Question about Canon FAX-JX200
Whenever i send a fax, the machine confirms by viewing 'TRANSMITTING OK' but the addressee receives a blank document
My fax machine successfuly transmits a document however, when i confirm if the document is clear and readable, the addressee receives a BLANK document.
  • 52 Answers
Check the baud rate of your transmissions. Slow them down to the slowest setting and send a test fax to a helpful person. Slowly increase the baud rate (communication data speed) and send the fax test. When the fax doesn't show up on the receive site, then step one baud rate speed back, and save the setting.
It could also be your fax that is faulty, or even the receive sites fax, also being faulty.
To test your copy-head, insert a document into your loading section of the fax and press copy. If the copy prints out fine, then you know the head is reading correctly.
It is also possible that the receiver fax (the other end) has a printhead failure.
Posted on Nov 26, 2013
  • 990 Answers
SOURCE: Fax comes out blank at the receiving fax machine.
Hello sir; I suggest you to replace a phone wire should be take care the problem.
Posted on Feb 03, 2009
POCBM
  • 121 Answers
SOURCE: Need fax confirmation
Not an expert on this model however, on most canon fax machines the plastic cover or panel on the keypad is a door. Opening this you should see descriptions for the keys one should say report. Press report to print and follow instuctions to get activity report.
Hope this helps
Posted on Mar 14, 2009
iservice
  • 318 Answers
SOURCE: Confirmation for a fax that is being sent
Press the menu(dataregistration button) go to report settings under Fax settings edit TX report,change it to - output yes.
Posted on Sep 11, 2009
SOURCE: need fax confirmation
change the tx report to yes>then tx manual sending .good luck
Posted on Sep 21, 2009
canontech
  • 1219 Answers
This type of fax is "toy" buy a laser fax an get rid of all your problems
Posted on Jan 12, 2010
Sharp FO-4700 Fax Not Received Even Though OK Fax Confirm Given
It's gone forever, once your machine received a EOT (end of transmission signal), your fax machine thinks it was received OK and clears it from memory.
Oct 28, 2009 | Sharp FO 5700 Plain Paper Laser Fax
How do i set up the fax to print a confirmation sheet when it sends something?
Try this:
Press the Setup button (it might be the sign of a monkey range)
  1. Press the Down arrow (c00844971.gif ) to highlight Print Report , then press OK .
  2. Press the Down arrow (c00844971.gif ) to highlight Fax Confirmation , then press OK .
  3. Press the Down arrow (c00844971.gif ) to select one of the following options in the table below, then press OK
On Fax Send Prints a fax confirmation report for every fax you send. On Fax Receive Prints a fax confirmation report for every fax you receive. Send and Receive Prints a fax confirmation report for every fax you send and receive. Off Does not print a fax confirmation report when you send and receive faxes successfully. This is the default setting.
Select the one you would like to choose ;
For further help click on the following Link:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01083680&cc=us&lc=en&dlc=en&product=3204785
Regards Soumajit
Sep 21, 2009 | HP Photosmart C7280 Laser Printer
I am having trouble faxing documents. Whenever I
Hi, you can check that your phone connection from your 7420 to line works. Listen for a dial tone in a phone connected to your mfc7420. If not, your tel comm module could be at fault.
Jul 08, 2009 | Brother MFC 7420 All-In-One Laser Printer
''Document Jammed'' error message
Open the document feeder and look for a switch actuator stuck in the down position.
Nov 19, 2008 | Panasonic KX-FL511 Plain Paper Laser Fax
Confirmation page
You can configure your HP all-in-one so that it automatically prints error and confirmation reports. If you need printed confirmation each time a fax is sent, follow these instructions before sending any faxes and select Send Only. To set automated report options from the control panel Press Setup. Press 2, and then press 1. This selects Print Report and then selects Fax Report Setup. clip_image001.gif Press to scroll through the following report types: Every Error: prints whenever there is any kind of fax error (default). Send Error: prints whenever there is a transmission error. Receive Error: prints whenever there is a receiving error. Every Fax: confirms every time a fax is sent or received. Send Only: prints every time a fax is sent indicating whether the fax was successfully sent or not. Off: does not print any error or confirmation reports. Press OK to select the report.
Jul 29, 2008 | HP OfficeJet 6210 All-In-One InkJet...
Fax mystery
I am having the same problem as you. I think that we need to activate the confirmation sheet but i dont know how to do it. Did you fix it ???
Thanks in advance,
_ting_
Jan 21, 2008 | Lexmark X7170 All-In-One InkJet Printer
Faxing problems
if you put the document in right direction(face up or face down)-your scanner unit may be out of order or unpluged firmly into the main board socket check it and reinsert scanner unit plug again.
Jan 10, 2008 | Panasonic KX-FB421 Plain Paper Film Fax
Canon FAX-JX200 Logo
192 people viewed this question
old marine
old marine
