Question about Brother DCPJ315W AllInOne Inkjet Printer
On my Brother DCP-J315W the waste ink pad leaks out of the rear of the printer if it is tilted while being moved to another room. I had to do a lot of head cleaning cycles when using non OEM cartridges. Can the waste ink pad be cleaned or replaced?
  • 333 Answers
SOURCE: Brother DCP-110C - "Unable to Clean" - additional questions
I suggest you have a search through this forum for your solution
to your problem
http://www.fixyourownprinter.com/forums/inkjet/
Posted on May 05, 2008
SOURCE: Brother DCP-130C refuses to print the magenta ink
If you don't print at least once a month, you will clog the machine. You unfortunately have to get it fixed by a professional or get a new printer. Sorry!
Posted on Jun 14, 2008
SOURCE: cyan ink won't print on Brother MFC-665
talked to Brother, cost to much to fix, replaced the printer.
Posted on Dec 25, 2008
komguy
  • 2306 Answers
SOURCE: brother dcp-150c Clean Unable 46
If you actually changed the flushing box, you should know how to go to the maintenance mode and reset the waste ink counter. Info. that is only available to Brother techs.
Posted on Jul 30, 2009
  • 526 Answers
SOURCE: I have a brother DCP-135c printer. the magenta ink not printing
The process to get to the print head will take you approx. 1 hour. Without being trained on it, there is a high failure rate upon completion.
The Scanner assembly needs to be taken off. Harness Cables for the Scanner need to be removed.The Upper Case Assembly needs to be taken off. Printhead casing and printhead tubing calbes need to be removed, printhead mainboard needs to be removed, and then you have access to the printhead.
Thanks
Posted on Dec 19, 2009
What to do if it always appear in the monitor of the printer that ink absorber is near full?
Not only the absorber must be cleaned, also the counter must be reset. I know there is a program for older Epson printers to reset the counter. I found a reset procedure for a brother printer here:
How to Reset Purge Counter on Brother DCP J315W Printer
Perhaps you can fine one for yours?
Feb 21, 2015 | Brother DCP-J125
Unable init. 50 on my Brother DCP-J315w ...what should i do
Any failure to initialise, print, clean error report usually indicates the waste ink chamber is full and the purge count has maxed out. You can remove the waste ink chamber, clean and replace the pads and refit it but seriously time consuming and messy. You should try the purge count reset first (do google search) eg this one
http://ref.topictimes.com/videos/tech/how-to-reset-purge-counter-on-brother-dcp-j315w-printer-full-1NzJwuCpVOc.html
If that works, you can keep using it but should clean the waste chamber. Or save the hassle and just buy a new machine :-)
Jan 05, 2015 | Brother DCP-J315W Inkjet Multifunction...
Ink absorber full
This video shows you how to reset the counter so your printer will work again. However, it doesn't solve the problem of your absorber being full of waste ink. I recommend placing the printer on a towel in the event that the absorber overflows. This will avoid ruining the table your printer is sitting on.
http://www.youtube.com/watch?v=1NzJwuCpVOc
Here is the parts list if you wish to order the pad. It will take most of an afternoon and be very messy. Not for the novice. Your best bet is to reset the printer and use it until ink physically leaks out of the machine - then replace it.
http://support.brother-usa.com/ModelDocuments/Technical/Parts%20Manual/PM_DCP_J125_MFC_J220_J265w_J270w_J410w_J415w_J615W_J630W_EN_5179.PDF
If you do fix it yourself. You will need the following:
http://www.sparepartswarehouse.com/Brother,Printer,Part,LS4699001.aspx
http://www.sparepartswarehouse.com/Brother,Printer,Part,LS5136001.aspx
I have no experience with this vendor. It's just the first one that came up in Google that wasn't in the UK.
Apr 19, 2014 | Brother DCP-J315W Inkjet Multifunction...
My printer brother DCP-J315W status is offline, how do I change to online?
This one is really easy if you know what're you doing. Just go to your printer in control panel to bring up the print dialog. Go to printer at the top of page, drop down the menu and uncheck use printer off line. That should fix your problem.
If you still have issues with this particular model, you can always download this neat manual. It really helped me a lot. Good luck!
Jan 04, 2013 | Brother DCP-J315W Inkjet Multifunction...
How to reset counter in brother dcp6690cw
Sir/Madam
It's Very easy to reset counter in brother Printer,I suggest You watch YouTube video For Your Brother Printer Problem,I Hope You resolve and get all Brother Printer Help after watching this video URL Link below:
Or
In case You still need Help I suggest You Follow Us On:
Brother Printer Support
Nov 13, 2012 | Brother Ink for Dcp-6690cw and Lc-1100
INK ABSORBER PROBLEM
Brother Printer Dcp-j125 Ink Obsorber Full
Jun 26, 2012 | Brother DCPJ125 All-In-One Inkjet Printer
Printer won't print
..if not mistaken, the error message is Unable to clean, which indicate you will need to replace the waste ink pad and reset the waste ink counter.. you will need to send to the local service centre to get it done..
May 24, 2010 | Brother DCP 115C All-In-One InkJet Printer
Brother DCPJ315W AllInOne Inkjet Printer Logo
27 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
