Question about HP Pavilion dv6000z Notebook
Is cpu booster what i need?
I have been having rough times, on my laptop because of the cpu usage is almost at the peak.. usually it just play on 0-35%, but now 40-75%
so how would i lower this down?
  • HP Master
  • 4,338 Answers
You may have too many background processes working.
http://www.processlibrary.com/processscan/
Uniblue's Process Library has updated their free process scanner and I think it works really well ... and yes, it's totally FREE ... not something you click then have to pay for. Once you click the above link , click the green button that says Instant Process Scan ... when the scan is done, you will see a list of all of the processes that are running in the background on (and possibly slowing down) your computer ... click on any name and you will be shown a description of what the process is and does and whether you can turn it off or not.
also, download ccleaner to remove Temp files cookies and TIF's:
http://www.filehippo.com/download_ccleaner/
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on May 08, 2009
How many services and/or applications do you have running in the background? Click <start> <run> and type "msconfig" without the quotes, then click on <Diagnostic Startup> <apply> and reboot. Now do the 3 finger salute (Ctrl, Alt, Del) and check your CPU usage. If it has dropped way down repeat the process and this time click on the Start up tab and uncheck all those things which don't need to be running in the background.
Constant 100% CPU usage
you have to get safe mode if you have win xp /7 .also need to check malware and remove unwanted start up programs.
Apr 04, 2014 | Toshiba Tecra 9100 Laptops
Tip
How to Protect PC from Overheating?
Laptop over heating which is also known as Thermal Overload.This is mainly due to excess usage of CPU(More than 60%) for a long time.
To check CPU usage Right click on Task Bar>Select Start Task Manager>Performance.
or
Shortcut Ctrl+Shift+Esc
If your CPU usage is more than 50% you need to close some applications which are using 20++% CPU.
To check application which are using 20++% CPU
Right click on Task Bar>Select Start Task Manager> Processes
Search in this dialog box for programs which are using 30++% CPU
You need to close this application to prevent PC from over heating.Actually %age usage indicates load to CPU by the application.If load is to much CPU is to processes at faster speed which in turn increases temperature of CPU.
To close the program select the program,and select End Process.
If didn't found any program using 30++% CPU in this dialog box.
Select Show process from all users. and search in this dialog box and close the program.
Caution:some times your system also uses 30++% CPU inn some processes like anti virus scanning,at this if you closed the program your PC may shutdown.At this time you need to restart the PC.
This usually happens for out dated anti virus or incompatible programs.
There are some other factors like Graphics Properties and Graphic Memory,Display size, Processor type,etc.At this time its better top use a cooling pad.
Some program like camera drivers,Simulation softwares,games uses 50+% CPU.This is common these programs need to process large amount of data at short interval time which increases CPU usage but this is normal.
The processors properties are tested at 140*c so no need to worry.If the CPU exceeds the limited temperature PC will shuts down automatically,and after cooling you need to start the PC.
Thank you...:)
ANY SUGGESTIONS...?
on Feb 16, 2011 | Computers & Internet
Msi wind freezes and jitters when watching live tv
Sometimes live TV stream can be demanding on Internet bandwith and you memory. I would check Task Manger>Performance chart while streaming to see if you memory or cpu usage is peaked out. If it does, you should look into upgrading your memory.(If you are max out, see if you can change to a memory card with faster speed and capacity.)
Good Luck.
Nov 18, 2012 | Computers & Internet
Slow speed until rest daily
cause high peak usage can be resolved with booster
Feb 15, 2012 | Linksys Computers & Internet
My Toshiba satellite pro M10 very slow.
check your system performance thru task manager. check for CPU usage. usually COU usage is 1% to 10%. if your CPU usage would peak from 10% to 100% there is a huge possibility that there is program running on your computer that eats up your memory. Or it could be spyware/malware
Mar 27, 2010 | Toshiba Satellite Pro M10-S405 Notebook
My cpu usage is at 100 % when i run more two programs at a time, in turn making my computer slow even after installing a new operating system
Be careful how you interpret this information. In general, any program that has "work" to do will use the CPU when it is available. Showing 100% CPU usage over en extended period of time MAY indicate a problem or it may just reflect the case where there are background programs beiung run that have no effect on the system. The "scheduling" iof the CPU is usually done in chunks called quanta. Since CPU time is usually scheduled on what is called a pre-emptive mode, lower priority jobs (like virus scanning of the disc) will be pre-empted by an interactive user command (word processing for example).
Without examining your system and understanding what programs are running, it is hard to provide guidance on how to "fix": the system. Use the task manager to see what percentage of time is being used and for what. The utilization is shown as a percentage of the whole. Report the info here and we should be able to at least explain what is happening.
Dan
Feb 08, 2010 | Dell Latitude 100L Notebook
Mac OS 10.5.7 high user account CPU usage
Hi.Maybe you don't let your notebook get the air that must take.Probably if you have it on your feet on bed the macbook cannot breathe.Check this software out if you need further information about your computer's hardware temperature.
http://www.almico.com/sfdownload.php.
Jun 22, 2009 | Apple MacBook Pro Laptop Computer with...
Laptop Powercord Problem
there is a virus infection you need to scan system and have to check the power cord plug in a fix plug no sparking at all should be there.
Mar 03, 2009 | HP Compaq nc6400 Notebook
My tablet pen occasionally stops responding.
what you need to do is go into cmd prompt and type this: /configtab (you need to type it correctly, sometimes you may need all caps or no caps, it depends your software). get the 7 digit code that appears next to "confm" and go to your tablet settings and enter it into the confirmation input. and you are set to go!
Dec 18, 2008 | Wacom Bamboo Fun 8.5" x 5.3" USB Tablet...
Mx6124 problems with distorted sound.
The problem is your processor here.
If u use dual core processor for this, it will not use 100% of ur CPU usage.
Oct 14, 2007 | Gateway MX6124 Notebook
HP Pavilion dv6000z Notebook Logo
183 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
