Pc doesn't start by pressing power on switch, supply is normal and ok
  • 31 Answers
How to check, let you try :
  1. Check the cable / pin power switch (connected correctly or not)
  2. Check your Memory RAM, dislodged it and clean it and then plug it.
  3. Or try to plug your memory to the other slot.
  4. Reset your cmos
  5. Check the Processor.
Did the fan of the processor working or not??
if it working but doesn't appear in the screen, check your vga.
Posted on May 08, 2009
Liebert gxt2-10000t230 low batt,bypass light flashing,no output,shutdown after a minute
Test outlet power by switching the unit to manual bypass and breakers off.
If power is supplied OK and the filter board repaired OK then restart the unit starting with the breakers supply to unit,battery confirm the display is on and static bypass led also on then switch back the bypass knob to normal and press the on button to switch the unit to normal.
Give the batteries time to charge 12hours then you can test the unit on backup mode.
Nov 25, 2014 | Liebert (GXT2-10000T230) (GXT2-10000T230)...
The LED in my motherboard is on, but if i turn on the switch, their is no response. the power connection is correct. but it doesn't work
Try swapping the power button connection with the reset button connection. Then to turn on your computer you will need to press the reset button. If that works you have a faulty power button. Otherwise try using a different PSU. One that you know works. If that doesn't help the motherboard will have to be replaced.
Jun 18, 2011 | ASUS P5VD2-VM SE - Motherboard - micro ATX...
My computer doesn't start power supply checked - ok connection checked - ok
Hi There,
Firstly, disconnect everthing from the Power supply EXCEPT the motherboard
1. Does the fan on the CPU spin when switching on?
Double check power switch connections to motherboard, sometimes if connected incorrectly, it may stop the board from powering up.
2. Attach the PC speaker to motherboard and remove RAM, REMEMBER to follow all antistatic rules when doing anything inside the computer.
Switch machine on and listen if it makes a sound. if it does then the motherboard is fine.
Have you recently fitted the board yourself?, if so make sure it is not earthing on to the casing.
Try these first and let me know how you go.
neil
Jun 09, 2011 | Asrock ALiveNF6G-VSTA (MB-ALVNF6G)...
E system 1212 Laptop won't switch on. Power
Laptops are so integrated that usually a system failure that involves power issues such as in your case where you cant get it turn on with anything on the screen mean the mainboard (motherboard) is damaged. This usually leads to buying a new laptop or paying for the board to be replaced which usually costs as much as the laptop.
May 12, 2011 | Computers & Internet
My gateway 503gr will not power on when you press the power button has power to mother board every thing is plugged in there is a green light on the power supply and the mother board and the power switch...
This could have a bad power supply (in this case I would try a new one just in case).
All other things being normal, I would guess a bad motherboard.
The best thing to do is disconnect everything but the CPU and memory and try to start it.
If it starts, then start connecting stuff until it doesn't start--this will tell you what is bad.
Apr 13, 2011 | Gateway 503GR PC Desktop
When I press the power switch, the green light comes on for about 2 seconds then it starts flashing red.
I'm afraid you need a new Power Supplies Unit. Just try an old trick first. Remove power cord from the back of PC. Press power button and keep it pressed for good 30 seconds. Then reconnect power cord and try to start as normal. If this don't work I'm afraid your PSU is dead. Good Luck
Apr 28, 2010 | Intel Compaq EVO D500 (RBMDTCPQP42400) PC...
Power supply Ok.But CPU fans started with seconds It's stop.
sounds to me like your mainboard is bad, i bet if you closely inspect the capacitors around the cpu one or more is bulged out or leaking
Feb 15, 2009 | Asrock P4S61 Motherboard
My computer doesn't power-up
Sounds like motherboard or cpu have given up ,try booting with no ram checking for beeps,vga etc
Jan 09, 2009 | Intel D915GAG Motherboard
My Computer starts then turns off...
hi buddy!
be sure that the power suppy can can handle all the components thier plug. and check the power button if there is no short circuit ok. also try the other power suppy if you encounter the same problem just reply i am willing to help you ok.
PS:
pls rate me if my solution solve the issue and you need more further information. but if is invaluable solution rate me fixya.
Jun 23, 2008 | Antec TruePower 550 (true550) 550-Watt...
150 W ATX Power Supply HP-150SS
All you have to do is connect the green wire (normally thinner than the rest of the cables) to any black wire. This can be done easily with a short piece of wire. If the power supply doesn?t immediately turn on (within 2 seconds) remove the wire, you may have connected it to the wrong wires, although most power supplies won?t allow a short to damage the unit. Once on, the power supply isn?t loaded so the voltages won?t be as stable as if they were used in a full PC, however it?ll be sufficient for most uses. It?s not a good idea to leave a power supply on in this fashion for a long period of time too."
Aug 10, 2007 | Dell HP-150SS (HP150SS) 150-Watt Power...
Computers & Internet Logo
367 people viewed this question
David Payne
David Payne
