Question about Sanyo DP42746 42 in. Plasma Television
Tv will not knock off or come on,keeps tapping
The tv keeps making a tapping sound whether it is on or off.there is no picture so do not know if it is on or off
    Scholar:
  • 171 Answers
Sounds like you have some bad capacitors that will need to be replaced ... if you are not qualified to do it yourself and the TV is not a high end unit, your best bet is a new TV. As far as knowing if it is on or off ... unplug it, wait a few seconds and plug it back .... most TVs will be in the off mode when you first plug them in. So then you will know it's off.
Posted on Nov 25, 2013
How do I fix my model tv No picture but knocking sound?
The knocking sound is the high voltage trying to fire. That would tell me that the high voltage splitter has failed or one of the 3 picture tubes (not lamps) has failed. Most likely too expensive to repair a TV that old.
Sep 12, 2015 | Sony Televison & Video
Samsung 52" HDTV turns on fine picture works fine but my sound isn't and it makes a knocking noise every few seconds,any idea what could be causing this
Try to disconnect all devices connected to the tv. Perform sound test. I need to know the model of your tv.check the model on back ??
Apr 16, 2015 | Samsung Televison & Video
Plasma has no picture but sound works???
If the set was struck even a moderate blow anywhere near the screen you may have a bad plasma display panel---the diffused picture sounds like that.
Sep 01, 2012 | Pioneer PureVision PDP-5040HD 50 in....
Constant tapping sound
there might be short in the wireing or in the speakers make sure it is in all the way...
Apr 29, 2009 | Bose Companion 2 Series II Multimedia...
Sony Tv PFM-42 V1 doesn't show any picture or tv menu
This is a common problem with plasma tvs You did not mention whether you could generate any sound like through your dvd player or something like that. Whether you have audio or not makes a difference on which board may be causing you the problem. Just because it does not have a picture for tv viewing does not mean it won't produce some type of sound through your av1 input. Try it and I'll try to be more specific.
Jan 06, 2009 | Sony PFM-42V1 42 in. HD-Ready Plasma...
Getting a sound and picture but with a strange noise
tap tv with palm and see if it stops if it does you have bad solder conection
Oct 19, 2008 | Disney DTD1363-CAR 13" TV/DVD
Knock
rockers tap rods knock pistons double knock
May 27, 2008 | 1996 Ford Taurus
TV Picture Cuts Out
Sounds like you have bad soldier connections inside your set.
Mar 12, 2008 | Daewoo DSC-30W60N 30" TV
Picture flickers when T.V. is tapped on or struck.
sounds very much like a loose connection, i.e. a wire or solder joint, you could have a look around make sure everything is plugged in right, as for the solder joints id advise getting it proffessionally looked at as these rear projection tvs can be a lot of hassle if you slighty knock any of the 3 tubes,
Feb 25, 2007 | Hitachi 53SBX59B 53" Rear Projection...
Sanyo DP42746 42 in. Plasma Television Logo
71 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
