Question about Vivitar Cameras
Vivitar Camera Flashes DF 186
I have DF186 flash, off late the equipment flashes without triggering and flashes continiously about 7-8 times. This also flashes even when the equipment is not mounted on camera
  • 19 Answers
SOURCE: Memory card flashes full when it's not
There should be a "format card" option in the camera's system menu. do this and it may help the unfortunate equipment realize the situation:) (be sure there are no pics you want to keep as they will be permenantly removed)
Posted on Jul 07, 2007
SOURCE: SB800 firing but not syncing??
hi, i had this problem also but found a way around it . what is happening, is that the sb800 preflashes when you shoot and triggers any external flash heads a fraction of a second just before the camera takes the picture. you see the lights being trigered but it the light doesn't register on camera. ( preflasing asseses the amount of light needed for the correct exposure and is a feature on newer models of flashes ). what you can do to avoid this problem is to either use a radio trigger and slave, or set your flash to su-4 mode ,which cancels the preflashing. if you press the select button on the flash .you go into the menu \ scroll up and down till you reach the icon of two flash heads . press the select again and change from " off " to su-4 .that will cancel the preflashing and your other lights will be in sync with your camera . if you get confused go to page 76 in the sb800 manual it explains everything there / hope this was helpful. good luck charles yacoub
Posted on Sep 14, 2007
kalaci
  • 30 Answers
SOURCE: camera and flash gun trigger voltage
Hi Syd,
Vivitar 2800 and 2800D are two different flashes. The first is an old flash, having high trigger voltage, which, as you will see, still can be used with your Fuji. The second is a member of modern flashes, having a low-voltage release. Manufacturers specify the highest applicable voltage at the trigger (hotshoe or PC) terminal; at most digital cameras it reaches several hundred volts.I believe, this is, what your seller was asking. As far as I know, Fuji doesn't mention this value in the user manual of the Finepix 9500, but I met reports of people, who called Fuji and asked that and the answer was 400 volts!
So the short answer is: buy any wireless trigger if you have the 2800D, and tell the seller the flash has about 200 volts if your flash is an older 2800.
I wonder if you did already use your flash with your Fuji?
Laszlo
Posted on Nov 28, 2008
  • 4 Answers
SOURCE: wireless flash trigger for vivitar 283
I purchased the Wein Slave Foot. The metal foot is designed to repair the plastic foot that, apparently, is prone to breakage. Mine is not broken, but I purchased the Slave Foot because the blurb stated that it would make my unit serve as a remote slave.
The setup works fine with my Sony A700 using either the built-in flash or in combination with my proprietary external Sony flash.
I have just purchased another used 283 and will be ordering the Wein Slave Foot from B&H in the morning.
Caruso
Posted on Jan 03, 2009
  • 1170 Answers
SOURCE: CANON 40D. Had Flash Error code 05. Powered down
Pop up flash locking mechanism needs adjustment or to be replaced . You might be able to do this yourself but the top cover has to come off completely ( the mechanism I am talking about is on the inside of the top cover and is not expensive ).
One reason for sending it in is that if the mechanism ( small electro magnet and the lock ) has to be replaced you will need spare parts and these are not freely available.
Posted on Jun 13, 2009
Vivitar 1900 on nikon d3000
NO!
The trigger voltage of the Vivitar 1900 is too high for the Nikon D3000. Using it without electrically isolating the units will fry the camera.
Nov 27, 2013 | Vivitar 1900 electronic flash Flash
I have an old Vivitar 215 flash, still working. Can I use it with my Nikon D3200?
Not without using something like the Wein Safe-Sync to isolate the flash from the camera. The flash's trigger voltage can otherwise fry the camera.
Nov 10, 2012 | Vivitar Auto 215 Flash
What do the positions 1, 2, and 3 do on the DF-120 Camera Flash? I have lost its User Manual.
If I'm not mistaken it's the different times at which you want the flash to fire (time after the shutter opens and before it closes).
One of the positions will be in sync with the camera build in flash (if it has one) due to the auto sync that the flash has build in.
Mar 17, 2011 | Vivitar DF-120 Flash
Vivitar DF-283-CAN flash suddenly won't go off. I hear it power up and the ready and ettl lights go on but the ok light doesn't light up and the test button wont work either.I tried replacing the batteries...
This is more than likely a Manufacturing problem. A lot of Vivitar cameras have this problem as well as many others that are usually not the consumers fault. Just a glitch in the technology. I alone have gone through four Vivitar cameras in the last six months. The best thing to do is contact Vivitar directly. This is there website: www.vivitar.com It is best to see if you can find the number for technical support. To see if they can give you a refund or replace it for you. I hope this helps. -Richard
Jan 01, 2010 | Vivitar DF-200 Flash
Can the Vivitar 283 be used safely on Nikon Digital SLR Cameras?
I assume you're asking about the 283, not the DF-283 which is compatible with digital cameras.
As for the 283, yes, if you put an adapter such as the Wein Safe-Sync between the camera and the flash. Under no circumstances should the flash be mounted directly on the camera.
Nov 29, 2009 | Vivitar 283 Flash
Older Vivitar Flash for new Canon SX10
Not compatible.
Get slave triggers and use them as remote flashes, or buy another film camera.
It seems Vivitar no longer is in the flash business. Get a Sigma or Sunpak digital flash for your SX10
Aug 28, 2009 | Vivitar 285HV Flash
Using a vivitar 2800 flash on a nikon d60
The old series Vivitar 2800 flashgun has a very high trigger Voltage, that can damage your D60's circuitry. Even measuring the trigger voltage with a voltmeter is not a solution since you can't rely on the voltmeter to indicate the peak voltage.
Feb 05, 2009 | Vivitar 2800 Flash
Vivitar trigger voltage
Yes, you can. The flash has a low-voltage trigger circuit.
Laszlo
Nov 14, 2008 | Cameras
Vivitar 3200 Flashgun and Canon EOS 400D
Using Vivitar 3200A flash gun on a DSLR is risky for the following reason. The trigger voltage of a DSLR at flash hot shoe that takes it to its TTL (through the lens) circuit is less than 10 volts, it is about 6 to 8 volts in the recent DSLRs. The trigger voltage generated by Vivitar 3200A at full charge flashing is around 180 volts (max). That is a fatal dose for a sensitive DSLR TTL circuit. This high voltage flash gun will work endlessly, the only damage is to the TTL flash circuit. When you attach a TTL flash to the DSLR after using Vivitar 3200A for sometime, your TTL flash will not communicate with your camera. It will be just another ordinary flash without any auto functions. There is a Wein adapter that you can fix b/w your cameral hot shoe and the vivitar flash gun that is said to reduce the trigger voltage that passes into the camera. Try it if you get it. Without this gadget it is better not to use non recommended and non TTL flashes on latest DSLRs.
Apr 13, 2008 | Cameras
Vivitar 283 charges but fails to flash
I had the same problem with my early Vivitar 283 flash.  I discovered that the thyristor on the trigger board tested as an open circuit.
Trying to find a replacement for a 30 year old thyristor semi-conductor proved to be fruitless.
My solution was to purchase a broken, late model Japanese 283 flash off of ebay and transfer the trigger board to my early Japanese model. The late model thyristors could handle more heat.
Problem solved.
Mar 15, 2007 | Vivitar 283 Flash
Cameras Logo
29 people viewed this question
Top Vivitar Cameras Experts
Tony
Greg Cann
Greg Cann
Are you a Vivitar Camera Expert? Answer questions, earn points and help others
