Is there freeware that I can get to edit noise gates?
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 45 Answers
You don't need really fancy software to edit noise gates, the chrome add extension for audacity is good enough for noise reduction.
Posted on Nov 25, 2013
Can I use Grage Band on my mac for compression or do I have to get the Logic express software?
It really depends on what kind of editing that you want to do. For some the simplicity and limited function of Grageband is all you need, but to have more control and effects you will want to use logic effects. Both are really great software though.
Nov 25, 2013 | Audio Players & Recorders
What do noise gates do?
A noise gate is a software that is used to get rid of noise in a recording that you don't want.
Mic not working on toshiba a665 laptop; hisses
Get rid of all possible noise in your recording space. Pick the least noisy area to record in. Turn off any fans, heaters, air conditioners and other nonessential devices. Even an extra laptop or idle gaming console makes noise, so if you're not using it, shut it off. Close the doors and shut the windows. Place your microphone away from any remaining noise sources, including power sources. Don't record next to a window, even if it's closed. Remember that your computer makes noise, too. Even sounds your ear can't hear will become noticeable once you amplify your recording. Finally, turn off any cellphones. GSM buzz can be picked up in your recording, so do not set the phone to vibrate. Turn it completely off. Get as close to the mic as possible. Positioning for tonality and comfort has to be taken into consideration, but beyond that you simply want to get as close as you can. The closer the microphone is to the audio source, the less background noise will show up in the recording. Turning up your source will accomplish a similar effect. Simply speak louder, or if you're recording an electric instrument, turn up the volume. If your levels start clipping, bring the volume down on the mixer. Tweak the EQ. After your audio is recorded, you can often eliminate noticeable buzz or hiss using the equalizer. If your mixer has equalizer presets, try playing with those before you start recording to see what bands you can turn down to diminish noise. If you're mixing digitally, you can record the audio straight in without any EQ and apply one during the editing process. Finding the right equalizer band to mix down is often a process of trial and error. If it's a hissing sound, it's going to be in the higher spectrum. If it's a buzzing sound, it's probably coming from the mid to lower spectrum. A graphic equalizer is a great mechanism to form a valley in the EQ and move it around until the noise is reduced. Use a speech enhancer plugin. Any good mixing program has one; even something as simple as Apple's GarageBand can do the trick. Or, try searching the Internet for a third-party plugin. The speech enhancer will let you apply some quick tone settings to make a speaking voice sound more professional. More importantly, it will give you the option to dial back the more quiet sounds in a recording. This will help isolate the vocal and push everything out. While this type of plug-in is meant for spoken audio, it can be used -- with mixed results -- on any kind of audio. Know your noise gate. The noise gate is your key to absolutely silent pauses and crystal clean audio. The gate takes out all noises under a certain level and turns them down however much you tell it to. If you find that your desirable audio never gets any quieter than -20dB, you can tell your noise gate to turn the recording down any time audio is not exceeding -25dB. You can even tell it how much to turn it down: all the way for a clean recording, or maybe just a little to allow some natural hiss in. The noise gate appears easy enough on the outside, but can be a little complicated to master. If your settings are too high, you will clip out parts of your recording, making it obnoxiously unlistenable
Feb 22, 2013 | Toshiba Computers & Internet
There is a reading that says threshold on my noise gate. what does this threshold refer to?
anything below the established threshold will activate the gate. if the threshold is 20 decibals, than noise at 19 decibals will be lowered by the gate
Jan 29, 2013 | Audio Players & Recorders
What is the difference between a noise gate and a compressor?
They both lower volume, but a compressor lowers the volume of a signal that gets too loud, and a noise gate lowers the volume of quiet signals such as background noise
I need fluent software for free. and installation procedure....
http://www.freeware-downloads.com/radarsync_-_free_edition.htm
Freeware Downloads.Com periodically updates software information of RadarSync - Free Edition from the publisher RadarSync Ltd., so some information may be slightly out-of-date. You should confirm all information before relying on it. Software piracy is theft, Using RadarSync - Free Edition crack, password, serial numbers, registration codes, key generators is illegal and prevent future development of RadarSync - Free Edition. Freeware Downloads.Com also does not provide download link for RadarSync - Free Edition from Rapidshare, Hotfile, Megaupload, Yousendit, Mediafire, Filefactory and other Free file hosting service also. The download file is obtained directly from the publisher, not from any Peer to Peer file sharing applications such as Shareaza, Limewire, Kazaa, Imesh, eDonkey, eMule, Ares, BearShare, Overnet, Morpheus, BitTorrent Azureus and WinMX.
hope this helps
May 11, 2011 | Computers & Internet
Noisegate on vyper tube 120 chokes note off on high gain settings to much for my taste
You are probablly overdriving the unit. Too much gain saturates the electronics. The noisegate really only works to eliminate noise when input signal is below a certain level... it is NOT used or effective when at high signal levels. If you set gain too high the tiny signals will open the gate. The noise gate will prevent low signals like guitar "handling" noise from passing through until you are actually playing the guitar. This is the purpose of the noise gate.
Apr 13, 2011 | Peavey VYPYRT120 Vypyr Tube 120Watt Combo...
Did a full recovery on windows xp home edition.
Freeware for data recovery Best freeware for data recoveryWhen computer data loss happens, like deletion, careless format, it actually means losing data. Data recovery is generally means a consumption of time and money. Ever through there are lots of freeware for data recovery, most of the freeware can only recover deleted files. These freeware for data recovery are can do nothing when the data is lost due to format, partition loss, system crash.
Luckily, EASEUS launched the first full-featured freeware for data recovery: EASEUS Data Recovery Wizard Free Edition. This freeware for data recovery is designed to recover data from all kinds of data loss problems. This data recovery freeware is so potent that most commercial data recovery software can't do more than it. It is able to recover data from lost or deleted partitions and even recover your files after partitioning or crashed hard drives. The freeware works well with FAT12, FAT16, FAT32, NTFS/NTFS5 and EXT2/EXT3 file system.
How to use freeware for data recoverymain.gifThis freeware for data recovery is very easy to use. A wizard interface will guide you through the whole process of data recovery. There are three recovery modules on the main window of the freeware.
Deleted File Recovery: aims to recover deleted files even if emptied from Recycle Bin.
Complete Recovery: aims to recover lost files after format, or from RAW partition.
Partition Recovery: aims to recover lost file from lost/deleting/missing partitions or system crashes.
Takes complete recovery for example:
1. Click the "Complete Recovery" button on the main window of the data recovery freeware.
2. Choose the partition that was formatted and click "NEXT" to start searching on this partition.
free-complete-recovery-1.gif3. Press "NEXT" button. The freeware for data recovery will launch the "Building directory" procedure to searching the files. You will see file/folder tree very soon.
free-complete-recovery-5.gif4. After the lost files are found on this freeware for data recovery, you can preview it to check the file quality. Select the files you want recover to save them to a safe place.
free-complete-recovery-6.gif5. The lost files are back to your hard disk now.
The freeware for data recovery is the easiest and most powerful freeware for data recovery. Why not have a try, you have nothing to lose.
Check it out
Jul 28, 2010 | HP Compaq Presario SR1303wm PC Desktop
I have a 30th special edition,,1962,,1992 marshall amp and want to know how to set up,,has jack plug in back,,not sure where it goes,,??
Well if there is anything you need to insert into the effects loop IE, wah pedals, noise gates etc etc the return is the output of the effect and the send would go to the input of the effect. As far as inputs those are all on the front panel.
Jan 08, 2010 | Marshall Amplification Marshall MG250DFX...
Edit saved image
you'll need to use an image editing program like paint shop pro or photoshop...look through the software that came with the scanner or you can download shareware/freeware image editors from places like www.download.com or www.jumbo.com
on actually editing the image ach program will do things in slightly different ways so you would really need to follow the help section in the program itself
Dec 12, 2008 | Umax Astra 2000U Flatbed Scanner
705 people viewed this question
 Grubhead
Grubhead
