Question about Toshiba Satellite C655-s5090
Toshiba laptop won't power ON
Ok folks i really need your help here....i have this Toshiba c655 and when i try to power up it does not work,the power led lights up and CD-ROM opens but fan does nothing....i removed the battery and hold poer down for about 2minutes and i tried a different RAM,i also took off the processor and refix it but still nothing....pls help
    Top Expert:
  • Toshiba Master
  • 26,210 Answers
Did you run a bios updateand has an anti virus programme installed? If you did the bios is corrupt and stopping the system from running.
I would remove the RAM and Hard drive. Power up without the battery and look for error messages on the screen. Ensure the RAM is correct and place one strip in at a time.
Posted on Nov 25, 2013
Testimonial: "Thanks Jon....But it turned out to be a GPU related problem so i did a re-flow of the GPU and the machine is up and running again....thanks for ur quick response,i appreciate it"
4 Suggested Answers
sandrew
  • 2961 Answers
SOURCE: toshiba satellite A60 no boot
We can only assume that because the cd drive operates then the motherboard is operating in part, although, the southbridge chip may be damaged, as the northbridge works memory etc. Maybe it is that the processor is fried as there is no fan and the system then shuts down. Toshiba are probably half way there with the answer, unless; they investigated further and decided it was not the processor but the motherboard.
Posted on Jan 02, 2007
frankzjm
  • 191 Answers
SOURCE: Will not boot up
this is motherboard hardware issue
1) first all you need take out all devices like HDD DVD, wireless card then try turn it on if noting yet
2) change RAM stick that you have done
3) check DC PWM standby status, like 3V/5V/1.8V which should be appear before power on.
if no 3V/5V DC output, check this PWM circuite like MOSFET or PWM chip.
if you find 3V/5V, so need check 1.8V DC output and 1.2V that chip fail also cause nothing turn on.
all steps need diagram check where the chips and componenets on your board.
hope help you something fixed, please take a rating let me know how much helped you thanks! keep in touch your question
Posted on May 27, 2009
  • 15 Answers
SOURCE: toshiba satellite 1005 s157 laptop powers on and then turns off
it could be your ac converter in your laptop.. best bet would be to check the memory, take both the batteries out and try restart it without batteries.. if non of this works i believe it might be your ac con...
success
Posted on Jun 18, 2012
I have a Toshiba laptop model# C655-S5501 with a bad keyboard (Gator Aid!). I can't find an exact model # match through Amazon. Will the "Eathtek NEW Keyboard For TOSHIBA SATELLITE C655-S5128 C655
Check eBay. I've been working on computers for years and order ALL of my replacement keyboards through eBay. I just found 9 of them after entering your model number; about $16 with free shipping. Sarawill82 hit the nail on the head for the replacement; you tube is your friend if you're doing it yourself. If it doesn't have your exact laptop, look at other videos. It will give you an idea what you need to look for to replace the keyboard.
It beats paying a computer store a $45+ bench fee, and it will only take you about 15 minutes as a novice.
Don't try to clean it; you could cause more extensive damage than just replacing the keyboard.
Jan 16, 2015 | Toshiba Replacement Keyboard
Toshiba Laptop Satellite C655 will not power up
Take out the battery and only hook up the AC Adapter into a normal working outlet. Push the power button and if it turns on then you know the battery is bad. If you still dont get the laptop to turn on then either you have a bad AC Adapter or the motherboard is bad and would need to be replaced.
Sep 23, 2013 | Toshiba Satellite C655-s5090 Notebook
Power port not working on toshiba c655
You had better replace your laptop charger. Even if you go to repair it, it will cost you the same price of getting a new charger. So it is wise to purchase a new one. Here are two for your reference:
$9.99 for Replacement Toshiba Satellite C655 AC Adapter 65Watt 19V 3.42A
$12.90 for Replacement Toshiba Satellite C655 AC Adapter 75Watt 19V 3.95A
Nov 03, 2012 | Computers & Internet
Z,/,?,and all four directional keys stopped working on my toshiba satillite c655-5128
The keyboard will more than likely need to be replaced, there are no user servicable parts. Go to www.ebay.com type make and model of laptop, refine search to keyboard.
Aug 31, 2012 | Toshiba Satellite C655-S5140 Notebook
Toshiba satellite c655 hinge replace
If you don't have the experience on disassembly the Toshiba Satellite c650 c655 laptop, we suggest you refer to the official maintenance manual firstly if you have. Here we provide a universal instruction for the reference, some steps may be not the same. If you need a detailed guide or manual, please contact us, we will email you if we have.
1. Please turn off your Toshiba Satellite c650 c655 laptop, disconnect the power adapter and remove the toshiba satellite c650 c655 battery.
2. Turn the laptop over. Remove the screws (may not exist) that hold the Toshiba Satellite c650 c655 hinges on the back of the computer.
3. Remove all the screws (may not exist) that hold the keyboard and keyboard bezel in place, then gently pry keyboard bezel using a flat head screwdriver. Lift the keyboard and unplug the keyboard cable from the motherboard to remove the keyboard. Now, you will see the toshiba c650 c655 laptop fan
4. Detach both hinge covers using your fingers. Unscrew the screws securing the Toshiba Satellite c650 c655 hinges to the laptop base.
5. Locate the screws on the LCD, pry the rubber screw seals using a flat-head screwdriver. Unscrew the screws attached under the seals. Remove the screen bezel.
6. Remove the screws securing the hinges d to the Toshiba Satellite c650 c655 LCD.
7. Now, you can remove the old Toshiba Satellite c650 c655 Hinges by sliding them out. Insert the new hinges in their correct place. Reverse the above procedure to assemble the laptop.
Mar 11, 2012 | Toshiba Satellite C655-S5068 Notebook
Toshiba Satellite C655-S5082. Won't power on. Worked fine last night. Today it won't turn on. Plug it it and no power light. With power cord plugged in when I push the power button the light for...
Hi.
Take out the AC power jack and then remove the laptop battery. Plug AC power back in and see if the laptop will turn on. If it turns on let it boot the operating system and then shut down as normal, remove the power cord and reinsert the battery and again see if it will switch on. If it does then there has been a glitch with the battery. If it doesn't then there is a problem with the battery.
If the laptop won't switch on either with or without the battery then there is a possibility that the motherboard has developed a problem.
Good luck.
Jul 16, 2011 | Toshiba Computers & Internet
Fpi need a webcam for my laptop c655 toshiba which one will i buy that will work with it
Hello fpat2479,
The C655 does not have a webcam built into its LCD bezel (case). But there are many webcams that should work on the C655. The TigerDirect.com website offers many webcams in a variety of price ranges. Most of these should work ok on the Toshiba C655:
http://www.tigerdirect.com/applications/category/category_slc.asp?page=2&Nav='c:6911'&Sort=4&Recs=10
If this solution is helpful please click a thumbs-up rating.
Have a great day,
martyshaw152
Apr 26, 2011 | Toshiba Computers & Internet
Keyboard inoperative
press and hold fn and press f11.it sounds like you activated the sticky keys
Nov 22, 2007 | Toshiba Satellite A135 Notebook
Toshiba Satellite C655-s5090 Logo
49 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
