Question about Oki Electric Industry B411dn Printer
(toner empty) replace toner problem although i put toner
I don't use this machine for 9 months
Hello, we have a Xerox Workcentre 7545, the waste toner cartridge needs replacing but we don't have the part yet. Can I manually empty the cartridge in the meantime so we can still use the machine? ...
If you can remove the waste toner cartridge go ahead and empty it out manually. Make sure that it is completly clean out. I use compressed air to flush out any residue.
Sep 22, 2011 | Xerox WorkCentre M-24 Color Copier
Hi, I have kyocera km c850D. Please could you explain why machine keeps saying replace waste toner box although it is quite empty. please advise if tere are any other parts of the machine to clean or...
Are you using a new waste toner container or did you empty the one that was already in the machine?
The machine uses a sensor that looks at the container to determine if it is full of waste toner. If there is toner on the inside sides of the container were it looks for toner it will indicate that it needs to be replaced even if you have emptied the toner out.
It is a good practice to replace the waste toner container with a new one, that is the way the machine is meant to be used.
If you have correctly installed a new waste toner container and the message hasn't cleared you may have a faulty sensor.
I hope this information is helpful,
Shawn
Jan 26, 2011 | Kyocera Mita (km-c850d) All-In-One Printer
Fax machine Samsung Inkjet Fax SF-360. Ink was finished so ordered the correct ink cartridge and replaced it now on the screen it tells us to install ink cartridge. I have tried severeal times and i know...
If the Toner Low/Empty message does not automatically clear when a new cartridge is installed, use the following to clear the message manually:
1.Press MENU # 1 9 3 4. The machine should display TECH.
2.Press MENU, and ENTER. The machine should display TECH Mode.
3.Press the left arrow < once. The machine will show NEW CARTRIDGE.
4.Press ENTER, the machine will show YES.
5.Press ENTER, there should not be any Toner Low/Empty message.
6.Exit TECH MODE, press MENU # 1 9 3 4. The machine will no longer display TECH.
If Toner Low/Empty message continues, there may be a problem with the toner cartridge or the machine.
Jul 21, 2010 | Samsung SF-5100 Plain Paper Laser Fax
Canon MX850 Empty Cartridge override
That code is "out of toner". I would try a genuine Canon Toner Cartridge.
Sep 24, 2008 | Canon FaxPhone L75 Plain Paper Laser
Xerox DC12 Error code 9-355
That is a magenta toner empty message, either the magenta is empty of there is an issue with the magenta toner dispencing.
May 07, 2008 | Xerox DocuColor 12 Color Copier
Xerox dc12 error message 9-355 on machine cant find out what it means. anyone help
that is a magenta toner empty message.
If the toner is not empty you most likely have a bad toner dispenser.
May 01, 2008 | Office Equipment & Supplies
LEXMARK X215 MFP ERROR MESSAGE
press menu-#-1-9-3-4 with the copier on enter in tech mode. press menu and scroll to new cartrige; select yes. press again menu-#-1-9-3-4 to exit service mode (do not modify other item; your machine will broken!)
good luck !
bogdan_enache89@yahoo.com
Apr 01, 2008 | Office Equipment & Supplies
"toner empty" problem
The samsung sf 5100 toner cartridge has a .05 Amps fuse in it. This gets blowed when you switch on the machine.This is used to reset the page counter and also to inform the machine that you have inserted a new toner. Now this recycled cartriges will not have this fuse and this is the reason why your machine shows TONER EMTY message! If you dont get the same rating fuse, put any fuse of the same size, insert the toner, close the door and just switch on the power and switch off immediately. Then take out the Toner cartridge and remove the fuse. Now your cartridge is ready for use.
Dec 06, 2007 | Samsung SF-5100 Plain Paper Laser Fax
Waste Toner Light won't go off?
The waste toner is usually a bottle near the toner cartridge which collects excess toner powder from the cartridge. It is usually present in more heavy duty laser printers, not all printers have them as a replaceable supply. You would need to refer to your manual for replacement instructions, they vary from printer model. For this machine, the Waste Toner supply number is #420131. In the case of the first poster, my best guess would be there was spillage of toner on the sensors to detect the waste basket overflowing, hence why the error message is constant. This would require cleaning of the sensors, a relatively simple task but for proper access, the machine would need to be partially disassembles for thorough cleaning. It would be best done at a repair centre.
Aug 04, 2006 | Ricoh Aficio CL2000N Laser Printer
Oki Electric Industry B411dn Printer Logo
Top Oki Electric Industry Office Equipment & Supplies Experts
Tony
Roger Binsfeld
Victorman
Victorman
Are you an Oki Electric Industry Office Equipment and Supply Expert? Answer questions, earn points and help others
