Question about Sport & Outdoor - Others
I have a ten year old tent hardly used that has somehow now minus its tent pools can i get replacement ? how ? and How much
    New Friend:
  • 24 Answers
Sporting goods stores normally carry generic replacement poles- you want to find pole of the same diameter. These can carefully be cut to size by securing the cord between the first & second pole, cutting the knot at the end of the pole, then sawing off the end of the first pole that does not have the metal coupling. This is easier if you wrap masking tape around the pole at the cut location to help prevent the fiberglass from splitting. Put the cord back through the first pole, tie a couple of figure 8 knots, and you are good to go.
Posted on Dec 02, 2013
Where can I get tent replacement poles for a Ted Williams blue canvas tent sold by sears as they don't have them?
How old is it? (Canvas suggests that it is very old and has not been produced for many years.) If it is more than a few years old, the only way is to find a supplier that will make custom poles to fit most tents. But that can be expensive, and so you might want to just find a new tent that you like. Don't spend a ton of money on an old and possibly very leaky tent unless you know that it will keep you dry.
Feb 27, 2015 | Camping, Backpacking & Hiking
I have a Hayward in ground pool pump with an AO Smith model# k48m2n111. It's 10 years old now but yesterday it stopped working and just whines real loud when i start it . Could it be a quick fix? Is it...
Hayward pumps are poor quality. You're lucky to get ten years. In 4 years I've needed the motor replaced twice and the pump repaired. The motor is starting to whine again. Just a matter of time before it fails. Do yourself a favor and stay away from Hayward.
Oct 06, 2014 | Pool & Spa
Does the salt system affect my pool pump?
Over time it will attack the motor, yes. There are pumps especially designed for salt water pools, with 316 stainless steel parts, and an open section in the casing between impeller housing and motor casing, and seals on either side with a flinger on the shaft. Eventually though the salt will get to the motor somehow. Mind you we are talking years. On my salt water pool, now 23 yrs old, it is on its 3rd motor, which is about 5 yrs old.
May 19, 2014 | Hayward 1.5hp Pool Pump Motor Motor A O...
What is the expected lifetime of a tent?
The average lifetime of a tent is 7-10 years when using it 2-3 times a year, each time between 3-7 days. Taking good care of the tent is a major factor in its lifetime.
Jul 10, 2012 | Camping, Backpacking & Hiking
Blue halo on mitsubishi dlp
The caps on the power board are replaceable by a ten year old who can solder.
If 1000uf @ 10 volts go to a higher rated voltage cap say 25 volts which is why all the original ones went south.
Each cap has a -minus and a +plus on one side===pretty simple to do with only two leads each and a plus and minus marked on the part and on the board.
Do not swap parts from another junk board...waste of time and effort.
hope you get it going
Mar 06, 2012 | Mitsubishi WD-52525 52" Rear Projection...
My booster pump is much louder than last year. Can you oil it somehow
PLEASE DO NOT TRY TO OIL THIS, IT HAS A START SWITCH INSIDE THE MOTOR, IF IT GETS OIL ON IT IT WILL NOT ALLOW THE MOTOR TO START. AND CAN CAUSE THE MOTOR TO FAIL.
SEARCH YOUR AREA FOR YOUR LOCAL POOL PUMP REPAIR GUY, COST AROUND 125.00 TO REBUILD ONE OF THESE MOTORS. USE UTMOST CARE WHEN REMOVING WIRES FROM THE BACK OF THE MOTOR !
POOL PUMP MOTOR HAVE SEALED BEARINGS, THERE IS NO WAY TO OIL THEM, THEY NEED TO BE REPLACED. I DON'T RECOMMEND WORKING ON A BOOSTER PUMP, THERE A HARD ONE TO FIX .. SORRY .. JAY .. THE POOL PUMP MOTOR REPAIR GUY IN LONGWOOD FL
Jun 04, 2011 | Polaris 280 In - Ground Pool Cleaner with...
05 cts when iturn the key the engine does not stat just a click 2 or 3 times the it starts and it does not sound healthy( im from winnipeg minus 25 don't plug car in) when it warms up it does strt fine...
If it's the original battery, it's 12 years old and way beyond it's useful life. If replaced once, the second battery is probably near the end of its life, five to six years
If you're near a Wal-Mart super store, get a new battery installed if the other is old, five to six years They have good prices and top rated batteries by CR. While you're there and if it's -25 (C or F since the scales are concurrent about that point) go to snack shop and warm up with a nice hot cocoa or hot cup of coffee. Sometimes its free in the customer lounge.
Good Luck
Sep 22, 2017 | 2005 Cadillac CTS
Swiss Gear Tent - Broken Poles SG33071F
Take a look on amazon for replacement. here: Amazon com tent poles. I hope this was helpful. Cheers
Aug 24, 2009 | Wenzel Swiss Gear Grand Lodge Cabin Dome...
Glowbuoy flashes on and off after charging,hardly been used
If your swimming pool light is not holding a charge, it could be that your battery pack is defective. For this particular light, you cannot change the batteries yourself. It is designed so that the housing cannot be opened by the owner. You would need to take it to a pool professional and have them change your rechargeable batteries.
Jul 13, 2009 | NRS CANTAR GLOW BUOY FLOATING POOL LIGHT...
Sport & Outdoor - Others Logo
Top Sport & Outdoor - Others Experts
Bill Eager
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
