Question about Acer Scan to Web 3300U Flatbed Scanner
Scanner acer do not work for win7 - Acer Scan to Web 3300U Flatbed Scanner
Mustek 1200cp driver for win7
Such is the problem with many products for Win7. But Win7 64 bit seem to accept such drivers.
Nov 30, 2014 | Mustek Plug-n-Scan 1200 CP Flatbed Scanner
Szw3300 driver win7
Try downloading a scanner driver from the Acer WEB site.
If Acer does not have a Windows 7 driver for this model then you may be able to get one from this WEB site.
VueScan 9 scanner driver - compatible with over 1750 scanners
http://www.hanrick.com/
Dec 10, 2011 | Acer Value Scan to Web 3300U Flatbed...
Need a driver for Visioneer OneTouch 8700 Flatbed Scanner
The drivers for supported OS versions are available here: http://support.visioneer.com/products/8700/downloads.asp . The supported OS versions are: Windows XP SP 1 / 2000 Professional / Me / 98SE and the additional software that was bundled on the CD is not included.
If you have a different Microsoft OS, you can check the Microsoft compatibility center for either Vidat or Win7. A check of the Win7 compatibility Center http://www.microsoft.com/windows/compatibility/windows-7/en-us/default.aspx showed some Visioneer OneTouch scanners work with Win7. However, the 8700F is not in the list.
I hope this helps.
(Dual boot with XP or a virtual computer with an older valid OS version will work. The Win7 Pro and Ultimate let you use Virtual PC and XP mode to run an XP virtual computer for free.)
Jan 03, 2011 | Visioneer OneTouch 8700 Flatbed Scanner
I have a CanoScan LiDE80 that wont work now with my new operating system, Windows 7...when trying to install it.. says I need drivers but can't find compatiable one??? Any suggestions as I love this...
Do you have Win7 32-bit or 64-bit? If you have the 32-bit, the driver you need is here: http://www.usa.canon.com/cusa/support/consumer/scanners/canoscan_series/canoscan_lide_80#DriversAndSoftware . This driver works for Win2K-Win7. This is an unsigned driver and probably will not work in Win7 64-bit.
In my experience, Canon is very poor at supporting their scanners for 64-bit OS versions. In fact, they do not have a Vista 64-bit compatible version of the drivers for this scanner.
The only solutions I have found are tedious. 1) Keep your old computer that works with the scanner and transfer files on a USB drive or optical disc (RW is better for this). 2) Set up a virtual computer with an OS that works with the scanner. If you have Win7 Pro or Ultimate, you can do this for free. Download Microsoft's Virtual PC and the XP mode package. Install both in order. For other versions of Win7, you will need a virtualization program (Parallels, Virtual PC, VMWare) and a licensed version of XP (or other OS that will work with the scanner). Set up the virtual computer program and install the OS.
Next install your scanner to the virtual computer and use it in that "machine". You may need to transfer files to external or optical media to share the documents. You can't install a printer on both the virtual computer and the real computer at the same time (at least with XP mode).
I hope this helps.
(I tried using the compatibility mode and accepting the unsigned driver for a Win7 Home Premium 64-bit machine for a different Canon scanner. It didn't work and I have dealt with a number of old hardware and new OS issues over time.)
Dec 01, 2010 | Computers & Internet
I need a driver for lide80 canoscan scanner
What OS do you have? The drivers (supported OS versions) for the LiDe 80 are available here: http://www.cusa.canon.com/cusa/support/consumer/scanners/canoscan_series/canoscan_lide_80#DriversAndSoftware . If you have Win7 64-bit, the Vista x64 driver doesn't work even in the compatibility mode.
If you want a work-around for the 64-bit OS, Win7 Pro and Ultimate allow you to download and install XP mode free. This takes two programs, Virtual PC and the XP mode, that you download from Microsoft and install. This will run a virtual computer under Win7 and you can install the scanner to the virtual computer. To share files with the real computer, you should store them on external media.
Alternatively for Win7x64, you can install any of the other Virtual computer programs (Parallels, VMWare, etc) with a licensed older version of Windows. Then do the same as above. Another option is a dual boot computer with the older licensed version of Windows with the scanner installed to the "machine" with the older OS. I don't see a Unix driver for this scanner so you need a valid copy of Windows.
I hope this helps.
(If you have Win7 x64, the only other options are 1) to try and get Canon to extend their drivers (since they do support Win7 32-bit) or 2) get a new scanner.)
Sep 15, 2010 | Canon CanoScan LiDE 35 Flatbed Scanner
Driver for Flatbedscanner22 for OS windows 7
About Agfa Snapscan E25:
Agfa discontinued its DTP scanner product line (SnapScan, DuoScan, Horizon and Arcus range) and digital cameras (ePhoto, ActionCam, StudioCam) at the end of 2001. At this page is the link for downloading the last valid drivers for your scanner, supporting up to winXP. Try, if you are lucky it may work with Win7
About Acer Aspire 3050:
This laptop has no drivers for Win7 (that's what acer says, not me). Here is the last driver for your camera supporting up to Vista.
In my opinion try the latest drivers that I send you, since there is nothing to loose.
In case of a problem or clarification, don't hesitate to post.
Thanks and regards
Please kindly rate this solution
Stelios
Feb 25, 2010 | Agfa SnapScan E25 Flatbed Scanner
Acer Scan to Web 3300U Flatbed Scanner Logo
15 people viewed this question
Top Acer Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
color wheel light...
Are you an Acer Office Equipment and Supply Expert? Answer questions, earn points and help others
