Question about GE WHSE5240D ENERGY STAR Super Plus 3.2 cu. ft. Capacity Washer
F13 APPERS DURING THE WASH CYCLE AND THE SCREEN FLASHING IN aqm9d 49 u
Long running wash cycle for whirlpool quiet partner 2
Hi there
The quickest wash cycle is the "1 Hour Wash" and is 58 Minutes long, but if your incoming water is below 120 deg. F or 49 deg. C you are looking at approx. 1H20 min.
Regards
Phillip
Mar 28, 2015 | Whirlpool Dishwashers
My GE washer WM0642H is not going through the entire wash cycle. It will be at the second cycle of the wash and the timer will say 49 minutes. The washer pauses for a couple minutes and jumps to the r
Hello Jacqueline;
My name is Peter. I am a retired field service appliance technician.
The model number you have given is for a LG washer.
Anyway, you have a draining problem. FE = Fill Error. Your washer will not fill if it has not drained.
To fix the issue you will have to remove both the washer top and front cover to access the problem components.
Before the start of any work disconnect the washer power!
1.) Pump & or Pump housing is plugged up.
You will need to remove and clean these components:
Part Number 4681EA2001D - $57.00
On this component to check if the pump has failed you will need a multi-meter. Set the meter on the lowest Ohms. Disconnect the wire leads to the pump. Put one meter lead on one pump contact and the other lead on the other contact. If the pump is good the meter should read '0'. Perform this after cleaning.
Clean the pump housing
Check the drain switch.
Part number 6600FA1704X - $24.00
You will need a multi-meter as described above to check this component.
Hopefully, you are just plugged up.
Nov 30, 2014 | GE Washing Machines
Airston AQM9D 49 U giving F13 error
Already covered here
http://www.fixya.com/support/t14504284-ariston_aqm9d_49_u_display_error_code
Jun 22, 2014 | Washing Machines
F13 for AQM9D 49 U
Hi Ashraf, it's Jack at Dyson.
Unfortunately since 31st December 2012, we have been unable to support CR01 and CR02 washing machines with spare parts or servicing. In October 2012 we proactively wrote to all CR01 and CR02 owners that we'd interacted with within the last 3 years to make them aware of this.
If you would like to discuss your concerns further with one of our experts, you can reach us on 0800 298 0298. Calls are free from UK landlines, and we're available from 8am-8pm from Monday to Friday, and 8am-6pm on weekends.
Alternatively you may wish to check with local repair services for advice - please note, we cannot recommend or endorse specific repair companies.
Nov 25, 2013 | Dyson Memory CRO1 Front Load Washer
GE Profile WPRE6100G Top Load Washer My washer is 2 yrs old and has started to make a loud metalic banging noise during the wash cycle. It does not during the spin cycle. Doesn't seem to matter whether...
Hi!!
The "Metallic banging/clicking" sound you hear is the Shifter mechanism engaging or disengaging.
The drive system will engage at the start of the Agitate Cycle and disengage when the Agitate Cycle is complete. This occurs multiple times during the wash. GE claims this is a normal sound and should not be concerned about it. Check page 10 of your Operating Manual, if you do not have a manual, click on this link to download one http://products.geappliances.com/MarketingObjectRetrieval/Dispatcher?RequestType=PDF&Name=49-90323.PDF
Good Luck!! A HELPFUL - 4 THUMBS - rating for this solution would be greatly appreciated. Thank you for using FixYa.
Dec 03, 2010 | GE Profile WPRE6100G Top Load Washer
FRIGIDAIRE DISHWASHER CLEAN LIGHT FLASHING WILL NOT WASH OR DO ANYTHING
Do what 'mrrevo'l says to reset the dishwasher, and next time, try not to open the door during the wash cycle. Make sure that all the cycles are complete before opening the door. Especially don't open the door during the drying cycle.
Jul 15, 2009 | Dishwashers
Trouble shooting the hotpoint aqualtis aqxxf149pi flashing f08
my hotpint aqualtis aqxxf149pi make a funny grinding noise when it spins help please?
Jun 25, 2009 | Hotpoint Washing Machines
F13 error during drying cycle
Hi, that indicates that either the fan motor is not working/ blocked or the dryer thermistor (thermostatic sensor) is playing up. Of course, the pcb reads the sensor so it could also be that causing the error.
May 06, 2009 | Hotpoint Aquarius WD640 Front Load...
F01 Error code
most likely suspect main control bd
Apr 11, 2008 | Kenmore 46462 Front Load Washer
Washer stops during wash cycle
you may a pluse cycle where the washer will stop for a couple of min, this cycle is for perm press to minimize wrinkels
Nov 12, 2007 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
GE WHSE5240D ENERGY STAR Super Plus 3.2 cu. ft. Capacity Washer Logo
29 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
