Daweoo dwd e1211r
It just rings at the start of the washing process after the water supply. Can anyone help me with this? sorry for poor english lol
jmeredith
  • 417 Answers
SOURCE: My washing machine (dwd-wd32ws) only uses hot water to wash!
hi,
try and switch your hot and cold water hoses around the other way. it should start the cycle with hot and rinse cold.. If it still does it you may have to have it serviced..
jm
Posted on Nov 27, 2009
  • 136 Answers
SOURCE: My washing machine isn't
code/DiceGame.zip clink on the above link and download the code. Select 'Save' from the IE popup dialog. Once downloaded, open the .zip file from your local drive using WinZip or a comparable program to view the contents.
Posted on Jan 18, 2010
  • 6277 Answers
SOURCE: I need an English Version
You will need to type into your search engine/web browser '(make) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount. During the process you will be asked for the actual model number!
You could also try the manufacturer's web site direct.
Good luck,
John C.
Posted on Apr 08, 2011
  • 6277 Answers
SOURCE: i have a daewoo front
I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to spin or release the door lock if there is any water still left inside.
Here are my complete and generic guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT.
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Posted on Jun 05, 2011
SOURCE: I had DWD-F1011 front loading washing machine. Power is getting on from top switch. But start/pause button is not functioning. Any solution.
Try unplugging it for 10 seconds then plug back in see if that resets it.
Hope that helps
Posted on Dec 02, 2012
Daewoo DWD-F1011 1E error code I have a daewoo washing machine model DWD-F1011 and it start working the wash before no working spin and gives error code 1E. Any idea what that might be?
I do not believe that is a 1E I think it's an IE error code which would be water inlet wiring or something like that. Here is the code list, scroll down until you find IE, Daewoo errors start at E2, hope this helps.
http://removeandreplace.com/2015/11/02/daewoo-washing-machine-error-fault-codes/
Aug 30, 2016 | Daewoo Washing Machines
E9 message and machine stops
Jayshree, E9 error, pressure sensor error/water sensor error.
Replace water level sensor. The error display disappears if power button is turned off and on.This is what the service manual states.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Daewoo DWD M103 Service Manual Page 15 of 16
Daewoo CV701PC Service Manual Page 26 of 52
Daewoo Washing Machine Error Fault Codes
Washing Machine pressure switch
Apr 20, 2014 | Daewoo DWD M1031
I need an English Version for Daewoo Washing Machine Model DWD-F1042T . I bought it in Spain.
Good luck,
John C.
Apr 08, 2011 | Washing Machines
OE code on front load Daewoo washing machine
According to your owners manual you only have two choices...
Your lint screen is blocked or you have a problem with your drain motor (a separate device ).
Old age & experience will add a third... Assume lint did get past all those sophisticated "filters" and is presently residing inside the impeller housing... In the olden days when those housings came apart (aluminum/aluminium) I took out an entire sock and enough lint to make another... My guess today is you buy another plastic pump.
Sorry I could not get part number or price here in the USA...
Not even cleverly saying "spares" (but I did try).
Hope this was helpful.
Daewoo Washer Drain Pump Spares Yahoo Video Search Results
Yahoo Image Search Results Page
Amazon com Daewoo Dwd m301wp Mini Drum Washing Machine English Menu...
http://www.daewooelecusa.com/customer-service/service-centers
Jan 06, 2010 | Daewoo DW500M Top Load Washer
hi,
jm
Nov 27, 2009 | Daewoo Washing Machines
Daewoo DWD-F1011 PFE error code
I hd zs problem before,no problems in z water outlet,z pump
Nov 16, 2009 | Daewoo Washing Machines
Washing Machines Logo
19 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
