Panasonic kx mb262
Hi..i use my panasonic kx mb262 as fax machine..the problem is i could not receive fax in. i can fax out (meaning that the phone line is ok, right?) because i've already tried using telephone to check for ringing tone & all..and there's no problem with that. Please help me..thanx
  • 960 Answers
Is your fax/ printer linked into your PC? Perhaps the firewall or anti virus is blocking incoming faxes??
Posted on Nov 25, 2013
5 Suggested Answers
  • 126 Answers
SOURCE: phone line is fine. But faxes will not convert to
check the splitter. ALso then reinstall the driver/software for winfax and see if this helps.
Posted on Apr 09, 2010
rajendrasngh
  • 393 Answers
SOURCE: download panasonic driver kx mb262
hi,
Go to the link
http://www.opendrivers.com/driver/278986/panasonic-kx-mb261-mb262-mb271-driver-multi-function-station-1.11-windows-9x-me-nt4-2000-xp%28x32-x64%29-vista%28x32-x64%29-free-download.html
and download the driver.
Thanks for using FixYa.
Posted on May 26, 2011
  • 2340 Answers
SOURCE: kx-mb262 laser printer panasonic driver
Check out this link @ http://panasonic.net/pcc/support/fax/asia/table/mb772cx.htm
Hope it helps.
Posted on Jun 10, 2011
  • 30 Answers
SOURCE: i have the panasonic phone
You can set your ring time to 5, 10, 15, 20, 25 or 30 seconds.
  • Tap **61*121*11* into your phone as if you're making a call.
  • Next enter a time between 5 and 30 (the number of seconds in multiples of 5)
  • Press # and then the call button. Don't put the phone to your ear - just look at the display until you see a message confirming your ring time has been set.
For example, **61*121*11*25# followed by the call button would set your ring time to 25 seconds.
Posted on Jun 11, 2011
Communication error 43 message every time and with every number.Panasonic fax kx-fhd332
COMMUNICATION ERROR (Code: 43, 44) means that "A line problem occurred". There might be a problem with the phone jack where your fax machine is connected to. Try to connect the telephone line cord to a different jack and try again.
Mar 21, 2011 | Panasonic KX-FHD331 Plain Paper Thermal...
Panasonic KX F511 wont' send or receive
If you cannot send or recieve. First make sure you have a dial tone at the jacj in the wall if you cannot hear it on the handset of the fax plug a phone into it and make sure.
Second make sure you have the line from the wall plugged into the jack on th machine that says LINE. Most machines have three jacks Phone handset and LINE Make sure you are in the LINE jack.
Hope this helps
Feb 18, 2009 | Panasonic KX-FL511 Plain Paper Laser Fax
We can send fax but can't receive...new fax line, old fax machine...panasonic kx-fc195
hi zebaron,
check your ink film maybe its empty, check the receiving mode if its on automatic mode, if its on manual mode you have to press the start button to start receiving fax.
hope this help....
Jul 24, 2008 | Panasonic Office Equipment & Supplies
Panasonic KX-FM220 fax machine does not have a dial tone
is your line provider ok.connect your line to ordinary phone to check if there is really a dial tone from the line provider.if there is a dial tone please let the analog board be cheked by a technician near you
May 01, 2008 | Panasonic KX-FM220 Plain Paper Thermal Fax
Panasonic KX-FL511 cannot receive faxes but can send
check to see if your phone line is plugged in the " L" or line slot on your fax machine if it is then press the speaker or monitor key and listen for dial tone. then you put a document into the feeder and dial your cell phone number and press send, when your cell phone rings answer and listen if you are getting a high pitched squeel. if you are then it should be working. try it the other way too by dialing from your cell and listen again for the squeel. if you still don't get the squeel you have a defective modem.
Thank You,
Mikey
Thank You,
Mikey
Apr 05, 2008 | Panasonic KX-FL511 Plain Paper Laser Fax
Panasonic KX-FL501
90 percent of the time that is a phone line issue.
But, first thing to look at is see if someone has removed the phone line and placed the line into the extension of phone jack and not the one marked "line"
You may simply need to replace the phone line between the machine and jack.
Yes you may hear a dial tone, etc etc, but you are losing one of 3 things. Either some of the phone line voltage, phone line current or what is called decibel loss.
When you send, you make the phone connection like lifting the phone off the receiver, but the signal to receive must be strong enough for it to key the fax board modem to receive.
If you have another device plugged in on the same phone line. Try removig that item, ex, an answering maching, Credit card machine etc and see if it is interfering with receiving also.
There is a high percentage the phone line is the issue.
Some things to check on the machine itself. Make sure Junk Fax setting is OFF, Make sure ECM ( error correction mode) is ON. Make sure Secure Receive is OFF and manual receive is OFF. Those will be in your machine setups.
The Junk fax setting will stop almost all incomming faxes.
It is less likely a software corruption issue. But that is remotely possible.
Let me know please, Some other obsecure things that can cause this. But I think you will find one of the posted things will resolve your issue.
Mar 04, 2008 | Panasonic KX-FL501 Plain Paper Laser Fax
Can't send faxes - Panasonic KX-FPG372 Fax machine
THE PHONE SEEMS TO BE GETING DISTORTED ,IT MAY BE IN THE PATH OF THES DIGITAL BOXES. PLS CHANGE THE LINE OR LOACTION HAPPY FAXING OMNIPRESENT
Sep 07, 2007 | Panasonic KX-FPG372 Plain Paper Thermal...
"Call Service 3"
if doing menu #9000*550 did not solve the problem for call service 3, it is better to call your panasonic service center.
the problem is in fuser unit. the thermistor maybe dirty or damage. careful to touch the fuser unit for it is really hot.
Nov 02, 2006 | Panasonic KX-FL611 Plain Paper Laser Fax
Computers & Internet Logo
65 people viewed this question
David Payne
David Payne
