Water level knob is broken
The knobs are terrible. The one that adjusts the amount of water is broken. We looked at it and there was a piece of plastic broken off, don't know where from. We tightened it and that only helped for a day.
  • 975 Answers
Write down the brand & model of washing machine , and go to an APPLIANCE PARTS SHOP , Im sure you ll find the replacements. thanks AJ
Posted on May 08, 2009
Water level knob won't turn
Karen, can I get the model number of your washer? If this is a top loading model with the water level switch on the left side of the console, there is probably a plastic piece inside the switch that has broken and it will need to be replaced.
Dec 22, 2014 | Washing Machines
Users manual for admiral atw4475xq
ATW4475XQ - Admirial Water Saver washer - Adjust Rinse cycle water level
The rinse cycle water level can be adjusted. Unplug the machines power.
You can youtube a video on how to remove the top control panel, its just 2 screws on the back of it,
phillips head. Swing the control panel up, and find something to support it so you have both hands free.
(http://www.youtube.com/watch?v=MYn0_qCFdec)
You'll see a clear plastic tube coming up from the back rear like 3/8 in diameter, to a "T"
connection. The one that goes to the left, thats the wash water level switch it connects to. The one you
can adjust, large, medium, small, from the front of the panel . The other off the T goes to the rinse
water level switch. There is not a knob to adjust it. But if you look at the bottom of the lever
mechanism/cam pickups of both switchs, you will see that they are the same. Rotate the wash load size
(knob on outside of control panel) from small to large, back to small, notice how the mechanism changes?
The rinse water level swtich acts the same way, although it is only a 2 position switch, small and
large. Once you watch the wash level mechanism move from rotating it back and forth a few times, you
should be able to see how to rotate that same mechanism on the rinse switch 1 click. It will click into
place, there are only 2 positions as I said and from the factory its in small, so once it "clicks in"
dont go any further. I did mine with a very small screw driver without removing the rinse switch.
Once you get that hidden switch turned to the other position, put it back together, fire it up and now
your rinse is the large level, all the time.
NOTE: There is a white plunger out of the end of each switch with a screw located in place. Dont mess
with the screw or that plunger. As you adjust the lever mechanism/cam this adjusts the amount of that
plunger sticking out, which changes the pressure pickup for water level.
May 17, 2012 | Admiral Washing Machines
I have an admiral washer atw4475xq can you adjust the water level on the rinse cycle
Pulled this together from a couple of Solutions & added some helpful tips I found as I successfully changed the rinse cycle water level!
Nov 14, 2011 | Admiral AW22 Top Load Washer
How can I adjust the shower knob to produce hotter water then it does now. It used to be hotter. Taking the knob off reveals a white piece of plastic with a colder to hotter temp. gauge. How can I adjust...
Should be able to adjust clockwise or counter clockwise to adjust the temp. You said that the temp used to be hotter. Check the temp setting on your water heater. Did you replace your old water heater? Hope this helps.
Mar 07, 2010 | Home
Super low water level in bowl decreases after flush refills
First, fyi, adjusting the knob? in the tank, or the fill level will not increase the amount of water in the bowl. The bowl fills to a certain point, and then as more water is added it starts to go over the built in trap, and down the drain. When you flush the toilet, all the water in the tank dumps into the bowl, and the existing water is pushed over the trap and down the drain. All of this being said it sounds like you may either have an internal crack, between the bowl and trap; you may have a crack that is draining under your toilet, (water spots?), or you have a more serious plumbing issue, improper venting, which is causing a vacuum, and pulling the water out. Hope this helps.
Jun 16, 2009 | Jacuzzi Bath Perfecta EZ33 959 White round...
My Hoover 550 wil not stop filling with water
Possibly caused by a leaking water level sensor. Turn off the power, remove 3 screws at top back of control panel. Rotate the control panel forward and have a look at the white rubber hose on the left hand side. Check that it is connected at both ends and not perished. Also check that the adjuster cam (turn the level knob and look behind) is not broken.
May 01, 2008 | Hoover Washing Machines
Kenmore 70 Series heavy duty washing machine
Kenmore
remove edge decore trims from left and right side front of control panel
remove phillips screws from bottom corners of contol panel
remove knob from water level selector
raise control panel ~1 inch then flip over backwords on pivots
depress lock tab on righ/underside of water level control body where it touches metal mount plate
rotate water level control body 90deg anticolckwise
pull body off
top side of body next to knob shaft is 1/8 hex head bolt
turn clockwise to rais water level
anticlockwise to lower water level
machine can be operated with this part not fitted so can check level. fill, adjust screw, fill will start again, adjust screw, until water level is correct
reinstall in reverse order
Mar 01, 2008 | Kenmore 22422 Top Load Washer
Washing Machines Logo
192 people viewed this question
Top Washing Machines Experts
