Question about Powercom VGD-1000 (VGD-1000) UPS System
Bus Fault on Powercom VGD- 1000 ups - Powercom VGD-1000 (VGD-1000) UPS System
2 Suggested Answers
SOURCE: I have a powercom (VGD 1000 VA)online UPS.All
It sounds to me like you have a shorted cell in one of the batteries and the current limiting resistor on the charging side is out of tolerance (too low). Though it is more likely that they fail too high, they can go low in the event of overheating. I would check the resister with an ohm meter vs what is printed on it. It should usually be within 10 to 20% you can put one in series to limit the current, but you need a high current diode in parallel with it as no to limit the current to the inverter. I don't remember, but i think your model uses 2 12vdc batteries. You should replace all of its batteries and check the resister. Also, if there was a plastic insulator on the old mosfets you took off, you must have it on the new ones. this is to isolate the collector from ground. I home this helps,
Ryan
Posted on Apr 19, 2009
Fault code
Check your cable connections to the ECU. The "Can" in question is the information Bus, so the chances are that either a cable or connector has become loose. If you can't find a harness fault, then it would most likely be an internal fault with your ECU. Sorry!
Sep 15, 2013 | 2010 MV Agusta F4 1000 R
My powercom ups canot power on
hi there check the fuse and let me know the condition of that.
Jan 19, 2011 | Powercom BNT-600AP (bnt600ap) UPS System
IN POWERCOM UPS 1500VA I NEED THE VALUE OF THE RESISTANCE R74 , R67, R51,AND R49 THANK YOU
first u have Chaque the color coding of resistance and u fine exact value of resistor.
Mar 15, 2010 | Powercom (BNT-1500AP) UPS System
How can i connect my external charger with my powercom kin-1200ap ups.Im using external two battries of 12 volt 40 amp .
your charger should be 24v and more then that but how can you stop charging after full charging overcharge may damege the batteries
Feb 07, 2010 | Powercom King Pro 1200VA...
Ups after 1 hr automatic disconnected and on only battery mode.
I have to believe that the problem is in the smart chip, with the software that monitors the power. There is a very good chance that you have a slightly higher input voltage then normal. You may have to contact Powercom.....
I don't think you are in the USA...I sell Powercom and I don't recognize the part number. I think this is simular to the IMD 625 Va UPS sold here in the USA. The imperial model had a defect on the smart chip two years ago here in the USA, and I figured it out for the MFG, so maybe that same chip is acting up for you. Besides, the 600VA size should be too small for you know. You should upgrade to a 1000VA. It will handle the load much better.
Aug 26, 2009 | Powercom Computers & Internet
My Powercom UPS overload
remove all loads, unplug it, turn it off, wait 1 minute, plug it in, turn it on, apply loads. if this does not solve the problem, replace it.
Jun 08, 2009 | Computers & Internet
I have a powercom (VGD 1000 VA)online UPS.All MOSFET (IRF 3710)had been shorted and DC fuse cutted off.I mounted all 6 mosfets and DC fuse.Display has been come and it gives out puts in AC mains but not in...
Ryan
Apr 06, 2009 | Powercom (BNT1000AP) UPS System
Error 116 on start up
Start--> run and write ( Msconfig )
go to start up tab and uncheck anything about Sony Vaio VGD.....
Mar 01, 2009 | Sony VAIO PCV-RX460 PC Desktop
Powercom VGD-1000 (VGD-1000) UPS System Logo
139 people viewed this question
Top Powercom Computers & Internet Experts
David Payne
David Payne
Are you a Powercom Computer and Internet Expert? Answer questions, earn points and help others
