Question about Sanyo NL-F560 Rechargeable Flash Light Lantern 220 Volts For Overseas
Circuit diagram for NL-F560 Rechargeable Flash Light
2 Suggested Answers
  • 12962 Answers
SOURCE: I have Sanyo NL-H786 Rechargeable Flash Light but it's not charging where can I repair it?
Try replacing the battery(s).
Posted on Jun 20, 2016
Tip
How to fix your gas furnice
most gas furneses have a red light on circuit board wich is located on intake. turn heater off then have someone turn it back on while you watch the circuit board. count the # of times the red light flashes before it pauses. it will flash in a cycle. for instance it flashe 3 times then pauses for 5 secounds then flashes 3 times again on and on. look on the back of the panel cover,their will be a diagram, in the diagram their will be dianostic report that will include what that # of flashing red light and what it means. for examle 3 flashing red lights ps stuck open. that means pressure switch stuck open. replace the part and your back up and running.
on Dec 18, 2009 | Heating & Cooling
Are schematics available for this device ihome iw1
I'm interested too because of a charging error. Battery is well, the problem is on the Mainboard (not the vertical with the WIFI-circuits). All voltages on the stabilization-ICs are correct
Apr 07, 2013 | iHome Airplay Wireless Audio System With...
My flash will not flash. I have put in new batteries. The units responds to TTL and menu commands and switches on perfectly. Even the pilot lamp goes to green, however the bounce flash and fill flash do...
Mine does the same after 10 or 15 flashes. It gives you the impression that its drained the batteries, but I doubt it. I have a feeling its some short-circuit or overheating.
Jan 03, 2011 | Nissin Di866 Flash for Canon
Flash on the green light,i guess it could be a false contact
Hil,
I'm going through here just to share the circuit diagram (schematic) for Boss PSA adapter because I know that many people need to repair their damaged fonts but can not get the original wiring diagram.
Savio
Oct 19, 2010 | Boss PSA-120 (761294015735) Power Supply
Flash light National PE-300SGW fails to charge
Thanks for your prompt reply.
Yes, I solved the problem of the Flash by replacing the main Capacitor.
In fact, as an Electronic engineer, I was looking for the Electronic circuit diagram, to be able to diagnose the problem on a scientific method rather than blind guessing through the circuits.
I'll appreciate if you could provide and offer the appropriate diagrams.
Thank you, Michael Aron.
Dec 18, 2009 | Panasonic Cameras
When using with canon rebel 2000. The batteries get hot
Not enough info-
Does the unit not flash? What type and size of batteries are in use? Are there ant odors, smoke or popping sounds coming from the unit? Are the batteries rechargeable and if so dies the charger or batteries heat up during the charging cycle. WARNING! dO NOT USE IT IN THE CAMERA- A SHORT CIRCUIT IN THE FLASH CAN DAMAGE THE CAMERA. uNLESS YOU ARE AN EXPERIENCED ELECTRONIC TECHNICIAN- DO BIT OPEN THE UNIT AND POKE AROUND IN IT- EVEN SMALL PORTABLE FLASHES MAY CONTAIN LETHAL VOLTAGES AND CAUSE INJURY OR DEATH.!
Come back with the information for more help. Ed
Nov 19, 2008 | Canon Speedlite 220EX TTL Flash
Amperege of 580 EX-II
Interesting Question!
The rating in milliamps is a matter of battery capacity and charging rates. The higher the better as you will get more flashes per charge as long as you have the correct charger to match the batteries’ capacity and use the correct charging times. Aside from this issue of duty cycle between charges- this has no effect on the power of the flash unit as to output. This cant burn out or damage the circuitry.
The issue here is VOLTAGE. Most AA alkaline batteries provide 1.5 volts. Most rechargeable AAs provide 1.2 volts. We are looking at a voltage differential of 1.2 volts (a 20% deficit) if 4 batteries are required. This MAY cause slower recycling times in order to attain a full charge for each shot. In SOME units that can cause a bit if overheating due to strain on the step up circuitry.
It so best to check with the manufacture or distributor of you flash unit before purchasing you rechargeable batteries and charger. If you units have a built in charging circuit this can definitely be problems if there is a mismatch in charging rates and voltage. If this is the case be sire to check your manual or with the manufacturer or distributor- there must be a list of compatible batteries.
Ed
Jul 08, 2008 | Canon SPEEDLITE 580EX TTL Flash
Sanyo NL-F560 Rechargeable Flash Light Lantern 220 Volts For Overseas Logo
128 people viewed this question
Top Sanyo Camping, Backpacking & Hiking Experts
Tom Chichester
ray gallant
Are you a Sanyo Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
