Question about Dell Computers & Internet
IN1930F NOT GETTING ON - Dell Computers & Internet
I have found power card of Del In1930f defective, after further checking I have found mosfet A2764 burnt and 1NN801B ic of driving card burnt, please help how to fix this problem.
It is considered unsafe to attempt a repair of a power supply of that design. It will probably cost less, than the parts and expertise, to replace it.
Dec 17, 2016 | Computers & Internet
Getting spark getting gas getting spark getting gas still won't start it still won't start I am getting spark I'm getting gas and it still won't start
Spark may not b strong enough or float level/fuel pressure wrong. Air cleaner or leak in a gasket. Test batt n starter for strength. Compression cud b bad
Oct 03, 2016 | Cars & Trucks
Why Dell icon flashes continuously on the screen when switched on in Dell IN1930f Monitor?
Press the Menu button on the monitor.
  • If the menu comes up, you've got a problem with the video signal.
  • If no menu appears, then there's something gone pear-shaped inside the monitor, possibly the power supply.
If you've still got the documentation for it, check the troubleshooting guide, usually found at the end of the manual.
Sep 25, 2016 | Dell Computers & Internet
Why my 1996 cadillac fleetwood brougham not getting any fire to the engine?
Your question needs some additional details. Are you sure that it is not getting fire to the cylinders or are you just using the term "not getting fire" because you are not getting any response from the engine when trying to start the car? Does the engine turn over? I would assume that it probably does based on your question. If your engine turns over then the first diagnostic step to see if you are getting "fire" (spark) to the cylinders is:
- Remove a spark plug wire and remove the corresponding spark plug.
- Put the spark plug wire back on the spark plug.
- Now hold the spark plug thread against a metal part of the engine
- You may want to use rubber gripped pliers to hold the spark plug
- Have someone turn over the engine.
- Watch the end of the plug to see if you are getting a spark jumping the gap to the ground electrode (little metal arm suspended in the air at the end of the spark plug).
- If you are getting spark then you are getting fire and your issue is most likely fuel related or timing (spark synchronization to the cylinder cycle).
- If you are not getting spark, then you have electronic/electrical issues
Let me know what you find out...
Aug 08, 2014 | Vehicle Parts & Accessories
Heater not working, heater core is getting hot, but vehicle is not getting warm inside
If the heater core is getting hot, you could have a problem with a blend door under the dash or the HVAC controller which opens and closes the doors.
Jan 13, 2013 | 1999 Chevrolet Suburban
The jeep has power and starter been replace but the jeep still wont start?
You need three things for an internal combustion engine to work, air, fuel and fire.
Is it getting all the above? Is there fire getting to the plugs? Is there fuel getting to the cylinders? Is it getting air?
If the answer is yes to all the above, then it should turn over and fire.
Possible causes for it not starting... Not getting air - Check air filter, or just take it out. Not getting fuel - Check your fuel pump, check your fuel filter, check your gas tank. Not getting spark- Check wires, check plugs, replace as necessary.
If all the above is GO, then I'd have someone check the timing.
Aug 02, 2010 | 1994 Jeep Cherokee Country
My engine is getting real loud...the temo guage
if your engine is getting hot after only a few minutews of running and it is getting loud than you probably have a cylinder head gasket problem. you should take it to a shop and have it checked.
Aug 24, 2009 | Hyundai Motor 1999 Elantra
My blazer will not start after i kill it. the fuel pump is still working .. what could be the problem?
even-though the pump may still be working, check make sure you are getting fuel to your injectors and check if you also getting sparks. two items need to make the car run. pull the plug out and ground it and have someone turn the engine over see if you getting fire; if you getting fire than check if you getting fuel, if not sure you getting fuel into your injectors than you can pour little gas in the carb intake and turn the engine over. hope that help some
Jul 09, 2009 | 1991 Chevrolet S-10 Blazer
Computers & Internet Logo
mukhtar21 shaikh
mukhtar21 shaikh
