Question about Pioneer PureVision PDP-503HDE 50 in. Plasma Television
PDP 503 hde will not turn on
The screen will not turn on.
When you press the power button on the front of the screen, the littel led goes green for 2 seconds and then red and flashes.
Any ideas
  • mark mcv Jan 23, 2008
    Hi - I also have just had this plasma screen do the same - it is a rapid 3 pulse flash of red followed by a pause then the same red flash. It is a different flash from the flashing red light that you get when you have the receiver switched off. Help!
  • 103 Answers
You need a new y-drive board and possibly a couple of buffer ic's replaced.The ic's definiately need to be replaced by a tv tech.
Posted on Mar 05, 2008
SOURCE:
PDP-4340HD keeps turning off.
Continuous blinks of standby light indicates a fault in the IIC data bus. The main board is likely to be faulty. If you wish to know more Check this link.
Feb 03, 2013 | Pioneer PureVision PDP-4340HD 43 in....
Tip
Waste ink full on Canon ip2000 series, and service mode
<Service mode operation procedures>
1) With the front cover closed, and the printer power turned off, while pressing the Resume/Cancel
button, press and hold the Power button. (DO NOT release the buttons. The LED lights in green
to indicate that a function is selectable.)
2) While holding the Power button, release the Resume/Cancel button. (DO NOT release the
Power button.)
3) While holding the Power button, press the Resume/Cancel button 2 times, and then release
both the Power and Resume/Cancel buttons. (Each time the Resume/Cancel button is pressed,
the LED lights alternately in orange and green, starting with orange.) During initial operations,
the LED blinks in green.
4) When the LED light sin green, press the Resume/Cancel button the specified number of time(s)
according to the function listed in the table below. (Each time the Resume/Cancel button is
pressed, the LED lights alternately in orange and green, starting with orange.)
Time(s) LED Function Remarks
0 times Green Power off When the print head is not installed, the
carriage returns and locks in the home
position.
1 time Orange Service test print
2 times Green EEPROM information print
3 times Orange EEPROM initialization
4 times Green Waste ink counter resetting Proceed to the step 5), and follow the
Waste ink counter reset procedures.
5 times Orange Destination settings Proceed to the step 5), and following the
Destination settings procedures.
6 times Green Print head deep cleaning
7 to 9 times Orange Not used in servicing
10 times Green Return to the menu selection
5) After the function (menu) is selected, press the Power button. The LED lights in green, and the
selected function is performed. (When the operation completes, the printer returns to the menu
In the waste ink counter resetting mode, press the Resume/Cancel button the specified number of
time(s) according to the ink counter reset value listed in the table below, and press the Power button.
Time(s) LED Waste ink counter value
0 times Green Reset the main waste ink counter (0%).
1 time Orang
e
Reset the platen waste ink counter (0%)
2 times Green Re-set the main waste ink counter value to 50%.
<Destination settings procedures>
In the destination settings mode, press the Resume/Cancel button the specified number of time(s)
according to the destination listed in the table below, and press the Power button.
Time(s) LED Destination
0 times Green No change
1 time Orang
e
Japan
2 times Green Other than Japan (A4)
3 times Orang
e
Other than Japan (LTR)
on Jun 30, 2010 | Canon PIXMA iP2000 InkJet Printer
RCA D52W20 WONT TURN ON...GREEN LED ON /OFF THREE TIMES
LOCATION NUMBER CP114,CP150,CP140,CP120,CP130 ANY CAN BE BAD ALSO SOLDER LOOSE CONNECTION UNDER FLYBACK
Aug 28, 2009 | RCA HD52W58 52" TV
Green spots/pixels at top of TV screen
I have a 50" Pioneer PDP-503MXE with the same problem - the fans don't run. It appears to be a problem with the temperature sensor that controls the fan speed. However, the fans can manually be switched to MAX.
To do this, put the display in standby. Press the 'Menu' button and within 3 seconds press the 'Power/Standby' button. The 'Integration Menu' will appear. Select the 'Option' tab on the right. Scroll down (next page) to the 'Fan Control' option. It will most likely be set to 'Auto'. Press 'Set' to change it to 'Max'. Within a few seconds the fans will run.
At Max the fans are a bit noisey but it will cool the unit down.
May 05, 2009 | Pioneer PureVision PDP-503CMX 50 in....
Cartridge seems to move smoothly. Just get the
There could be 2 reason for this error. You can either reset the error or try and clean the printer from inside which might be causing the problem. Below are the 2 steps:
STEP 1: Clean the printer from inside
  1. Opened the cover and checked the front right of the printer near the waste ink pads
  2. Carefully turn the cogs to move the ink cleaning mechanism
  3. There might be a load of paper jam debris blocking the mechanism from reaching its port
  4. Carefully cleaning this out and putting the printer back together
STEP 2: Reset the error
1) Close the print head cover, and turn off the printer. While pressing the Resume/Cancel button, press the Power button. (Do not release the buttons. The LED lights in green to indicate that a function is selectable.)
2) While holding the Power button, release the Resume/Cancel button. (Do not release the Power button.)
3) While holding the Power button, press the Resume/Cancel button three times, and then release the Power and Resume/Cancel buttons. (Each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange.) During initialization, the LED blinks in green.
4) When the LED stops blinking and lights in green, press the Resume/Cancel button the 4 times. (Each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange.)
5) Press the Power button. The LED lights in green, and the selected function is performed. (When the operation completes, the printer returns to the menu selection mode automatically.)
6) Power off then back on and test.
Apr 26, 2009 | Canon PIXMA iP90 Mobile Printer
I need to know what the error codes 5100, and 5700 mean, and what causes those errors to come up on the screen. Thank you
Try resetting the printer:
Jun 20, 2008 | Canon PIXMA iP90 InkJet Printer
Screen wont turn on - flashing green light
hello mark ,just had the same problem with my pioneer pdp503 hde, fixed myself and very easy to do. its the power supply board ,got mine on ebay for 109 pounds.was very easy to fit.it is the big silver panel in the center just unscrew and disconnect cabels. very commen problem in pdp . mark doran post again if you want more info
Jan 23, 2008 | Pioneer PureVision PDP-503HDE 50 in....
PDP 5030
This may help you Greger, I found this on another site and I assume your model is simular to the 503 HDE... Good Luck - Rob...
I had exactly the same problem with my 503HDE. Screen would randomly shutdown and display E01.
In my case I believe that the cable was not at fault. The power supply in the media box looks like the most likely culprit.
I dismantled the media box and removed the LARGE power supply board and checked for dry solder joints. Sure enough, where the heatsink was soldered onto the board the joints were in a bad way. I reckon this is a symptom of the fact that the media boxes for V3 Pio's get very hot - all that expanding and contracting is likely to create dry solder joints. Taking the box apart shouldn't be a problem for anyone with a reasonable level of IT type skills!
I resoldered the joints and (touch wood) I've not had a problem for over 2 months. Whilst I can't guarantee that this is the definitive fix for this problem it seems to have worked for me. I'd be interested to hear if anyone else finds this cures the E01 problem.
Not being a hardware engineer, my only doubt is why the heatsink is connected electrically to the circuit board. Would this be for earthing purposes or perhaps to do with temperature sensing? Not sure about that - rolleyes.gif
Hope this helps someone - six grand is a lot of dosh to write off!! __________________
Dec 26, 2007 | Pioneer PureVision PDP-5030HD 50 in....
Open Questions:
See all Pioneer PureVision PDP-503HDE 50 in. Plasma Questions
Pioneer PureVision PDP-503HDE 50 in. Plasma Television Logo
274 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Marvin
Marvin
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
