How can i boost my wi-fi
You can buy a 'repeater'. A repeater is a net device that can pick up your wifi signal from one wifi, and using another channel (your computer or other device can automatically change channels) it will also send the same connection without wires. Basically, these are like cell towers in that you can move from one to another seamlessly, if they're built to do so. Some cheaper models will require you to chose the one you want.
The other option is to use the etherport, and run another wireless router by pulling a cable to the part of the house or buisness where you need the signal.
Now, that's the easiest way. However, if your wifi uses an antenna, sometimes, if you can find one, you can get a better antenna, something that is directional, or partly directional, this can at times double or triple your distance. However, unless the antenna has an amplifier, it will merely have the same signal, it will just confine the directions it travels, and this boosts the signal. Most normal antennas transmit 360°, but you can get them with any angle spread, and it will help, even down to 15°, which is a very narrow but strong signal. Add an amplifier, and you increase the output signal.
Hope this helps.
