Question about Air Tools & Compressors
How do i reverse rotation on a dayton model 5k675k compressor motor?
2 Suggested Answers
  • 1388 Answers
SOURCE: Hi. I have a Dayton Air Compressor, operated by
I have a similar compressor from grainger. Same motor as yours with 10hp speedair compressor, however a newer model. The graninger number of my pump is 5z405. and can be seen at the link below:
http://www.grainger.com/Grainger/SPEEDAIRE-Two-Stage-5Z405
If your pump looks similar then contact grainger and ask them for info relating to your serial number. Every time I call grainger for info or parts, they ask for the grainger number of the complete unit. These pumps do not change much over the years so maybe the info above will be helpful. Good luck
Posted on Mar 29, 2011
Reversing a Dayton motor model # c286c1 motor
electric motor reversal requires the field winding to be reversed
this is best done by an electrical motor repair electrician as not getting it right can burn the motor out
Nov 26, 2017 | Dayton Heating & Cooling
How to reverse a model c286c1 Dayton 3/4 hp 115 230 v motor
https://www.grainger.com/category/hvac-motors/motors/ecatalog/N-9xz?okey=DAYTON+MOTORS&mkey=DAYTON+MOTORS&refineSearchString=DAYTON+MOTORS&NLSCM=17&EndecaKeyword=DAYTON+MOTORS&searchRedirect=DAYTON+MOTORS&sst=subset&cm_mmc=PPC%3A+Yahoo+Supplier-_-DAYTON+MOTORS%26gt%3BDAYTON+MOTORS-_-DAYTON+MOTORS%26gt%3BDAYTON+MOTORS%26gt%3BBroad-_-DAYTON+MOTORS
I’m happy to assist further over the phone at https://www.6ya.com/expert/david_dc2f9e0a44104720
Nov 25, 2017 | Dayton Dryers
Can I reverse model 9k322j Dayton motor and how
There should be a nameplate on the side of the motor.Look to see if it is reversible. The motor is a fairly heavy duty and more than likely is reversible.
Mar 05, 2015 | Dayton Dryers
I have motor dayton model 9ncg4 now the wire is110 conected i need to conected 220 i need the diagram
I reversed start winding to reverse motor now it runs the right direction but it keeps starting instead of running smooth
Sep 27, 2012 | Dayton Wire Wheels Motor 2 HP 3450 230 V...
I installed a Dayton 4m205j condenser fan motor. It comes on but turns the wrong way. I switched the wires and it still turns the wrong way.
From what I can find on the internet, there should be a plug very close to the motor body that can be reversed to reverse the rotation of the motor. It should be a small rubber plug on the wires leading into the motor.
Also, check inside the wiring compartment for a sketch or notes.
Gary
Aug 15, 2011 | Dayton Permanent Split Capacitor Motor Fan
HOW DO YOU REVERSE THE ROTATION ON A DAYTON 6XJ04 MOTOR?
If the motor is reversible, you will have 4 small leads that have pigtails that will connect to eachother to make the circuit. Usually they are 2 colors and you will either hook up the matching colors for CCW or opposite colors for CW. If you do not have these leads, you will more than likely have a non reversible motor. You can also look at the data plate on the motor itself and it will tell you the rotation. If it says REV. then it's reversible. Hope this helps and good luck!
Jul 05, 2011 | Dayton Heating & Cooling
How to rewire dayton 2m034 to change rotation from CW to CCW.
Check and see if there is a plug with 2 wires coming out of the motor, connected through the plug to two other wires. Reversing the orientation of the plug should change the rotation.
--W/D--
Jan 24, 2011 | Dayton Permanent Split Capacitor Motor Fan
. How do I wire this for forward and reverse use
you can reverse the rotation CCW to CW if you reverse the wiring on the brushes
Jan 09, 2011 | Dayton Universal Ac/Dc Open Motor 1 Hp...
What does line and tape mean dayton motor
L 1 is power in .L 2 is also power in.line means this is were the power needs to be hooked to . cw / stands for clock wise rotation . ccw stands for counter clock wise rotation.
Sep 28, 2009 | Air Tools & Compressors
Air Tools & Compressors Logo
85 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
