lamp Lamps Last only between 5000 to 8000hrs you cannot leave these sets on like a regular projection TV also could be just a defective Lamp make sure Fans are running correctly sometimes they are defective. Call or visit online Encompass Parts 1-800-638-3328
Nov 13, 2009 | Philips 50PL9126D/37B 50" DLP TV
Black vertical bar about 4 and a half inches wide down center of screen
hi...
It sounds like an Intergrated Circuit (IC) has fried.
Your best bet in this situation is to contact ur tv service operator and let them recommend an authorized service center in your area....
rate me!!
Jun 01, 2009 | Philips 42PF7320A 42 in. Plasma HDTV
Phillips Plasma - Model #42PF7320A/37 - 3 flashing red lights
it sounds like you could have a signal board problem they are pretty expensive but there is a web site that sells refurbed parts
Nov 17, 2008 | Philips 42PF7320A 42 in. Plasma HDTV
My Plasma TV is not working any more
Sounds like a scan problem if yu suspect the y-sus i suggs\est changing the drivers to
Nov 16, 2008 | Philips 42PF7320A 42 in. Plasma HDTV
Philips 42PF7320A blinks 3 times every time i hit the power button
The SSB is small self contained board that u connect your Antenna, and HDMI to. An error three is a communication error between the SSB and to Logic board ( located underneath the SSB on the back fo the plasma panel that is just below the power supply. U can check parts.com and see if u want to purchase a SSB for this TV. Is the 3blinking lights coming from the front of the TV. Also check the power supply and see how many times the green led blinks on the upper left of the power supply and let me know.
Apr 24, 2008 | Philips 42PF7320A 42 in. Plasma HDTV
Customer service number for Trutech
I too purchased TV on Black Friday from target in 2006 and w/in the last month the picture went..The sound works, but no picture..cust service tel #:888-252-6252..I tried to call but was on hold so long...I'm actually on hold again...If you happen to figure out what the problem is, please e-mail with resolution..TV isn't even a year old..Can't find the warrenty...
jdinap@comcast.net
Nov 08, 2007 | TruTech PLV16190 Television
Open Questions:
See all Philips 42PF7220A 42 in. Plasma Television Questions
Philips 42PF7220A 42 in. Plasma Television Logo
735 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
