Question about Microwave Ovens
Microwave Dead A person was microwaving a squash which blew up in a GE Profile oven model #PEB2060SM1SS and then it stopped working after it was cleaned up. Tripped circuit breaker in house I was told. Checked oven and found 20 A fuse blown. All checks passed on Tech Data Sheet except 5. B. With door both open and closed the resistance measures 0.4 ohms across the power cord line and neutral connections but the way they describe the test makes me wonder if the shorting jumpers are not in the right place. For one thing, they describe the relay without saying which one of the three. I am guessing it's RY2. Is the 20A fuse a slow or fast blow? I thought I would try replacing the fuse if I can get one locally and see what happens. Why would a squash blowing up cause the 20A fuse to blow? Would it maybe cause one of the door interlock switches to operate and then blow the fuse? I see that the Tech Data Sheet says that when the fuse is blown, that the monitor switch and primary interlock switches must be replaced. That's poor design if they have to be replaced just because the fuse blows. What are your thoughts? Thanks.
  • Wayne Carpenter Nov 25, 2013
    Thanks for your responses. I am still wondering why a squash blowing up caused the fuse to blow--it's strange. So the oven was actually made by Sharp. No one happened to mention, that I saw, whether the 20 A ceramic fuse is a fast or slow blow fuse. I suppose it may be hard to find one in a small rural area.
    Thanks.
  • Microwave Ovens Master
  • 2,113 Answers
Having 20 year experience fixing microwaves i know that when the fuse goes that if you can't find a melted wire or overheated components on the circuit board that the high voltage capacitor at the back needs to be replaced. Sometimes you have to replace the magnetron too. You can replace the door switches if you like, microswitches are inexpensive but would only be bad if arced inside so bad that you read over 1 ohm.
Posted on Nov 25, 2013
4 Suggested Answers
  • 19 Answers
SOURCE: Ge Spacemaker microwave jvm240 wv Micro hood combo.
sounds to me like the magnatron has shorted out. i don't know of a way to test them unless you have some high dollar equipment. a continuity test prob wont tell you anything. what reading did you get on the cap when you tested it?
Posted on Jan 06, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: Servicer with a PLMV169DCD Fuse blowing Problem
For future reference, we regularly repair such control boards and displays for customers nationwide by mail for $39.95 postpaid in about a week or so with a one-year guarantee.
Here's the main service manual. Other versions are here and here.
It may be grease inside one of the switches or arcing conductors (usually due to opening the door while it's cooking) making it sticky.
This was made by Sharp, so the side panel should come off each interlock switch for inspection.
But looking at the schematic, the monitor switch cannot come into play under normal circumstances unless the door is shut and the secondary interlock (relay RY2 on the control board) is closed and (oddly, if the published schematic is to be believed) if the oven lamp relay RY1 is closed .
Everything seems to point to a bizarre problem like maybe an intermittent short of a wire to the chassis, perhaps where a wire passes through a hole or guide in the sheet metal.
Also, you might consider unplugging the hood vent motor and trying it.
Did you try it with the oven powered from another outlet?
Also be sure the neutral and hot are not reversed at the outlet and that the line voltage is correct.
Sometimes a loose neutral can be a factor. Test outlets in several area of the house to see if some are high and some are low. This can be dangerous, and the power company must be called.
If there is anything else on the same breaker, that can be a factor.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Posted on Nov 29, 2009
  • 6771 Answers
SOURCE: My Magic Chef microwave tripped a breaker,I found a melted door switch and replaced it, the other three test ok.With the door closed everything works like new. When the door is opened the breaker blow
The only thing I can think of is check to make sure all switches are aligned correctly otherwise you will keep tripping the breaker, I'am certain that one of your switches are not properly in position.
Posted on Jul 08, 2012
GE Microwave runs for a few seconds
I had the same problem and got tired of resetting the breaker. It was the processor board, about $100 bucks. Works like a charm now. It's a pain to get to and is attached to another main circuit board inside the right front panel..
Apr 30, 2014 | Microwave Ovens
Ge profile microwave convection oven model 1790 troble shooting stop working
It may be a bad door switch or mount.
(Anybody in the home opening the door while it's cooking?)
See our help file on door switches here.
Mar 26, 2013 | GE Microwave Ovens
Unworking microwave
Well this is not good, the magnetron has probably been damaged and the main fuse has blown in the microwave oven not to mention other parts that may have been compromised. If this is a older machine I would consider a new microwave oven.
Apr 02, 2012 | GE Microwave Ovens
GE PROFILE MICROWAVE MODEL JEB1095SB002 Making
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Aug 05, 2011 | GE Profile Over-the-Range Microwave
I have microwave oven, PEB2060SM1SS, from GE. it happens twice where no power on display control pannel and oven stop work. The first time, still under warranty, so the guy fix the problem. Then, one year...
go to youtube type in your query and you should see a page go through video's and make note of who posted the video ,so you can keep referring to it . Hope this helps you .
Nov 30, 2010 | General Electric Microwave Oven
I have a GE Profile series microwave model #
the magnatron has blown they are very expensive to repair i suggest you buy a new microwave
]hope this helps
Jun 25, 2010 | General Electric Microwave Oven
My ge Profile microwave just stopped heating food/liquids. All else works on panel; just not heating. Why?
heatman101
45xs
May 12, 2010 | GE JE2160 Microwave Oven
GE Profile Performance Convection/Microwave Problem Heating
Either magnetron, capacitor, diode pack or transformer has failed causing a fuse to blow.
Jul 13, 2017 | General Electric Microwave Oven
Goldstar MIcrowave stopped working when light bulb blew out.
when that happen to me i change the bulb and the fuse in of the microwave f the don't work send it to the company that made it and they should tell what wrong.
Mar 11, 2009 | Goldstar MV-1501 Microwave Oven
No more heating, GE Profile Microwave JVM 1870CF02
I think its the mag tube, mine went out the same way. GE will provide the mag tube for free just call them...have a local ge certified tech out to put it in.
Aug 31, 2008 | GE JVM1850 1000 Watts Microwave Oven
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
