Question about Whirlpool Dryers
Azb 9750 The dryer is just over 2 years old. The dryer won't turn. When turned on "check filter" and "water tank" led's plashing red. Unable to reset. I took the side panel off and tried turning it by hand, belt slips on pulley but motor doesn't turn. No burned smell from the motor, no signs of overheating, burning/melting. How do I reset? Do you have a fault diagnosis/error code list that you could email me? norbidworak@gmail.com Your help will be greatly apprecited.
  • 2,113 Answers
If the motor doesn't turn then the bearings have dried up and it seized. As this point the start winding likely overheated and it would blow a thermal cutoff inside the motor as well. Replace the motor.
Posted on Nov 25, 2013
  • 2692 Answers
SOURCE: DRUM NOT SPINNING....and a burning smell
Motor going bad. Run windings inside are burneded up.  Start windings are ok. replace motor.
Posted on Jan 07, 2009
  • 142 Answers
SOURCE: My frigidaire dryer had burning rubber smell now wont turn on
soulds like the fuse in the unit overloaded, fluff or oter items may have fallen onto the element, or the unit was overloaded, and the belt was slipping on the motor drive pulley. check for rubber drive belt debri. replace damaged items as required.
Posted on Jan 25, 2009
Maytag317
  • 1136 Answers
SOURCE: Burning Smell from Belt on Whirlpool Dryer
Hi, You need to check and see if the belt has slipped off of one of the pulleys. Was the idler the wheels style or a glide style?
Make sure the grooves in the belt are facing the drum and they are in the grooves of the motor pulley.
Please let me know if this helps and if I can assist you further.
Vic
Posted on Jun 01, 2009
erpaalai
  • 999 Answers
SOURCE: how do you check the belt?
You will have to lift the top to check the belt and also for access to change it. Burning could also be lint or wires so if it was not the belt make sure you find the reason and repair that carefully.
Eric
Posted on Jun 08, 2009
  • 97 Answers
SOURCE: Maytag dryer, LDG9334, won't start to rotate, burning smell
Hello Friend, From my experience, it sounds like the motor is tired and getting ready to fail. Only option is to replace. Happy to help, Tim.
Posted on Jul 11, 2009
How to reset whirlpool model#G2IXEFMWB01 after replacing water filter
Reset? Some models will have a "filter replace" led that turns from green to yellow to red when it is time to change the filter. Resetting is as easy as pushing the "reset" for 3 to 5 seconds and the light will change from red to green. I looked up this model and could not see if it had a filter led or not so I am assuming this is what you are asking?
Make sure to run water though the dispenser to get the air out of the lines as well
Jul 15, 2017 | Whirlpool Refrigerators
How do i reset the fault code FO4 on whirlpool dryer AZB 7570.i read the manual and it says i need to call service engineer
It can only be reset after fixing the issue with the unit. Have you successfully completed the repair?
Dec 28, 2014 | Whirlpool AZB 7570 White Electric Dryer...
I have a whirlpool azb 9750 and seems to have no pore but the fuse in the plug an the socket power is all ok, is there an internal fuse or thermal reset within the dryer
There are some overload/temperature switches within the dryer. Most reset when the overload/temp gone. You could open up the back and follow the wires to the overload switches and check with an electrical tester to see if you have power passing through each. The wiring diagram should be inside the dryer, and show each switch.
Jan 26, 2014 | Whirlpool Dryers
Can't unscrew water filter canister from main water system, I tried silicone spray didn't work.
1. Turn the incoming water off.
2. Open closest cold water faucet, let it run until no water.
3. Turn off outlet valve after filter.
4. Hold down red pressure relief button, until no water.
5. Unscrew filter bowl with filter bowl wrench (if you have one).
If this does not work repeat steps 1-5 and turn the water off at well tank or water meter. Never tighten pre-filter with wrench, changethe o-ring every year and lubricate the o-ring every time filter is changed.
RJ
Sep 22, 2011 | Culligan Sediment Water Filter
We pulled our stacked washer out from the wall to service the cold water hose filter on the back of the unit. when we pushed it back into it's location the washer won't start, won't fill...
I know you don't want to hear this, but either you did something to the hose filter or you didn't get it plugged back in correctly.
If you banged the water inlet valve in moving it back, it might be damaged.
Suggest you unplug everything and start over.
Sep 04, 2011 | Frigidaire FEX831F Top Load Stacked Washer...
I have a GE front loading dryer model # DBVH512EF0WW. It's about 1 1/2 to 2 years old. It has worked perfectly up until this point. When we push the start button, it just beeps twice, but does not...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jun 13, 2011 | GE DCVH515GF Gas Dryer
Red led light on constantly
electronic circuit needs replacement
Feb 01, 2009 | PUR (FM-9500) Air Purifier
NOTHING WORKS
Check the foam filter on the underside of the recovery tank lid, make sure that it has at least a 1/4 in. gap from the top. There also is a filter, from the bottom, it has a red frame, pull out far enough to clean it.
On the bottom of the tank, depress the vale to make sure water is coming out. With the tank off, squeeze the trigger, is the rod inside the handle pushing up against the diaphram, if it is, there maybe a problem with the reservior asm and will have to be replaced.
Jul 04, 2008 | Hoover SteamVac F5914-900 SpinScrub...
Dryers Logo
110 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
