I have a Element Electronics 40' LCD ELDFW407 . IVE HAD IT LESS THSN A YEA. YHE TV JUST WENT BLACK WHILE WSTCHING IT & I HAVEN'T GOTTEN IT TO TURN BACK ON. HELP
4 Suggested Answers
  • 4234 Answers
SOURCE: LCD TV blows fuses
Since the main fuse is being effected, it suggests that there is a major problem in the power supply section. I would be looking for a shorted rectifier diode. If you have any experience with electronics, you may be able to locate this problem. If hte set is still in warranty, return it for warranty service. If not, try loking for burned components etc.
Dan
Posted on Jul 22, 2008
SOURCE: Element flx-3210 lcd tv
I have an element lcdtv 32inch. The tv is less than a year old, i was watching the tv and it just shut off. The red light is on, when i go to power it up, the blue light comes on for a second then blinks, and goes back to red. I know its not a brand name tv, but for 600 bucks, it should last for more than 8 months. Anyone have any advice ?
Posted on Oct 31, 2008
SOURCE: Element Electronics FLX2211B 22 in. LCD TV will reset every time
I have run into the same problem with a different model (32 inch from Circuit City). You may have found that there is almost no support from the co or web. I do not have an official solution but have some work arounds that have done the job for me.
WA#1 = after a channel scan tune to a HD/digital channel before you turn the set off. You need to do this each time for several times, because the set when turned on to a regular cable or analog station will default to skip all channels. After several times the set should remember your channels.
WA#2 = after a channel scan, go to the skip channel section of the menu, and if your remote has the colored buttons on the bottom scroll through the channels using the red and green (up and down on this menu) buttons. This apparently helps the set remember not to skip your scanned channels.
These are not glamorous solutions but appear to trick the TV into not re-setting the skip function for the channels.
Best of luck.
Posted on Jun 03, 2009
Can the screen on an Element TV ELDFW407 be repaired?
Yes it can. But are you prepared to pay the price?! Not cheap due to parts and labor.
Sep 09, 2017 | Televison & Video
Element eldfw407 has blue screen only does not get menu or input screenswhat would cause this
Fault to its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Aug 10, 2015 | Element Electronics 40 Class LCD HDTV -...
Code electronics element eldfw407
HDMI white balance settings should be re-calibrated. It is a skilled work. If you wish to get more details, check this site linked below. Pull up older posts there. Check the site with patience, as it has over 2350 posts now. All are related to electronic equipment repair help. If you search the site in Timeslide option, which can be selected from the drop down list at the top left of the display window, it will be easy to locate the related post. You can also do a search by type in the brand name to your device into its search box at the top right of display window. http://electronicshelponline.blogspot.com/
Apr 30, 2013 | Element Electronics FLX-2610 26 in. LCD...
Picture went black
Likely power supply failure, especially with the bad smell
Sep 10, 2012 | Element Electronics FLX-3211B 32 in. LCD...
Code number
hi . you could try ge brand or philips brand universal remote control in code#1173 or auto code search. maybe working your element lcd tv. good luck!
Sep 03, 2012 | Element Electronics Televison & Video
Had this TV for less than 9 months and now all i get when i turn it on is a black screen.
T CON VIDEO BOARD NEEDS TO BE REPLACED. YOU CAN GET IT AT A GOOD PRIZE
AT TVPARTSANDMANUALS. COM
Dec 18, 2010 | Element Electronics FLX-1910 19 in. LCD...
I do not have any sound on my element tv and I have had it less than a year. Please Help!!!
I have the same problem. I went out and bougt a pair of external speakers (computer speakers) and plugged them in the back and listen to the audio that way. It's been over a year and it works great. Good Luck
Sep 06, 2010 | Element Electronics FLX3210 32 in. LCD TV
Element electronics LCD, was on for several hours picture went blank, sound is still perfect. 12 hours later still no picture when turned on, great sound though.
Typically this failure is due to the backlight inverter going out. On this model of tv there were two runs with different parts. Open the back of the tv and open the control box. If you see a large black circuit board on the top, replace that one. If its tan then you need to take out the control box and remove the black plastic backing. If you're looking at the back of the tv the inverter will be on the left side of the control box. Its a long skinny board that has 8 black metal squares on it. Good luck and be careful.
Mar 14, 2010 | Element Electronics FLX3210 32 in. LCD TV
Televison & Video Logo
43 people viewed this question
Top Televison & Video Experts
Electro Med Services...
