SOURCE: Overall details
I like the look of it and from what i have read it should be able to do quite a high mileage with no trouble at all ! I would go for it and enjoy the ride !
SOURCE: Remodelling
Try using Bajaj Platina's Alloy wheels on your bike. It comes in Silver color. If u like black then try using Discover's alloys. U can also change the tires of your bike to the new one used in the New Discover 135 model. Both of the alloys and tires can easily fit on your bike. The modification can cost u upto Rs.4000 including tires. If u want a headlam change also then try using the headlamp of the New Platina. It will work good on your bike. Do not go to the Bajaj's service centre for all these modifications. They will not be able to do it perfectly and will ask u more questions than guiding u to do it perfectly. They will also charge u a hell lot of money. Try using your local mechanic for all these changes and it will not be a tough job for him. U can also bargain on the final price for all the modifications.
SOURCE: starting problem my ct100 bajaj
You need to do a few things to make it start.
SOURCE: IS THERE ANY CDI THAT WILL FIT TO THE CDI OF BAJAJ
hi if its a chinese or indian import has the cdi have two blocks one a 4 pin the other 2 pin if so thay are the same as a chinese sukida honda cg125 copy let me no i can tell u wear to get if it is the same
SOURCE: can u give me full details of cleaning carborator
hi buddy its very easy to clean just take the carb off then once you have disconnected all the pipes and cable just take the bowl off the bottom by 2/4 screws then just clean it all out inside clean the jets i use a air compressor for mine / you can use a brush and petrol good luck budd
Testimonial: "can u give some information of site of repair & manual of Bikes with Pictures. Thanks "
