Question about Cell Phones
Ipod heat issue
I open my ipod 4g I lift the metal cover to plug in the digitizer conectorand I think that I muve someting underned, because when i put it to charge it gets hot in top left corner and also it has screen of dead, I try reseting and still the same; please give me a good answer on this one, I will get it done myself.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 46 Answers
It is not a heat issue, you have shorted the board out.
You need to have the iPod repaired. If you know about circuits, you could test each one on the board, but you need to know the resistance of each one. I suggest you send it to apple repair.
Posted on Nov 25, 2013
  • jesus cota Dec 09, 2013
    Thank u sr. For your help, and one last question I found that my on and off botton flex is broken u think that could be the problem, I change the screen many times in difrent divises, I got the right tools and I im very carefull every time I do it, so u think that my flex could be the reson or is it short out for shur? Thank you...
4 Suggested Answers
SOURCE: Number 2 in top left hand corner
hold down hash key for 3 seconds and it will go away
it is something to do with which line you are using,
Posted on Nov 08, 2008
  • 4 Answers
SOURCE: number 2 in the top left hand corner
this is due the fact that your mobile's line is set to line 2
in the ideal screen press # for a few seconds it may solve the problem
Posted on Jun 07, 2009
xyver
  • 173 Answers
SOURCE: frozen screen on ipod 4,
I have seen this!
even though the screen is till on, pretend its not OK!
lets try forced recovery.
have iPod unplugged, itunes running on pc/mac
hold down home screen button & then plug into pc/mac
continue holding.....like 45 - 80 seconds (really)
iTunes (may) finally find an iPod in recovery mode, let off button, hit ok on pc/mac then restore
Hope it works!
Posted on Mar 20, 2011
Testimonial: "Well, even though the guy had a roommate messing with him, it Did work! just like he said!"
How to Replace screen and digitizer for iPod touch 4th gen.
iPod Touch 4th Generation:
iPod Touch 4th Generation: Heat the surrounding edges of the iPod for 30 seconds
Begin at the bottom corner...used a straight blade to pry the glass up slowly; the LCD will come with it since they are fused together.
When you get closer to the top be very careful since the wifi cable is normally sticking to the glass. If it is use a small screw driver to detach it from the glass. The wifi cable is on the opposite side of the power button.
There is one flex cable (LCD) that can be removed; just a slight twist and it should pop off easily.
The other flex cable (Digitizer) is under the logic board and since you'd be replacing it you can cut this flex cable to work with more ease.
Remove the eight screws on the metal plate.
Remove the metal cover over the camera...screw driver on the very edge and pop up...do not use much force or dig at it since it would be very easy to destroy the camera.
To remove the metal plate that covers the batter: bottom left corner... dig your screw driver in (shallow) then push through horizontally until you reach the edge and lift the end of the screw driver upwards...using this method will allow the speaker to stay in place and the metal plate to separate.
Remove the top three screws
Put a screw driver between the logic board and the power flex cable as you gently lift the logic board up on that side...this method will ensure you don't rip the POWER flex cable
Do not lift aggressively...both cameras must be lifted gently, the adhesive is not that strong but there are some there.
The power and volume flex cable connection to the logic board is near the volume buttons, be extremely careful not to damage the connection when lifting the logic board.
Remove the copper tape surrounding the connection for the digitizer and install new digitizer.
Follow steps in reverse.
Good Luck
Sep 23, 2013 | Apple Touch Screen Digitizer For Ipod...
Tip
How to replace your ipod battery
1. buy a new battery
2. open ipod (where it joins up) with thin pice of plastic or metal
3. there will be clips holding then together. push them in and they will open.
4. open ipod carefully because there a ribon cable holding each side together
5. carefully remove the hardrive, (should have a rubber protection around it) by lifting the cable socket.
6. removie battery carefully with thin plastic or metal. try not to touch the circuit board underneath.
7. disconnect wire from ipod case. (pull them from socket)
8. attatch the new battery
9. put back in hardrive
10. put case back on and your all set.
on Feb 17, 2010 | Audio Players & Recorders
My iPod touch 4th gen is disabled and won't shut off, what do I do?
The iPod 4G (fourth generation) is easy to restore to factory settings. This may reinstall the software, and it always wipes all music, video and other data from the iPod. Restoring is the most effective way to fix problems with the iPod that haven't been fixed through traditional troubleshooting. You will not be able to retrieve data from your iPod 4G once it's restored, so make sure you back up your information first.
Plug your iPod 4G into your computer with its dock connector USB cable. Install the most recent version of iTunes and open iTunes. Wait a moment for your iPod to appear in the side bar. Click on your iPod in the side bar and select "Restore." A pop-up window will ask if you're sure you want to clear your iPod and restore to factory settings. Click "Continue" and enter your password, if prompted. Leave the iPod untouched and on a flat surface while it restores to original settings. It's important that you don't try to disconnect or use the iPod while it's restoring. You'll see a progress bar either on the iPod or your computer that indicates how far along the process is. Select your new syncing settings (automatic sync or manual) when prompted after the restore is complete.
Feb 10, 2013 | Apple iPod touch
Why is my ipod 4g screen blank
is it an ipod nano ?
Remove the two screws on the panel on top of the Nano and remove the top panel.
Use a case opener tool to pop the plastic screen cover off the unit.
Slide the screen up to expose the orange ribbon cable on the bottom of the screen that connects to the motherboard.
Unplug the orange ribbon cable from its port and slide the screen out of the Nano.
Fit a new screen in the Nano and plug the ribbon cable into the port.
Replace the screen cover and top panel of the Nano.
hope this helps
http://www.bing.com/videos/search?q=how+to+replace+an+ipod+4g+screen&qpvt=how+to+replace+an+ipod+4g+screen&FORM=VDRE
Sep 29, 2012 | Audio Players & Recorders
Hi i put a paas code to my ipod touch 4G and i forget the passcode , i tried many times , now my ipod is disabled what can i do ? regards
According to Apple, if you have forgotten the code, you can unlock the IPod by doing the following:
Connect your IPod to the primary computer you use it with (the first one IPod synced with), and open iTunes.
When you disconnect iPod from the computer, it will no longer be locked.
If you can't unlock IPod using either [the code or connecting it to the computer you use to manage its songs]. . . you can restore your iPod to factory settings using iPod Updater. Please note that this will erase all data on your iPod.
Afterwards, you can add your music and data back to your iPod.
If you want to change the primary computer that your IPod is associated with, do this:
1. Restore your iPod. WARNING: The restore process cannot be undone.
All of your songs and files will be deleted. Always make a backup of your important data.
2. Connect your iPod to the computer that you want to be the primary computer.
3. Open iTunes and synchronize.
Apple also notes that company "representatives cannot unlock an iPod if you forget your combination. If you can't unlock your iPod and you don't have access to the primary computer, your only option is to restore the IPod, which will erase all music and data."
For this FREE answer, Please rate me
Jan 26, 2011 | Audio Players & Recorders
Ipod nano 4G silver not syncing
Well if you bought it off of ebay or some other internet site you might have bought a clone ipod that only syncs with windows media player, but if you bought it from a certified Apple reseller than I dont think I know. goodluck !
Feb 28, 2009 | Apple iPod nano
install the version 7.7.20.14 it may work
Jan 09, 2009 | Apple iPod nano
Nano (4g) ipod
Nano iPods do not take pictures, they only play music.
Oct 28, 2008 | Apple iPod nano
Ipod nano 4g
i think
i can solve your problem if u follow these steps:
1connect the device to your com
2.right click on ur device and format it
and then again connect it
tat will solve ur prob
i have the smae prob now it solved
Dec 31, 2007 | Apple iPod nano
Ipod nano
The bad news is its probably scoobied. Open your ipod up by using two small screwdrivers inserted between the metal and plastic parts of the casing and gently prise apart. Disconnect the hard drive and put to one side. Then there are some small screws that hold the top part of the casing on, unscrew these and lift the plastic cover away from the logic board and chassis.
Leave your ipod and all the bits open in a warm dry place for a couple of days to make sure it is fully dry. Then reassemble and try charging it.
As I say its probably knackered but you might get lucky.
Nov 22, 2007 | Apple iPod nano
Cell Phones Logo
56 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
