Mitsubishi ws-55511 will not operate by remote. Will power up from front panel but will not power down,with picture and sound but device menu is displayed and cycles from each input like it is stuck in a loop.Will not respond to anything reset button,disconnecting plug.
  • 2 more comments
  • gitz94 May 08, 2009
    This did not work display menu is still up with icon cycling through each input icon.Remote still does not work
    ???? no reply
    Was not caused by a power outage. Was hooking up a game console to input 5, front of tv then this problem occured.
    where is this fuse located?
  • 413 Answers
Try resetting it ro factory settings and plzz dont try something complicated because minor things requires just a technicians touch it is not a major problem,same happened with me
Posted on May 08, 2009
    Genius:
  • 1,268 Answers
I believe this problem is caused by a dead main fuse. You must replace that one immediately to resolve the problem.
  • 854 Answers
This unit, when first plugged in or after power interuption takes 70 to 90 seconds for the digital module to boot up. During the time the LED blinks green and the set will not respond to anything. After the appropriate amount of time the blinking should stop and the set should operate normally. If the blinking never stops then you have to have the Digital Module repaired.
Tv wont respond because device menu is changing through each device
I had a similar problem: my WS-55511 would not respond to the remote and the front control buttons (with the exception of Power) cycled through the Device Menu. I solved this problem by disconnecting the front panel. Here's how to do it: 0. Unplug the TV
1. Remove the speaker grill from the front by pulling forward: there are no screws. 2. Disconnect the two cables that are exposed after the grill is removed. 3. Plug the TV back in, wait for 5 minutes to reset. 4. Try using the remote.  Hope this helps!
Oct 06, 2008 | Mitsubishi WS-55511 55" Rear Projection...
Tip
Bypass Mitsubishi WS-73711 Front Lock
Bypass Mitsubishi WS-73711 Front Button Lock
Models: WS-B55 / WS-48511 / WS-55511 / WS-55711 / WS-65511
Models: WS-65611 / WS-65711 / WS-65712 / WS-73711
Would you like to bypass, defeat or reset your Mitsubishi HDTV WS-73711 Front Button lock?
If you have misplaced your remote control, and have engaged the Mitsubishi WS-73711 HDTV Front Button Lock, you can bypass the front button lock by pressing and holding the MENU button on the front panel for more than 8 seconds.
I hope that helps.
________________________________________
Mitsubishi WS-73711 Manual Download
Reset Mitsubishi WS-73711 VChip Password
on May 05, 2010 | Televison & Video
Tip
Bypass Mitsubishi WS-65712 Front Lock
Bypass Mitsubishi WS-65712 Front Button Lock
Would you like to bypass, defeat or reset your Mitsubishi HDTV WS-65712 Front Button lock?
If you have misplaced your remote control, and have engaged the Mitsubishi WS-65712 HDTV Front Button Lock, you can bypass the front button lock by pressing and holding the MENU button on the front panel for more than 8 seconds.
I hope that helps.
Mitsubishi WS-65712 Manual Download
Reset Mitsubishi WS-65712 VChip Password
Tip
Bypass Mitsubishi WS-65711 Front Lock
Bypass Mitsubishi WS-65711 Front Button Lock
Would you like to bypass, defeat or reset your Mitsubishi HDTV WS-65711 Front Button lock?
If you have misplaced your remote control, and have engaged the Mitsubishi WS-65711 HDTV Front Button Lock, you can bypass the front button lock by pressing and holding the MENU button on the front panel for more than 8 seconds.
I hope that helps.
Mitsubishi WS-65711 Manual Download
Reset Mitsubishi WS-65711 VChip Password
on May 04, 2010 | Televison & Video
Tip
Bypass Mitsubishi WS-65611 Front Lock
Bypass Mitsubishi WS-65611 Front Button Lock
Would you like to bypass, defeat or reset your Mitsubishi HDTV WS-65611 Front Button lock?
If you have misplaced your remote control, and have engaged the Mitsubishi WS-65611 HDTV Front Button Lock, you can bypass the front button lock by pressing and holding the MENU button on the front panel for more than 8 seconds.
I hope that helps.
Mitsubishi WS-65611 Manual Download
Reset Mitsubishi WS-65611 VChip Password
Tip
Bypass Mitsubishi WS-65511 Front Lock
Bypass Mitsubishi WS-65511 Front Button Lock
Would you like to bypass, defeat or reset your Mitsubishi HDTV WS-65511 Front Button lock?
If you have misplaced your remote control, and have engaged the Mitsubishi WS-65511 HDTV Front Button Lock, you can bypass the front button lock by pressing and holding the MENU button on the front panel for more than 8 seconds.
I hope that helps.
Mitsubishi WS-65511 Manual Download
Reset Mitsubishi WS-65511 VChip Password
on May 03, 2010 | Televison & Video
Tip
Bypass Mitsubishi WS-48511 Front Lock
Bypass Mitsubishi WS-48511 Front Button Lock
Would you like to bypass, defeat or reset your Mitsubishi HDTV Front Button lock?
If you have misplaced your remote control, and have engaged the Mitsubishi HDTV Front Button Lock, you can bypass the front button lock by pressing and holding the MENU button on the front panel for more than 8 seconds.
I hope that helps.
Reset Mitsubishi WS-48511 VChip Password
Mitsubishi WS-B55 Manual Download
Tip
Bypass Mitsubishi HDTV Lock
Bypass Mitsubishi HDTV Front Button Lock
I hope that helps.
Reset Mitsubishi HDTV VChip Password
Mitsubishi Projection HDTV Manual Download
on Apr 30, 2010 | Mitsubishi WS-55511 55" Rear Projection...
Tip
Mitsubishi WS-55511 Manual Download
Download Mitsubishi WS-55511 HDTV Manual
Have you misplaced your Mitsubishi WS-55511 HDTV Owners Manual?
Would you like a digital, searchable, pdf version of the Mitsubishi WS-55511 HDTV Users Guide?
Follow this link to download a pdf version of the operations manual.
I hope that helps.
Bypass Mitsubishi HDTV Front Panel Lock
on Apr 30, 2010 | Televison & Video
Tip
I hope that helps.
Televison & Video Logo
48 people viewed this question
Top Televison & Video Experts
Electro Med Services...
