Question about Acer (ACERMOTHERBOARD)
Blank screen on my laptop, unit is turned on
Had screen saver on, could not turn the computer off the norma way. Turn if off by pressing the off/on button and then tried to re-boot,the small light turns on the front of the compter and the on/off button is on makes sounds like it starting up but the monitor display is dark. Tried f5 to turn the monitor on/off when using another monitortried several soultions such as pressing the alt & f10 keys , safe mode keys, ect. Acer Aspire 3100 laptop
  • leo_j2002 May 08, 2009
    Thank you for all the information, followed the instructions you gave , couldn't get a beep when the ram was removed. Sounds like the motherboard is the problem with my computer. Still have a faithful old desktop .
    Scholar:
  • 70 Answers
Could be a couple of things. First off, I would try shutting the laptop off entirely, removing the AC Adapter and battery from the bottom of the unit and pressing the power button down for about 20 seconds with all devices removed, and plugging everything back in and turning it on again. Should this not work, again remove power and battery, and if you're familiar with the process, removing the RAM as well, then plugging the power back in and try turning it on, see if you can get the computer to emit a POST error beep. If you do get the beep, then it could very well be a faulty stick of RAM, which is easy enough to replace. If you don't get the beep, but the unit still powers on, then there' smore than likely a problem with the motherboard in the laptop. If that's the case, then check with either Acer Technical Support via phone or web, or with the place where you bought the computer and see if you're still within some kind of warranty, and if you are, you can get it serviced through them. If not, motherboard repairs can be very costly (parts and labour will probably run about $400-600USD). RAM modules though like I mentioned before are quite inexpensive and simple enough to replace.
Posted on May 08, 2009
My laptop went to hibernate and I cannot wake it from that mode. I only have a blank screen.
you have to press the power button once to get it out of hibernation. If nothing else works you can do one of two things:
1] Press and HOLD the power button for about 5 seconds or until you hear the laptop turn off. Then turn it back on again by pressing the power button momentarily.
2] You can DISABLE hibernation. To do this - follow these steps,
  • right-click the desktop and click on and click on "properties".
  • click the screen saver tab.
  • click the power settings button
  • in the power options properties dialog box click the hibernate tab.
  • uncheck the enable hibernation check box.
  • click OK then click OK again
Hope that helps
Good Luck
Feb 07, 2011 | HP Compaq Presario V3000T Notebook
On my laptop the screen had rotated. It not landscaped now. In order to view, I need to turn my laptop to view.
Press CTRL+ALT and any one of the Arrow keys to turn your monitor screen to proper position..see the pic to find out arrow keys
Sep 20, 2010 | Computers & Internet
When I close my laptop during normal use, Instead of going into hibernation as normal, the screen just goes blank (with the laptop still running). However I cannot resume the computer and have to just turn...
hi when you close your laptop it goinng to stand by mode if you press any key it should resume. you can change this options in control panel, power option then go to advanced tab. By the way hibernation need to be enable and is different than normal shout down. if you need more help let me know.
is it help please rate it
regards
Sep 06, 2010 | Computers & Internet
Computer restarts every time screensaver comes on
try to turn off the laptop, remove the cables and battery, then press and hold the power button for 8 secs. Reinsert the cables and battery and turn on the pc. Observe if the screen saver works...
Aug 03, 2010 | Toshiba Satellite P105-S6197 Laptop
The monitor turn off when I used more than one hour.
It is most likely caused by the 'standard' Windows Power Saving settings:
- Check your PC/Laptop 'Power Options' and Edit Plan Settings to Change the 'Turn off the display' setting to your requirement including Never Off.
- Check your Screen Saver option especially if set to Blank screen and change the timeout accordingly..
Hope it helps.
Dec 30, 2009 | E-Machines eMachines Monitor E15T4
Dell Inspiron 1100 screen goes into power saver mode after 45 sec
it sounds like your most likely having trouble with the hibernate feature try this
start>>control panel>>power options>> click on the hibernate tab
un check enable hibernate mode
this should fix your issue
Apr 10, 2009 | Dell Computers & Internet
White blank screen
<Fn> + <F6> Screen blank
Turns the display screen backlight off to
save power. Press any key to return.
Dec 30, 2008 | Acer Aspire 4315 Notebook
Getting frequent black screens on 1501 Inspiron Laptop
Black screen is probably a screen saver or the screen is turned off by power management software.
Check your screensaver setting. Change the screensaver to None to disable screensaver.
I assume you are using Windows XP.
If the LCD is turned off by power management, on the same screen with screen saver, on the lower part of the box there is a Power button. Click to open Power Options Properties. Set your monitor power properties there.
When the screen go blank and you have to push power button, probably the computer is set to go to stand by mode after some idle minutes. You can also set it here in system standby setting.
Regards,
Dapid Candra
Dec 08, 2008 | Dell InspironTM 1501 Notebook
Screen going blank and laptop freezes.
Go into the diplay properties, under the screen saver tab there is a button marked power, open this. Under one of the tabs there is a section that reads, when I close the lid, under this section set it as never.
Jul 10, 2008 | Dell Inspiron 1000 Notebook
Computers & Internet Logo
196 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
