Question about Ingersoll Rand Stationary Air Cooled Rotary Screw Compressor 10 Hp, 35 Cfm At 125 Psi, Model# Ep
AIR END problem is occurs high pressure inter cooler ararm?
Really they have hidden button ?
Posted on Dec 16, 2013
  • Muzammal Baig
    Muzammal Baig Dec 17, 2013
    yes they have two hidden buttons one on the right and the other on the left side
Hi I have an 08 vw jetta 125 tsi the turbo doesn't
I would check the pressure blow off valve to see if it is stuck partially open. check hoses for holes or leaks where clamped. Also if you have a inter cooler for this turbo check it for cracks or leaks a pressure check of air to the cooler then spray with soapy solution to look for bubbles no bubbles after cooler good.
Sep 17, 2014 | 2008 Volkswagen Jetta
Please help!!! my IRN55K-OF-N55 alarm "high intercooler press"
Your problem is valve discharge closed, so the pressure cannot out from inter cooler.
Apr 07, 2014 | Ingersoll Rand IRN7H-115 Nirvana...
How do remove the pressure ,before you add r34 cooler
you never work from the high pressure side of an a/c system. EPA requires it to be recycled, freon is removed using a vacuum tool on the low port until the system holds vacuum for 5 minutes. Then the recycler is removed and freon is added. You mean R134 right?
Aug 20, 2012 | 2001 Volkswagen Beetle
My 185 ingersol compressor runs fine for 30-45 minutes, then it cuts off. If I wait 10-15 min it will crank and run for 3-5 minutes then shut off. I have all new fuel filters. What do you thibk could be...
From your description I think you are shutting down on high air end temperature. I recommend the following, Check the oil cooler. you want to make sure you are getting good air flow thru it. If not wash it with a pressure washer. I like to use my flash lite to check and make sure I can see thru it. dont look just at the middle check around the sides. If cooler is OK next check the amont valve (thermostat valve). This valve mixes oil from the cooler and bypass to get the temperature where it needs to be so condensate does not form in the oil. Next you may have a bad HAT switch which is located on the end of the air end. If you have a meter see if the switch opens when you have the shut down. you will need to make sure you really don't have a high temp situation. If the temp is high 228 F or higher the switch is doing its job. The temp limit should be located on the HAT switch. It could be 215,245 etc. If the unit is not hot and the switch opens replace the switch. Hope this helps you with your compressor problem.
Aug 02, 2011 | Ingersoll Air Tools & Compressors
SSR-EP75 Ingersoll Rand SERIAL # F15525U95286 320 CFM i CONTINUE TO ADD OIL GOES OUT ON HIGH AIREND TEMP. SOMEONE TOLD ME THERE WAS AN ADJUSTMENT FOR THIS. CAN YOU TELL ME WHAT TO...
Mike, an EP 75 Should not use more than 3 to 5 parts per million of oil. Your oil issue sounds like you have a separator that needs replacing or a plugged scavenge line. The separator is located in the oil tank. the scavenge line and orifice come from the bottom of the separator filter to and Thur the oil tank lid. then to the air end. In this line approx. 1ft from the lid should be the orifice. make sure its clean. your high air end temp can be from several different problems. 1- low oil level from separator or scavenge line plugged. 2- A plugged oil cooler. Dirt and debris pushed against the cooler by the the cooling fan. This needs to be cleaned using a pressure washer. Wash in the opposite direction of air flow. Be careful with the pressure washer. You can damage the cooler. Low oil level and dirty coolers are the most common problems when getting high air end discharge temp shutdowns. However you could also have a bad thermal valve located where the three cooler lines come together. you will have to remove one line and 4 bolts. inside is the thermal element. You may also have a bad HAT switch (high air end temperature). It is located in the end of the air end and simply unscrews. I do not know of any adjustment.
Feb 12, 2011 | Air Tools & Compressors
1.6 hdi when i rev the engine it sucks the rubber pipe in from the intercooler and will splutter and wont rev past 3000 revs?Thanks.
I'm not very conversant with your vehicle, as we have few where we are, but there are certain parameters to follow. First I would check for a restriction in the inter cooler or the air cleaner. The element may have become very contaminated.
  • Open the air cleaner and try the engine with the element removed.
  • If that doesn't work it will mean removing the inter cooler and checking for a restriction inside it.
  • The inter cooler unit is usually fixed with four five or six bolts.
  • It will also have an electrical connection for the cooling fan.
  • disconnect the fan at the socket provided.
  • Remove the clips for the rubber ducting and ease them off from the inter cooler.
  • Check the work outlined above
  • Your vehicle is a diesel powered, so if it's required to clean out the inter cooler unit, do not leave any water inside, as water can damage the engine, even breaking pistons.
  • Water is non compressible. The water won't accommodate the pistons, or rings, not even the cylinder head, each will bend shatter or break to accommodate the water.
The last suggestion is to replace the ducting as these may have become weak, but I doubt that.
Best regards Johngee10
Oct 26, 2010 | 2005 Peugeot 405
My 96 850 Turbo has a issue related to the intake tube directly off the top on the inter-cooler. In colder conditions (0deg or lower) it will collapses the hose (like the engine is trying to in more air...
if you do by pass it i would leave the turbo in operation and just remove the hose of the inter cooler and put a air filter in place of the inter cooler.
Dec 18, 2009 | 1996 Volvo 850
We have 30 gtc model air cooled chiller problem is water intered in the compressor but we opened the cooled and given the pressure to the cooler but there is no leakage in the cooler then from water is...
you are going to have to try to dry out the refrigerant by replacing the drierd and pulling a good revaucuation on the unit after you replace the drier that are in the refrigeration lines .
Mar 21, 2009 | Carrier BM23S-2 Refrigerator Beverage...
Air compressor won't build pressure
If this unit has what appears to be a pipe with fins on it , you may have a ruptured inter-cooler which will be leaking where you stated.
Mar 07, 2009 | Air Tools & Compressors
Just a query; about installing an air inter-cooler
i`ve worked on inter coolers fiddly but not impossible . my tip would be take the old one out then put it back in . a little practice before fitting the new one.joe
Nov 21, 2008 | 1997 Toyota Land Cruiser
Ingersoll Rand Stationary Air Cooled Rotary Screw Compressor 10 Hp, 35 Cfm At 125 Psi, Model# Ep Logo
496 people viewed this question
Top Ingersoll Rand Tools & Hardware - Others Experts
elunsford
Phil Walker
Phil Walker
Are you an Ingersoll Rand Tool and Hardware - Other Expert? Answer questions, earn points and help others
