I have this horizontal flickering problem on my
I have this horizontal flickering problem on my philips 191EI.. Anyone know how to fix it? Thanks
    Top Expert:
  • Televison & ... Master
  • 75,424 Answers
This is not horizontal flickering. The picture is out of synchronization. The problem should be with its sync; separator stage circuit. For most modern TVs, this section will be a part of and IC, and is not repairable. Check what number IC is used as system-chorma-video jungle. It is faulty. Replace it. Before replacing, check all the components connected external to it. For details. You're seeing an out of sync: picture on screen. In this case, audio will be almost OK.
Posted on Nov 25, 2013
A solid horizontal line across middle of screen , sound is normal fixable?
Yes,hits the back plastic cabinate see if the picture flicker back to normal.Know how to slders just find out were is cold solders.Resolders that will fix it.Don't flicker back ur Horizontal IC is dead.Must take it to shop for IC replacement.
Feb 17, 2010 | Televison & Video
Top 3 inches of screen have horizontally flipped
that Good , you are a n electronics technician , check capacitors and resistors in vertical circuits ,
Sep 24, 2009 | Philips 27PT9015D 27" TV
Blue Screen with thin horizontal white lines
THI IS THE INTERNAL CIRCUTRY FAULT BEST YOU
call the service person and dont try to open it other than in side of TV SET HAVING Hazard of electrical shock be handle most care fully .
and check video board and all.
Oct 19, 2008 | Philips Magnavox 20MS233S 20" TV
Flickering screen
Yes, right click on the desktop, go to properties > settings > advanced,
Go to the monitor tab and try changing the refresh rate to something a little higher IE if it is set at 60, try 70.
Jul 18, 2008 | Philips 170P 17" LCD Monitor
RCA TV flickering problem
Your tv has a video problem, leak capacitor in video section, near in flyback need to replace it.
Apr 14, 2008 | RCA L46FHD37 46 in. LCD HDTV
PHILIPS 55PP8620
Good Day;
It sounds like the CRT COOLANT needs replacement, it is a fluid that trys too keep the picture tubes cool , but it some times get "dirty". The fluid is called 'PROJECTION TV COOLANT', it contains; High Concentration of Ethylene Glycol. You can purchase at M.A.T. Electronics; (215) 354-7667, in PA. Part Number 212072-16.
BUY at least 2 containers. CAUTION: remove tubes from TV, just alot of plugs,remove plugs, clean "fluid" chamber, replced discarted fluid. Good Luck, big IRISH. PS more INFO; come back.
Mar 28, 2008 | Hitachi 53FDX01B 53" Rear Projection...
Compaq presario v2000 monitor is having horizontal purple lines that flicker.
Try reloading the drivers, delete the device in device manager and reboot. It should then pick up the drivers and reload them, if that does not work I would suspect the screen is on its way out (flickering normally means the screen or its connection is bad)
Jan 26, 2008 | HP Compaq Presario V2000 Notebook
Faint horizontal lines in picture
This is usually caused by a problem in the Horizontal Output section, around the Horizontal Output transformer usually a capacitor or diode going or gone faulty... the line you see are the Horizontal "Retrace" lines that are useually "Hidden" when the circuit is OK..
Jul 30, 2007 | JVC AV-27320 27" TV
Televison & Video Logo
Top Televison & Video Experts
