Question about HP Scanjet G3110 Flatbed Scanner
How to calibrate paper in travel scan 860 - HP Scanjet G3110 Flatbed Scanner
Unable to get magic wand to scan documents
Mine was scanning and saving a black image. Needed calibration. To check, I calibrated on a bare lightbulb. Ugly, but there was an image. Recalibrate on brightwhite paper.
Jan 23, 2014 | VuPoint Office Equipment & Supplies
I want to download driver for TravelScan 860. model: 800U
I have travel scan 860, but it is not workig , can you help me with service centre contact details in delhi
S Kumar
+91 9650068887
kumar@ilfi.in
Mar 05, 2013 | Syscan TravelScan 860 Business Card Reader
Proform 860 treadmill, want to undo incline feature, & use it without it
Run the software calibration for easy diagnose, troubleshooting, and fix it.
God bless you
May 16, 2012 | Proform 860 Competitor Treadmill
My calibration page printed on plain white text paper
When you calibrate the 5100 AIO, first, you push in the photo paper drawer until it CLICKS. Next, print an alignment sheet. It will use the photo paper. Pull the drawer out, put the printed sheet in the scanner bed, with the arrow in the right hand corner, closest to you. Press start and it will scan and print a sheet on full sized paper.
If your initial scan doesn't print onto photo paper, you don't have the drawer pushed in the whole way. There is a definite click and the green light will turn on.
May 14, 2011 | Kodak EASYSHARE 5100 All-In-One Printer
WON'T RUN TRAVEL SCAN 464 CAN'T GET SOFTWARE UPDATED. DON'T HAVE DISK WITH ME
Complete driver with calibration here: http://www.docucap.com/downloads/
Sep 12, 2010 | Syscan 464 TravelScan Scanner
My paper comes out black after i scan it
try to calibrate the scanner, go control panel, scanner and fax, properties.. and calibrate with the calibration paper.. you can clean also with the cleaning paper..
May 11, 2010 | Visioneer Strobe XP 300 Pass-Through...
Canon mx 860 will not print from rear tray: gets
From the symptom,seems that another material (broken paper or something else) block the paper path. Observe paper path carefully and remove any material which blocking the paper.
Oct 10, 2009 | Office Equipment & Supplies
Why is this tekronix 860 printer kept flashing error message saying missing upper tray. However, all trays are intact. It looks like a sensor issue
Tektronix printer paper trays, I seem to recall that there's a plastic key that fits on the right side of the paper tray. It's a little plastic piece that just clips in on the right side of the paper tray. Sounds like it's missing
May 18, 2009 | Tektronix Phaser 860 Thermal Printer
SOFTWARE FOR TRAVELSCAN 860
Hi
Here it is:
TravelScan 860
32-bit Windows 98SE/ME/2000/XP: TravelScan 860 V3.2.0.0 [345 KB]
Calibration Note:
To calibrate your scanner use the back of a plain clean white business card.
Feb 10, 2009 | Syscan TravelScan 860 Business Card Reader
Canon PC-860 Black & White
ERROR MESSAGE ON MY CANON D 860 COPIER
Jan 30, 2008 | Canon PC-860 Black and White Copier
HP Scanjet G3110 Flatbed Scanner Logo
18 people viewed this question
Seeker5211
Seeker5211
