Centurion gate motor
Hi my centurian d3 motor gate opens and closes without problem however when opened and closed there is a period of aprox 3minutes that it won't work ie. it cannot be re-opened without waiting 3- 5minutes. Please help
    Top Expert:
  • 12,223 Answers
YOU MUSt test the r.control see the photo atttached, when you hit any key the LED must be ON, and otherwise, you must open the keypads for clean from oxide, corrosion, etc. and clean the springs contacts battery, replace by new ones full charge type alkalynes. and test again.Of ocurse you can have problem too with the control motor.
God bless you
Posted on Nov 25, 2013
5 Suggested Answers
  • 28 Answers
SOURCE: Steps to program additional remotes for Centurion gate motor
hi
are the remotes sorted
Posted on Feb 23, 2010
SOURCE: Hi, I have a centurion
I have the same problem, i have replaced the bevel gears twice and that solved the problem for a short time. Take a look at the play on the bearing housing where the beve gear goes in. It most probably is worn.
Posted on Jan 13, 2011
ercupa190
  • 12223 Answers
SOURCE: Programming the Nova remote for Gemin garage door
download the instr manual go www.manualsonline.com
download the coede www.remotecodelist.com
God bless you
Posted on Apr 04, 2013
gopakumarg43
  • 74251 Answers
SOURCE: Can i please get help on how to programme my
Programming procedure is too much to type in by this window. If you wish to get more details, check these links. http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Pull up previous posts by its left sidebar, or type in the brand name and model number to of your set, to its search box, and press 'Enter' or view it in Mosaic / Timeslide option.
Posted on Sep 26, 2013
Testimonial: "I have a sentry remote and not a sony remote, does it make a difference"
I bought a receiver to pair a Centurion D5 motor with thE Digidoor motor.How do i install the Receiver on a Digidoor motor?
Hi there Vusi.
You should have a manual open and close switch on the wall for your Digidoor. You need to find the two wires which control the open and close functions on the Digidoor Trace these back to the Digidoor motor connect these to the Comm and NO terminals. You also need to supply 12V power to the receiver This needs to be connected to the Possitive and Negative terminals on the receiver. These connections originate in the Digidoor motor housing and can be connected right there. Some Digidoor motors have connection terminals for additional remote receivers in the housing. Remember that the minimum connections needed are Positive, Common(Sometimes the common is also the negative supply so you can bridge the common and negative terminals on the receiver) and NO. Then pair the remote with the receiver as per the instructions in the receiver box. If you still cannot come right post pics of the PC boards of your receiver and Digidoor motor and I will identify the connections for you
Jan 05, 2015 | Televison & Video
These gates have the ability to adjust opening, closing distances and speed. Your manual has the instruction. I would recommend a qualified technician make the adjustments as you have to get inside case(where high voltages are located).
Mar 12, 2014 | Televison & Video
Is it posible to program my Centurion D3 remotes to open an E.T MK111 garage door motor
No. It's not possible. There is no setup codes to synchronize with.
Nov 27, 2013 | Televison & Video
Sliding gate suddenly inoperative, centurian d3 motor, test button flashes 5 times when pressed
Some motors have a thermal (red) reset button on the back of the motor that needs to be reset . And if you haven't yet try turning off the power breaker for a sec then test it again.
Oct 25, 2013 | Cars & Trucks
I got my centurion gate motor D3. the problem is when i press the remote an LED lights but the gate does not open, i opened the motor cover and there is no light nor sound from the motor. the gate can be...
Try to reprogram your remotes.... or replace the batteries even if the l.e.d. still works (it only takes half a volt to make the l.e.d. work but almost the full charge of the batteries are needed to send a working signal.
Oct 18, 2013 | Televison & Video
Trouble shooting Centurion D10 gate motor
look for a loose wire and faulty earth check for wires shorting out to earth
Jul 14, 2013 | Cars & Trucks
My gate is equipped with a D3 Centurion gate motor. When I push the button to open the gate, the motor turns in the opposite direction (close) and tends to close further. Then if I deactivate the gear box...
if you push the open button and it closes indicates that you have the wrong polarity connected to the motor
gate motors are DC so where the positive and negative wires are connected are critical for rotation direction of the motor
Jul 29, 2017 | Garden
I need to programme extra remotes to open and close my centurion gate motor
You can call the Technical Support Hotline at 0860-236-887 or you can e-mail at support@centsys.co.za.
Nov 01, 2010 | Sears Craftsman LiftMaster Chamberlain...
Televison & Video Logo
91 people viewed this question
Top Televison & Video Experts
Electro Med Services...
