Question about Dryers
Lakewood box fan 3 speed switch wiring schmatic
  • Anonymous Mar 29, 2014
    Wiring for three way switch replacement
  • 38 Answers
What I did was (but be VERY VERY carefull) is have the fan plugged in, and check which wires give which speed when you touch the main wire. VERY carefull. I'm not liable for any harm done to you or your fan.
Posted on May 09, 2009
Fan does not turn on low speed, middle speed. do I need a new motor?
if the motor works, you do not need a new one ! sounds like the switch is bad. if you only get high speed. have a good day !
Feb 12, 2011 | Lakewood HV-12-c Floor / Box Fan
Wht is the correct wiring (red, white, blue, black) for the three speed switch?
White is the common or neutral...
Black is the high speed...
blue is medium...
red is low speed...
hook them up right in that order....
heatman101
Aug 17, 2010 | Lakewood HV 18-c Floor / Box Fan
On a 3 speed switch you usually have 4 terminals, and they are marked L1, 1, 2 and 3.
L1 which is line voltage from the electrical cord or wall plug, #1 low speed usually a red wire from motor, #2 medium speed usually a blue wire from the motor and #3 high speed usually a black wire from the motor. That is if the fan is low,medium and high, if it says high, medium and low then reverse #1, #2 and #3
May 08, 2009 | Heating & Cooling
Speed indicators light up but no fan operation 18" floor fan.
Your fan speed control module is probably shorted and is damaged. Have it repaired by an electrician.
May 01, 2009 | Lakewood HV 18-c Floor / Box Fan
Need to replace the switch that has ,hi,low,med off on nit? please Help
you have 3 control wires (the 3 speeds) and a common wire. the common wire will go directly from the fan motor to the power source/cord and the other 3 leads will run through the switch. you could even use a standard dimmer-style lighting rheostat and connect it to the common and "high" fan speed wire and have infinitely variable fan speeds. hope that helps.
Apr 30, 2009 | Lakewood HV-18 Floor / Box Fan
Cleaned a fan, now it's broken!!!
Is this the speed switch itself? These multi-speed fans have 4 or 5 wires which come from the motor which go into the speed select switch. The wiring may have the ends stripped, and this stripped end just pushes into the hole on the switch, and a little metal piece grips that stripped end.
Anyway, one possibility is to contact the manufacturer- look on their website or give them a call, see if a tech can give that info. Another poss. is to locate an identical fan and note the wiring locations on it. You can also experiment trial and error, though caution needs to be exercised here.
Jul 31, 2008 | Lakewood HV 18-c Floor / Box Fan
Lakewood HV-18 fan... how to wire switch?
My switch unit also fell apart as I took the back off and I didn't get to see the correct position of the switch. After much trial and error, I found this to be the initial "Off" position (see photo)
Oct 13, 2007 | Lakewood HV 18-c Floor / Box Fan
Window Fan switch bad
Steve, Your fan model is HV-18-WR; I have 2 with the same problem. I can't find a source for DYE-3606 switches either. Here is one source for rotary switches; one might be suitable: http://www.alliedelec.com/Catalog/Indices/Products.asp?sid=46BBAA8076DBE17F&N=4294828748 I can draw a diagram of how the existing switch is connected, but I don't know how that would translate to a replacement switch.
May 22, 2007 | Lakewood HV12WR Window Mount Fan
Dryers Logo
2,657 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
