Question about Garden
KAWASAKI td33 FUEL MIX RATIO IS IT 25:1
  • 2336 Answers
SOURCE: oil to fuel ratio
32 parts fuel to 1 part oil
Posted on Nov 10, 2008
onyeredson
  • 404 Answers
SOURCE: How do i disconnect the oil pump/injection system, Fuel oil ratio
Hi Dan,
Why do you want to disconnect the vital oil supply? If you are experiencing too much blue smoke or plugs oiling you can adjust the amount of oil fed to the engine via the secondary oil pump cable,the one that splits off from the throttle to the carb.
If you disconnect the cable it also stops the oil pump sending oil to inlet, winding out adjuster increases oil screwing in reduces.
As for ratio? trial and error as No knowledge/specification is available for Oil injected engines, poss 25:1 to start but don't blame me if you seize?
Quality synthetic oil is always a must, did you know you can also purchase smokeless two stroke oil?
Good Luck!
Paul 'W'
Please remember the Fixya button if my efforts are respected?
Posted on Jan 24, 2009
  • 104 Answers
SOURCE: fuel ratio for homelite ut10829
the ratio should be 25 to 1 so 250 mls of oil for 1 litre of petrol
Posted on May 23, 2009
dunglizard
  • 3 Answers
SOURCE: Fuel mix ratio for 115 hp force outboard engine
50:1 ratio
panilling9
  • 284 Answers
SOURCE: HT-17 Hedge Trimmer Fuel Ratio?
I use 40:1 in mine always have works perfect 3.2oz of reputable 2 cycle oil to one gallon of fresh gas
try to find the oil that has fuel stabilizer already in it
Posted on Jun 12, 2009
Do I mix the fuel for my shindiawa 575 chainsaw
Re-fill with fresh fuel of the correct mixture
(Shindaiwa Premium 2-cycle Engine Oil
and gasoline-40 : 1 ratio;
other brands-25 : 1 ratio).
Workshop manual
http://www.golftechs.us/Manuals/shin%20chainsaw_current.pdf
Dec 12, 2016 | Garden
What is gas m ratio fr 25cc weer
Hello there
Download here friend.
http://manuals.homelite.com/system/files/4262/original/UT40502_UT40903_041_eng.pdf?2011
Page 8 of the Homelite user Manual gives you the EXACT ratio.
FUEL MIXTURE
'This product is powered by a 2-cycle engine and requires
pre-mixing gasoline and 2-cycle lubricant. Pre-mix unleaded
gasoline and 2-cycle engine lubricant in a clean 1 gallon
container approved for gasoline.
Recommended fuel:
This engine is certified to operate on
unleaded gasoline intended for automotive use.
Mix Homelite Premium Exact Mixlubricant with gasolineaccording to the instructions on the package. If Premium Exact Mix lubricant is not available, use a high quality synthetic 2-cycle engine lubricant, mixed at 2.6 oz. per gallon (US)'
Sep 12, 2014 | Homelite Garden
Proper fuel mixture for Dynamac DY 51?
you would be safe to run a standard 25:1 mix 200ml of 2-stoke oil to 5 liters of petrol/fuel/gas.....(5000ml divided by 200ml= 25) most 2 stoke oil is able to run at 50: 1 mix ...instuctions on what oil ratio should be used are always displayed on the oil bottle you buy for aircooled 2 stroke engines....
Dec 03, 2013 | Garden
Fuel mix for 25cc trimmer
For two stroke engines of this capacity the ratio of fuel to two stroke oil is (25:1) 25 fuel to 1 (two stroke) oil. Eg 200 ml of two stroke oil to 5 litres of fuel.
Jan 27, 2012 | Craftsman 25cc Gas Line Trimmer
I have a 1983 jonsered 520 sp and don't know the fuel ratio for this saw
You should run it at a 25-1 fuel oil mix, use a good quaility two stroke oil.
Oct 09, 2011 | Garden
Whats the fuel and oil ratio for a suzuki ts 250 x
HI, THIS WAS A OIL PUMP SYSTEM AND THE RATIO WAS WORKED OUT AS PER THROTTLE OPENING, IF YOU ARE USEING PRE MIX A SAFE MIX WOULD BE 25/TO/1, TRY TO FIND OUT WHAT THE OLD OWNER USED, TO MUCH OIL CAN CAUSE THE ENGINE TO OVERHEAT.
Dec 25, 2010 | Suzuki TS 185 Motorcycles
Could you please advise on the fuel/oil ratio for a shibaura HB26 blower. I have misplaced the manual. Thanks
From the manual - page 8.
Use only branded two-stroke air-cooled engine oils with the classification TC for mixing. The mix ratio is 25 ~ 30 : 1.
We recommend Shell Super Two Stroke Oil since it is specially tested fr use in SHIBAURA engines.
The mix ratio is 50 : 1
Also, use regular branded gasoline with a minimum octane number of 90.
Aug 08, 2010 | Garden
Fuel mixture 1998 ?
I think the official ratio is 32:1 but a range of 25:1 to 40:1 is acceptable. If you run it wide open and hard most of the time, use the 25:1 or higher oil mix. If you run it pretty easy, then you can go up to 40:1 or less oil.
Good Luck
Dec 18, 2009 | 1998 kawasaki KDX 200
Need fuel mix ratio & plug gap 4 husky 154 sg chainsaw
Hi there, No problem.
Recommended fuel mix ration if using Husqvarna brand premium Two-Stroke Oil is 50:1. If using another two-stroke air cooled engine oil, you should use 25:1 fuel:oil ratio.
Regading the spark plug, the recommended plug is a Champion RCJ7Y with a plug gap of 0.5mm (or 0.020 inches).
Mar 14, 2009 | Husqvarna Garden
Garden Logo
83 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
