Question about Garmin Nuvi 660 GPS Receiver
GPS plug do not fit in car cigarette lighter
I have a Toyota Avalon "98. I just bought a Garmin 260w GPS. It has a power cord; unfortunately, the plug do not fit to the cigarette lighter (the only outlet for power in my car).
How can I get my GPS powered?
  • Garmin Expert
  • 343 Answers
Buy a adapter for your cigarette lighter socket that has multiple sockets with one that will fit the Garmin adapter.
I've never heard of a problem you are having??
Are you using a Garmin plug?
If not get one.
Posted on Feb 24, 2010
How can I change the cigarette lighter fuse in Toyota Avalon 2005?
Changing the fuse in the fuse box wont solve your problem On the back of the socket that is mounted in the dash that the lighter pushes into has a inline fuse that if over heated will blow. You will have to change the lighter. Toyota wanted close to $70 for a replacement lighter for my Tacoma. I never used the cigarette lighter for cigarett but needed to charge my cell phone so I replaced it with a dash Mount 12 Volt Power Socket for $10. Good luck.
Sep 26, 2014 | 2005 Toyota Avalon
How do you get started... where do you plug in the gps in my toyota avalon? I have a 5045
Hello, If i understand correctly, you are just trying to set up your Magellan gps into your Toyota Avalon. First of depending on the kit you got for the bracket to hold the unit, it normally will have a suction cup, that secures the bracket, put the bracket on the window, normally to the right of driver view and toward bottom of window, then after putting mounting (suction cup and gps holder) on window, then mount gps in to bracket, now your gps is mounted at this point on window. Now, of course you have to plug it in. GPS kits when you buy them normally have a 110 power plug ( to plug into home outlet) and some will have with the kit, a 12 volt cigarette type of plug to plug in your car (which is 12 volt power) In your home of course you can charge the gps off your 110 power, and gps will run off internal battery for a few hours, but you will find out like with mine, that your better off to plug into car for power, because the internal battery does not last very long. I have a Magellan as well, and they are great units. NOW this being said, if you did not get with your gps a 12 volt car adapter for your gps, you will have to get one. ( unless you have a power converter, which takes 12 volt and converts it to 110 power, but that's another story and only recommended for devices that do not have 12 volt adapter capabilities)
In conclusion if you have the 12 volt adapter to plug in your gps, all you do is find your cigarette lighter, take out your cigarette lighter, put in glove box for storage, and plug your gps in your cigarette lighter, or any other 12 volt cig lighter plugin. That's all there is to it, and now you have power running off your car. Thanks mike , hope this helps
Jul 23, 2011 | Magellan Roadmate 5045 3065 3055 3045-LM...
I bought at Garmin Nuvi 1300 GPS for my daughter for Christmas. She just tried to use it for the first time yesterday and it doesn't fit the cigarette lighter. What can we do now???
It's strange if the plug doesn't fit the cigarette lighter socket. They can be a tight fit so if you find it a little big for the socket try putting pressure on it to push it in. If it absolutely won't fit you can buy cigarette lighter plugs in car accessory shops. If you can get one that does fit you can cut the one that's on the lead off and fit the new one.
If you cannot get any plug to fit you can get the lead wired permanently into the car. Any garage would be able to do it for you.
Feb 01, 2011 | Garmin Nuvi 660 GPS Receiver
I have a Garmin nuvi 255w GPS. Recently, the cigarette lighter adapter cord began to fray, causing the unit to flip back and forth between running off the battery and drawing power from the cigarette...
You must buy the Special Traffic cord to receive the traffic.....it will have 2 lights to it to let you know that it is working..... just a regular cigarette lighter adapter plug will Not work, you need the Traffic Receiver cord.
You can get them on the Garmin site www.garmin.com
Nov 05, 2010 | GPS
I have a new garmin 260w given to me about a year ago today when i plugged it in to my cigarete lighter it came on then quit charging does that mean my battery is bad and how do i check thanks
On the cigarette plug adapter there is a fuse on the tip of plug its silver or black..... its spring loaded so unscrew it carefully. Check and replace
Oct 12, 2010 | Garmin nuvi 260W GPS Receiver
Battery
The unit will take a very slow charge via your computer. I tell most people no it doesnt charge VIA your PC just because it takes soooo long. I recommend getting a new power cable from GPSCity. Just call them up or follow the like to the cable you need.
** This cable is for the Nuvi 200 series GPS units
http://www.gpscity.ca/garmin-mini-usb-12v-cigarette-lighter-adapter-for-nuvi-in-web-packaging.html
Cheers
Jul 13, 2010 | Garmin nuvi 260W GPS Receiver
Garmin nuvi 260w is not charging with car charger
You have a short in the wire that runs to your unit. Other than holding the wire in the exact location until your charge is complete you would be better off replacing the charging cord. They should be available at your local shop for around $19-$29.00.
May 29, 2010 | Garmin nuvi 260W GPS Receiver
Garmin nuvi 12 volt power cord
Could be the cord or your car plug. Does it fit snug? I have a 1996 Acura TL and the way the cigarette lighter is designed, I have to give it a bit of pressure so it makes good contact. try your unit in another vehicle and see if that solves the problem. If so, it's your car's cigarette lighter connection.
Jul 21, 2008 | Garmin nuvi 200W GPS Receiver
Garmin gps 296
If it does not show 'charging' when connected to power, then something may be wrong with the power cord. If it is the vehicle cord (the one with the cigarette lighter plug) check the fuse in the tip of the cord.
May 10, 2008 | Garmin GPSMAP 295 GPS Receiver
Charging unit with AC adapter
I have a 100v A/C power / charger unit for my garmin C340 GPS that I use to charge my Garmin's battery every day. I can use thj adapter to run the GPS, or just turn it off and let it charge the GPS. But it connects dirctly to the Garmin GPS unit, not to the cradle like the Cigarrette lighter unit does. .
Mar 18, 2008 | Garmin StreetPilot c340 GPS Receiver
Garmin Nuvi 660 GPS Receiver Logo
840 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
