Question about Cameras
NEED MANUAL FOR KODAK EASYSHARE C182 - WILL NOT PRINT MANUAL
I NEED MANUAL TO FIGURE OUT WHAT TO DO
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Cameras Master
  • 102,366 Answers
    Top Expert:
  • Cameras Master
  • 6,702 Answers
You also can try to tell here what is wrong and what you want.
I'm not sure the manual you can find online (see one other message from me) can be printed. Most of the time you can print a manual, with adobe acrobat reader (the programm is for free all over the net) you can read it on the computer. You also would need the acrobat reader to print a PDF file. Most manuals are in PDF format.
Posted on Nov 25, 2013
4 Suggested Answers
  • 11967 Answers
SOURCE: kodak easyshare c182 lens error 111
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Apr 13, 2010
SOURCE: how do i turn the volume up on my kodak easyshare
There is no sound play back on videos until they are loaded to a computer.
Posted on May 27, 2010
  • 3 Answers
SOURCE: when I watch a video on my Kodak easyshare c182
First, try pushing the UP arrow on your curser to see volume bar increase on video display. There's really not much in the way of speakers on the camera so you have to listen CLOSELY in a quiet room. The louder the sound during recording, the louder during playback, and vice versa. When transferred to a computer, you will have more control over loudness, especially since you will have ACTUAL SPEAKERS amplifying the sound. Good luck!
Posted on May 30, 2010
Need to restore the manual for a C182 Easy Share camera
First the manual in pdf format can be found here:
http://resources.kodak.com/support/pdf/en/manuals/urg01042/C182_UG_GLB_en.pdf
and saved to the computer for future reference.
An extended user guide can be found here:
http://resources.kodak.com/support/pdf/en/manuals/urg01041/C182_xUG_GLB_en.pdf
I am not quite sure what you mean by "printers for the camera". Printer drivers would normally be on the computer and you would print from there. The manual however mentions "pictbridge" direct printing and I don't think you need a separate driver for this, just connect the camera and printer with the appropriate USB lead and control the functions from the printer's control panel.
Another way of printing is from the EasyShare programme supplied on the original disk that came with the camera. This programme is no longer available for download from Kodak.
Cheers
Nov 17, 2014 | Kodak Easyshare C182 12MP Digital Camera
Purchase manual for kodak easyshare c182
If you'll settle for free, you may download the user guide here and the extended user guide here.
Dec 16, 2012 | Kodak Easyshare C182 12MP Digital Camera
Please note I need a manual for my Kodak C182. Would it be possible to email me info. Thank You.
I'm glad to assist you in providing the manual for the Camera.
Please click hear to download the Manual
Please let me know if you require any clarifications.
Apr 12, 2011 | Kodak Easyshare C182 12MP Digital Camera
How do you get the date to stamp on the photos on a Kodak EasyShare C182? Thank you, Rene
The date and time (and a lot more) are stored with every picture in its EXIF metadata. Any photo viewing/editing program should be able to display this data. To print this data, please consult the documentation for whatever program you're using to print your pictures. Depending on the program and printer you may print the date on the image, in the margins, or on the back.
Nov 24, 2010 | Kodak Easyshare C182 12MP Digital Camera
Will the Kodak EasyShare c182 allow me to put a date stamp on my photos when I download them to my computer?
The date and time (and a lot more) are stored with every picture when taken, and the data will remain with the image through the transfer. If you want to print the date on the picture, please refer to the documentation for the program you're using. Depending on the program and printer, you can print the date on the image, in the margins, or on the back.
Nov 10, 2010 | Kodak Easyshare C182 12MP Digital Camera
Where can i find c-182 users manual on line ?
User guide:
http://support.en.kodak.com/app/answers/detail/a_id/19176/kw/c182
Extended user guide:
http://support.en.kodak.com/app/answers/detail/a_id/19173/kw/c182
Nov 05, 2010 | Kodak Easyshare C182 12MP Digital Camera
We need a manual for Kodak easyshare C182
Here is the online guide/manual for the camera:
kodak c182
Hope this answers your query.
Regards
Anand
Mar 25, 2010 | Kodak Easyshare C182 12MP Digital Camera
I need a manual for the kodak easyshare c182 12mp. can u help me. u can sent it to me in my e mail
You can download one from the manufacturer's web site at http://www.kodak.com
Simply go to the Help Center and select your camera.
Feb 06, 2010 | Kodak Easyshare C182 12MP Digital Camera
Cameras Logo
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
