Question about Audiovox Vehicle Parts & Accessories
How to disable audiovox car alarm
Hve tried everything to disable alarm. even keychain disarming button does not work.how to uninstall system
  • 33 Answers
SOURCE: How do I disarm a audiovox prestige car alarm?
Locate the valet/override switch (button), (if you can't locate it, try tracing the wires under the dash from the main unit, usually a black and gray or black and red set of wires). Turn key to "RUN" position then press the button, the alarm's LED should light up solid at this time indicating valet mode as been set.
Posted on Jun 20, 2009
SOURCE: need to disarm the alarm because the remote is not
i have an 02 WRX my alarm keepes going off and i cant start my car and it keeps honking and honkin this viper system cam with the car n there is no button to press my blue button is flashing n my car is honking loud ! help! RPN 473V
Posted on Oct 10, 2009
  • 151 Answers
SOURCE: I have an Audiovox Car APS95BT3 Transmitter with 3
here is a link that should help you.
http://audiovox2.info/docs/voxx_mob/man/APS95BT3_DOC_TPG.PDF
Posted on Dec 28, 2009
  • 171 Answers
SOURCE: disable viper alarm
Yes the best way is disarm the alarm and put in a Valet Mode
To activate the Valet Mode do the following:
There is a push button or toggle switch to disable the alarm (to engage the valet mode). Without knowing where this
switch is you won't be able to disconnect the alarm.
1. Put the key in the ignition and turn it to the "on" position.
2. Flip the toggle or hold the push button for at least 5 seconds.
3. The LED. light will stay solid on.
4. Turn the ignition off
5. Release the push button. If you have a toggle leave it alone in step 2
Posted on Jan 08, 2010
  • 11 Answers
SOURCE: Audiovox Pursuit Pro keyfob reprogram
if thats the picture of the transmitter to program it you have to : turn the ignition to on position. press and release the programming switch 3 times... press and hold,for 3 seconds, the buttonof the transu wish to add until the parking lights flash. this would mean the transmitter has been learned. repeat step 3 for each transmitter... turn the ignition off to exit the program mode..
do not let 15 seconds pass between steps.
Posted on Jul 26, 2010
Security system disarm
call the dealer and they will walk u through on dis arming the alarm
Jan 18, 2014 | Shock Sensor AS94904P
I have the Audiovox CA425 remote start and keyless entry system and had service done on my vehicle. The door locks and auto start and alarm all worked perfectly. The auto shop disconnected the battery and...
Usually it`s happens with any alarm system when you disconnecting the battery, try to put key in the door and open manually while alarm on, check the fuses
Dec 17, 2013 | Audiovox Vehicle Parts & Accessories
My security system won't disarm on my 1999 chevy blazer
Is this an aftermarket alarm? If so, first locate the valet switch. It should be a black push button. Next, turn the ignition on, press and release the valet switch. This should disarm you aftermarket alarm. This is the most common manual disarm procedure for Directed (avital, python, Automate, Viper) and Audiovox (prestige, pursuit, code).
If this is the factory alarm and, you don't have the remote. Unlock the vehicle using your key in the driver's door.
Aug 16, 2012 | Vehicle Parts & Accessories
How do I uninstall an Audivox 6 tone mini siren from my 2004 Honda Accord. I didn't install this item and now it is always arming itself locking me out of the vehicle!
The siren is merely the part of the alarm that gives you an audible alert when you arm, disarm the alarm. It also alerts you to intrusion and tampering. The siren does not arm itself and lock you out.
Locate your valet switch and turn the ignition on, press and hold the valet switch, count to five and release. the unit will be in valet at this point. Locate the model number and report back for the instructions to disable the passive arming.
Aug 12, 2012 | As9903 Mini Six Tone Siren For Car Alarm
How to disable or reset a Prestige car alarm. Purchased a used car with an after market Prestige alarm installed. Alarm somehow tripped and shut off the ability to start the car. I can't find a valet...
The valet switch,on the newer Prestige alarms, is a push button LED or, it's incorporated into the antenna. In both cases, turn the key to the on position, then press and release the valet switch. The alarm will respond with two chirps confirming that it is disarmed. You may now start the vehicle. After you successfully disarmed the alarm, turn the key to on position, press and hold the valet switch for approximately 5 seconds, the LED will come on solid. Turn the key off.The alarm is now in valet. You can take it out of valet in the same manner.
Oct 28, 2010 | Audiovox Prestige Code Alarm Remote Alarm...
Transmitter no signal
check you setting or rest and start programming over
Jul 01, 2009 | Vehicle Parts & Accessories
Jun 14, 2009 | APS20B Prestige Keyless Remote Alarm
Vehicle Parts & Accessories Logo
71 people viewed this question
Top Audiovox Vehicle Parts & Accessories Experts
xxxxxx xxx
Glen Weitzdoerfer
Are you an Audiovox Vehicle Part and Accessory Expert? Answer questions, earn points and help others
